POV-Ray : Newsgroups : povray.newusers : Creating a rotating gem Server Time
7 Jun 2025 17:46:29 EDT (-0400)
  Creating a rotating gem (Message 1 to 10 of 23)
Subject: Creating a rotating gem
Date: 10 Dec 2010 03:30:01
Message: <web.4d01e47564f2c1cb3c0146760@news.povray.org>
Hi all,
I am trying to make myself a rotating gem. I found some sample code from a
different ray tracer program and proceeded to try and "import" it into POV-Ray.
However, the output that I am getting is far from the intended output and I am
at a complete loss as to what I need to do to fix it.
I have included links to 4 images. The GIF file is what I am trying to achieve.
Stone1.bmp, Stone2.bmp and Stone3.bmp and the outputs that I can get by
modifying the specular and roughness flags but I cant get the full clarity
throughout the picture.
The picture is made by using a mesh of 48 triangles, all with the same texture
and the mesh itself has an interior specifying the IoR and a couple of other
flags.
Can anyone suggest what I might need to do in order to get this looking right?
(I would much prefer (detailed) pointers to answers as an answer would defeat
the purpose of learning)
Thanks in advance
Bidski
http://i288.photobucket.com/albums/ll167/Bidskii/diamondrot.gif
http://i288.photobucket.com/albums/ll167/Bidskii/stone1.jpg
http://i288.photobucket.com/albums/ll167/Bidskii/stone2.jpg
http://i288.photobucket.com/albums/ll167/Bidskii/stone3.jpg
Subject: Re: Creating a rotating gem
Date: 10 Dec 2010 06:39:15
Message: <4d021163$1@news.povray.org>
On 12/10/2010 04:27 AM, Bidski wrote:
> Hi all,
> flags.
> Thanks in advance
> Bidski
have you explored the glass.inc file that comes with the distribution
... besides textures there are macros that might be helpful ... some ior
defs too
http://wiki.povray.org/content/Documentation:Reference_Section_7.2#glass.inc.2C_glass_old.inc
http://wiki.povray.org/content/Documentation:Reference_Section_7#IORs
Date: 10 Dec 2010 06:39:18
Message: <4d021166$1@news.povray.org>
Am 10.12.2010 09:27, schrieb Bidski:
> Hi all,
Gems live from reflection and refraction, so they need some environment
to be reflected and refracted.
Also make sure you have the IOR right. (If you want to do it really
good, don't forget dispersion.)
Date: 10 Dec 2010 12:34:21
Message: <4d02649d@news.povray.org>
> flags.
I did a similar cut with csg a long time ago:
(it's a 3.1 object)
http://jgrimbert.free.fr/pov/brilliant.zip
(preview here:
http://jgrimbert.free.fr/pov/objet.html
(object is inside a sphere of radius 1, <0,0,0> is the center of the
greatest circle)
CSG is simpler than mesh when you need an interior.
You need an environment to reflect, and raise the trace level (really
raise it, 5 is far from enough with such gem's cut)
Date: 10 Dec 2010 12:41:42
Message: <4d026656@news.povray.org>
> Hi all,
> flags.
> Thanks in advance
> Bidski
Stone1 is the closest to your intended result.
You may need to change your light's position to get optimum result.
Your camera may not be located correctly.
Any gem have an ior, diamond's ior is close to 2.5.
A gem also have variable reflection. That reflection follows the fresnel
model.
There are some specular highlights.
You need some environment. It can be as simple or complicated as you want.
You may need to adjust max_trace_level. 5 is probably way to small.
Some times, you want to see the light_source... it looks_like{...}
Very low to zero ambient and low diffuse value.
Try to add some dispersion. Stay just a little over 1.
Take a look at glass.inc to get some ideas.
When things are looking good, please use anti aliasing.
Date: 10 Dec 2010 18:20:00
Message: <web.4d02b54b1e34407486c9e330@news.povray.org>
> model.
> Alain
Here is the texture and material that I am using for all of the triangles and
the mesh (material for mesh, texture for triangles).
#declare Diamond_Tex = texture
  pigment { rgbf <1, 1, 1, 1> }
  finish
    ambient 0
    diffuse 0
    brilliance 0.5
    specular 0.9
    roughness 0.05
    reflection
      colour rgb <1, 1, 1>
      0.1
      fresnel on
    conserve_energy
#declare Diamond_Mat = material
  texture { Diamond_Tex }
  interior
    ior 2.417
    caustics 1
    dispersion Diamond_Dispersion     // Defined in consts.inc
    dispersion_samples 7
    fade_power 2                      // Used because POV-Ray complained about
me using refraction in the finish, said I should use fade_power and
fade_distance instead.
    fade_distance 1
    fade_colour colour White
I added a sphere of radius 5 centered at the origin as an evironment (just added
it) to no effect, I still get the same results as I did. I coloured it white. If
I use rgb <1, 1, 1> with a radius of 10 everything vomes up grey, with a radius
of 5 the whole screen is a complete white-wash, using rgbf/t<1, 1, 1, 1> gives
me the same results as Stone1.bmp (both with a radius of 5 or 10). If I specify
no colour the whole picture is black (can't see the gem at all). Am I doing the
right thing here for an environment?
I had already changed max_trace_level from 5 to 10 (was getting warnings about
it, 10 removed the warnings). However I further changed it to 50 and then 100,
the only change that made was that the top of the gem got brigther and at 100 it
was nearly completely white.
I ran through all the finishes and interioirs in glass.inc. All the finishes
gave results close to that of Stone3.bmp, so i kept my finish. All the interiors
gave little to no change to the one I already had.
One thing that I am noticing is that it spends a lot of time rendering the top
of the gem (the part with the most clarity in Stone1.bmp) and then it chops
through the last part in less than a second (total rendering time is 17
seconds).
Regards
Bidski
Date: 10 Dec 2010 19:11:30
Message: <4d02c1b2$1@news.povray.org>
> seconds).
sounds like you need to play with the angle of light_source and/or camera
Date: 10 Dec 2010 21:15:00
Message: <web.4d02dd011e34407486c9e330@news.povray.org>
> > seconds).
Ok, I have tweaked the camera angle and the light_source angle and have gotten
some different results (a little better, but still not quite there). I have
attached a picture of what I have now. (stone4.bmp).
The camera used to be
camera
  location <0, 2.5, -6>
  look_at <0, 0, 0>
and is now
camera
  location <0, 0, -5>
  look_at <0, 0, 0>
and the light_source used to be
light_source
  <0, 0, 0>
  translate <65, 65, -65>
and is now
light_source
  <0, 0, 0>
  translate <5, -5 -5>
Keeping in mind that I have a white  of radius 5 centered on the origin, this
places the camera and the light source directly on the edge of the sphere.
Im not really sure how else to twek this now as every tweak I make from here
returns me to what I had before in stone1.bmp.
If I turn conserve_energy off it brightens the gem considerably, but doesnt
change the overall appearance much.
If I have the following inside a finish
reflection
  0.1            // What is this number doing?
  fresnel on
Regards
Bidski
http://i288.photobucket.com/albums/ll167/Bidskii/stone4.jpg
Date: 10 Dec 2010 23:00:57
Message: <4d02f779$1@news.povray.org>
>>> seconds).
> camera
>   look_at <0, 0, 0>
> and is now
> camera
>   location <0, 0, -5>
>   look_at <0, 0, 0>
> light_source
>   <0, 0, 0>
> and is now
> light_source
>   <0, 0, 0>
> reflection
>   fresnel on
> Regards
> Bidski
getting there ... try something other than black background ... also I
find it helpful to have object at <0,0,0> with cam at say <0,0,-10> (or
some other suitable -z dir) with look_at <0,0,0> ... rotate x*15 angles
cam up by 15 deg then rotate y*30 goes clock-wise ... similar setup with
light_source that way it's easier (to me anyways) to keep track of where
everything is. besides the texture ... light position and cam position
(viewing angle) are most important aspect of scene setup. seems like
you're headed in the right direction.
Date: 10 Dec 2010 23:14:10
Message: <4d02fa92@news.povray.org>
On 12/11/2010 12:00 AM, Jim Holsenback wrote:
thought of this picture after posting:
http://wiki.povray.org/content/File:TutImgRaytracing.gif
thought it might give you some ideas of where you need to be headed with
your setup
