Having trouble seeing any scattering effects from the media I'm putting in. I've
added two lines to my code:
"light_source{<30,0,0> 0.3 media_interaction off}"
to light the room
and
box{<-20,-32,-20>,<10,8,20> pigment {rgbt 1} hollow interior {media{scattering{1
,0.07 extinction 0.01} samples 1000,10000}}}
to scatter the light.
However, I'm not seeing anything. Are my values for the scattering or sampling
not in the right ballpark to see the effect, or is something else going on here?
Thanks!
I figured out my issues, which were numerous. Here is my current result:
http://yfrog.com/fvcode5int5samplesp
Took 22 minutes to render on my computer. I'm steping up the interval and
sampling rate to make a better image though. This program is mind-blowingly fun
Thanks for all the help. No more questions in this thread :)
Subject: Re: How to get preserve color through an intersection call?
Date: 4 Oct 2010 16:04:34
Message: <4caa3352$1@news.povray.org>
> Moving the disco ball to the top makes it look a little better just because the
> walls aren't all the same anymore.
> http://yfrog.com/f7codekp
The right and left spots are geting several colours. It looks like you
have several pieces at those locations.
For the shadow behing the ball, you can try placing the light farther
back or make it shadowless.
To render the beams visible, you need to add some scattering media into
your room. Read the interior and media sections of the documentation.
Date: 4 Oct 2010 16:10:54
Message: <4caa34ce$1@news.povray.org>
Don't increase the intervals value as it will kill your render times.
Only increase samples.
samples 100 will render faster than intervals 10 samples 5 for twice the
total samples.
While you can use samples 10, 100, only the "10" will be used ans the
"100" will be totaly ignored.
The defaults value from the documentation are for smpling method 1. The
default sampling method is method 3. It's defaults are:
intervals 1 // NEVER change that!
samples 10 // MUST be 3 or larger.
Date: 4 Oct 2010 16:13:17
Message: <4caa355d$1@news.povray.org>
> On 03/10/2010 9:49 PM, Brad wrote:
>> Is there a way for me to visualize the light rays that are hitting the
>> wall, as
>> if there were dust in the air? Would I just fill the observable area
>> with a
>> white box with almost perfect transparency? Or is there a more
>> professional way
>> to do this (surely....)?
> You will need to use photons and fill the scene with scattering media.
> Read 3.6.2.1 Media Types
> And for an example look at optics.pov in \POV-Ray\v3.7\scenes\advanced
> To make this work the container for the media needs the "hollow" flag set.
> 3.4.9.5 Hollow.
> Fun, fun, fun ;-)
You DON'T need photons in this case. The light only goes straight
through the transparent parts, thus no refraction, and there are no
reflection.
Thanks for these additional comments Alain. However, before I read them I
already ran a case at 20 samples and 20 iterations, with the output below (and
also rotating the cube a bit so the light isn't shining in the camera's eyes).
http://yfrog.com/2mcode20int20samplesp
It took a little over 4 hours to render on my desktop (ran it overnight). I can
really see how those doing much, much more complicated scenes run into
ridiculous rendering times.
> total samples.
> Alain
Date: 4 Oct 2010 22:49:25
Message: <4caa9235$1@news.povray.org>
>> total samples.
>> Alain
I notted an anomaly in your scene:
The spots are set into 6 sets of 9, for a total of 56. The problem is
that you have 84 cylinders, and looking further, you have LOTS of
duplicates like: <0,0,10> <-0,0,10> <0,-0,10> and <-0,-0,10> with many
apearing in 2 or even 3 colours sets. (manualy changing very small
values to zeros helped a lot to spot those)
Those duplicates increase your render time and cause coincident surfaces
artefacts each time that you have more than 1 colour at the same place.
Date: 5 Oct 2010 16:12:38
Message: <4cab86b6@news.povray.org>
>> below (and
>> camera's eyes).
>> overnight). I can
>>>> result:
>>>> interval and
>>>> mind-blowingly fun
>>> total samples.
>>> Alain
> Alain
After removing 18 duplicates (6 for each colours, only for the
orthogonals ones and not checking between colours sets), I got an
impressive boost in my render time. Down to 66 elements down from the
original 84. Sould be further reduced to 54.
Still have 3 for <0,0,10> and <0,0,-10> that have all 3 colours.
Resolving those removes 4 more elements-> down to 62.
It should be noted that intersection and difference are inherently poor
at bounding: Any ray that encounter those need to be tested against all
components. This also apply to the shadow rays. So the less components
you have, the faster the shadow rays can be evaluated.
I'm thinking of another aproach:
Have only a plain sphere and place a collection of tight spot_light in
it's center. Add double_illuminate to make the spots visible on the
surface. Add no_shadow so that the beams can continue outside of the sphere.
You use the points that you have presently as the point_at for the spots.
Now, any duplicate will be obvious due to the increased lighting.
Date: 6 Oct 2010 13:21:22
Message: <4cacb012$1@news.povray.org>
> sphere.
> Alain
Using that, I got some dramatic speed improvement, about 20 times faster.
The only thing been that if you want to see the bright spots the sphere
can't be black. It can be dark and using fading lights that are very
bright at short distance the spots will show as bright coloured areas.
> > sphere.
> > Alain
> Alain
Thanks for all those additional suggestions and the catching of duplicates
Alain, I really appreciate it! I'm out of town at the moment but I look forward
to playing around with some of your suggestions once I get back.
