POV-Ray : Newsgroups : povray.newusers : realistic smoke with high degree of transparency Server Time
28 Jul 2024 04:26:24 EDT (-0400)
  realistic smoke with high degree of transparency (Message 1 to 10 of 10)
Subject: realistic smoke with high degree of transparency
Date: 5 Sep 2010 14:15:00
Message: <web.4c83d711edeea7abe03d6d450@news.povray.org>
HEllo group, and pov ray gurus i am currently stugggling at making a realistic
smoke, but whenever i' scale it up, smoke appears completely black and white and
let's no light throught it, i played with scaling options of emissions but my
objective it to provide some real transluscent smoke like in realist chimney
that pump quite low emissions that when we've seen in the 19 century industrial
chimenys !
here is the code that is not working when scaling thanhs to lowmuller pages !
when i cale it to about 150 all i get is completly black and white smoke that
not let light through... it now that emission directive shoud de scalled down
(divided by the bontainer scale, but no way)
sphere{ <0,0,0>, 1.5  // increased from 1 to 1.5, because of the turbulent
pattern !!!
        pigment { rgbt 1 }
        hollow
 interior{ //---------------------
    media{ method 3
//           emission 0.6
           scattering{ 1, // Type 1 = isotropic scattering, 2 = Mie haze, 3 =
Mie murky
                          // Type 4 = Rayleigh scattering,  5 =
Henyey-Greenstein scattering
                       <1,1,1>*3.00   // color of scattering haze
                       extinction  1.50  //  // 0 ~ 1 extinction
                       // how fast the scattering media absorbs light
                       // useful i.e. when the media absorbs too much light
                    // eccentricity i.e. -0.6 ~ +0.6 (if type>1 )
           } // end scattering
           density{ spherical // or: boxed
                    turbulence 0.85
                    color_map {
                    [0.00 rgb 0] // density at the border of the media
                    [0.05 rgb 0]
                    [0.20 rgb 0.2]
                    [0.30 rgb 0.6]
                    [0.40 rgb 1]
                    [1.00 rgb 1] // densitiy at the center of the media
                               } // end color_map
           } // end of density
           samples 1,1     // 3,3 for adaptive sampling
           intervals 3     //
           confidence 0.9  //
     } // end of media
  } // ------------------ end of interior
 scale 1
 rotate<0,0,0>
 translate < -0.5, 1.50 + 0.20,0>
} //------------------ end of "Rauch"
please somebody help me i am stuck
Subject: Re: realistic smoke with high degree of transparency
Date: 5 Sep 2010 14:34:15
Message: <4c83e2a7$1@news.povray.org>
emission 0.6
<1,1,1>*3.00
When you scale up the object, you want to divide those numbers by the
same amount. So if you "scale 100", add "/ 100" to the end of those
lines. That will reduce the density proportionately and should keep it
looking about the same.
Date: 5 Sep 2010 15:00:35
Message: <4c83e8d3$1@news.povray.org>
Am 05.09.2010 20:14, schrieb rodv92:
> chimenys !
Here are a few hints:
- Don't use emission; real-life smoke does not emit visible light. It
scatters and it absorbs - nothing else.
- For scattering media, always set extinction to 1.0; any other value is
bogus.
- You'll probably want a /bit/ of absorption. Do use "absorption" for
that, not the scattering's "extinction" parameter.
- Expect some media types' effects to scale not-quite-linearly. Don't
expect you can compensate for a "scale 150" simply by a corresponding
division of emission & scattering parameters; you'll probably need to
tweak a bit. If you start with a "scale 10" you may get a better feeling
how scaling affects the media, and how to compensate.
(And finally - I hope I'm not stepping on your toes here - try not to
type so fast; it may help the legibility of your postings ;-))
Date: 5 Sep 2010 15:31:27
Message: <4c83f00f$1@news.povray.org>
> chimenys !
The aspect of media depends heavily on the lenght of the ray as it
travel through it. Scaling up means that the travel lenght increases by
the scaling amount. To compensate, you must reduce the density by the
same value.
If you scale the container up by x150, then you must divide the density
of the media by the same amount:
media{emission 0.6/150...
scattering{1, 1*3/150...
Altrernatively, you can divide the values in the color_map by that value
instead of dividing the main density of the media:
     [0.00 rgb 0]
     [0.05 rgb 0]
     [0.20 rgb 0.2/150]
     [0.30 rgb 0.6/150]
     [0.40 rgb 1/150]
     [1.00 rgb 1/150]
Normaly, extinction should remain at 1, it's default value.
Also, normaly, smoke don't emit any light unless it's overheated to some
ridiculous temperature. I'd replace the emission by some actual fading
light_source near the top of the chemeny if you realy need some glow up
there.
Some complementary notes about media sampling:
The default method is method 3
samples only take a single integer value. You can add a second value,
but it will be ignored. method 1 and 2 DO use 2 values.
confidence is not needed and not used. Only usefull when using method 1
ou 2.
You use samples 1. It will take only one sample ether as the ray enter
the container or at the middle point. Both will give you the wrong
result. The minimum value for samples should be 3 and defaults to 10.
NEVER EVER use intervals! It defaults to 1 and should be left at that
value. It must only be used with method 1 or method 2.
"samples 30" is faster than "samples 5 intervals 3" for twice the total
samples count. I know, I've done some testing and found that using ONLY
samples you may have about 10 times as many samples as you get using
samples and intervals for about the same render time.
A media with samples 300 rendered in about the same time as the same
media with samples 5 intervals 5
intervals can also cause artefacts to appear.
Date: 6 Sep 2010 23:25:00
Message: <web.4c85afcb1a9cf0e3e03d6d450@news.povray.org>
> > chimenys !
> same value.
>      [0.00 rgb 0]
>      [0.05 rgb 0]
>      [0.20 rgb 0.2/150]
>      [0.30 rgb 0.6/150]
>      [0.40 rgb 1/150]
>      [1.00 rgb 1/150]
> there.
> ou 2.
> Alain
Hello Alain, thanks for the reply, it solved most of my issues. there is only
little problem left, when i scaale up, the bounding sphere appears in a light
shadowy grey even if a specify correct transmit value, i do not know if it is
linked to the fog, sky sphere above plan cloud etc...
if you could shed some light on the issue a would appreciate
Date: 7 Sep 2010 17:16:58
Message: <4c86abca@news.povray.org>
>>> chimenys !
>> same value.
>>       [0.00 rgb 0]
>>       [0.05 rgb 0]
>>       [0.20 rgb 0.2/150]
>>       [0.30 rgb 0.6/150]
>>       [0.40 rgb 1/150]
>>       [1.00 rgb 1/150]
>> there.
>> ou 2.
>> Alain
The use of fog is the most porbable cause of what you describe.
With fog, you start evaluating the fog between the camera and the
container sphere, this gives you a value for the fog effect. You then
evaluate the fog inside the hollow sphere giving you another value. And
finaly, you evaluate the fog for the rest of the ray after the sphere up
untill you hit something else or the background, giving you a third
value. All those values are added toggether and don't summ up to the
same as the fog alone when you never encounter the container. This
especialy true when you reatch the background or a background feature as
a sky_sphere.
The cure is usualy to use actual media instead of fog... With the
obvious effect on the render time.
Date: 20 Sep 2010 15:25:00
Message: <web.4c97b4121a9cf0e3e03d6d450@news.povray.org>
> >>> chimenys !
> >> same value.
> >>       [0.00 rgb 0]
> >>       [0.05 rgb 0]
> >>       [0.20 rgb 0.2/150]
> >>       [0.30 rgb 0.6/150]
> >>       [0.40 rgb 1/150]
> >>       [1.00 rgb 1/150]
> >> there.
> >> ou 2.
> >> Alain
> a sky_sphere.
> Alain
Hi again! i appreciate very much your help.
the culprit in fact is a sky sphere to render a dawn sky.
i tried to replace it with a media, but the smoke container is still visible,
if you like i can send you my scene (or your friends) (it is quite nice) and
maybe you could see what could be done, sorry to bother you but pov ray has
quite a difficult learning curve :)
my mail is rodv92 at the gmail.com provider.
Rodrigo,
ps: are you french ?
Date: 20 Sep 2010 22:22:15
Message: <4c9816d7$1@news.povray.org>
> Rodrigo,
A sky_sphere is a background feature. Any ray that encounter it have an
undefined length.
This leads to some problem when you have any media or fog in some
container. Whenever you reatch the background directly, you have
undefined ray length. Whenever a ray encounter a transparent object, you
effectively get 3 ray segments, 2 of whitch do have a precise, finite,
length and one of undefinite length.
That's what causes the container to become visible.
A workaround:
Use a very large "world sphere". That's a unit sphere that have the
pigment you would use for the sky_sphere, that is scaled up by a large
value like 100000. Make that sphere hollow or use the "inverse" keyword
so that media and fog can exist within.
Now, you no longer have undefined ray length.
You can post your scene on povray.scene-files if it's relatively small
and self contained, or povray.binaries.scene-files for a large one
needing some include or other resources. On that last group, you can
post a zip containing your scene and all of it's parts.
native language, and, like most francophone in my area, I'm functionaly
bilingual.
Date: 20 Sep 2010 22:33:47
Message: <4c98198b$1@news.povray.org>
Small corection: it's povray.TEXT.scene-files for the smaller scenes.
Date: 27 Sep 2010 09:35:01
Message: <web.4ca09cf81a9cf0e34213a2ef0@news.povray.org>
Thanks for the suggestions,
and indeed i tried all the combinations :
sky_sphere
"world sphere"
sky by using media
all, unfortunately, make the container visible (however when using media the
container is partially visible (truncated with a white aura, maybe with some
adaptations it is the way to go...)
if somebody could get a look at my scene, the code is a bit messy, the sky
elements are at the beginning of the code, the smoke is quite at the end,
(you may also comment the code creating the trees)
Thanks in advance, it will help me to move on with my first POV ray scene.
http://news.povray.org/povray.binaries.scene-files/thread/%3Cweb.4c9cea4f846f1355e03d6d450%40news.povray.org%3E/
