POV-Ray : Newsgroups : povray.newusers : getting some existing value as a variable Server Time
7 Apr 2026 19:26:36 EDT (-0400)
  getting some existing value as a variable (Message 1 to 8 of 8)
Subject: getting some existing value as a variable
Date: 3 Sep 2009 09:30:00
Message: <web.4a9fc4204fc5d1a76ce87ead0@news.povray.org>
Is it possible to get some already defined parameter as the value for some
variable? My reason to ask is I would like to keep the value output by my
exporter for some parameter (light position), and use it in a hand written
macro (SBenge SSS) This would allow to move the light and not having to always
modify the variable pov code by hand.
Say I have a light
light_source { <x,y,z> rgb <1,1,1>*3 spotlight point_at
<-0.281606,0.960535,-0.0901413> falloff 15 radius 12.75 fade_distance 30}
is there anything like
#declare
lpos = light_source.position
that would evaluate to lpos=<x,y,z> ?
Subject: Re: getting some existing value as a variable
Date: 3 Sep 2009 10:03:15
Message: <4a9fcca3$1@news.povray.org>
Mr schrieb:
> Say I have a light
> #declare
No, querying the properties of scene elements is generally not supported
by POV-Ray's SDL.
For objects, you can get the approximate position via the min_extent()
and max_extent() functions, which return the corners of the bounding
box; I never tried whether this works with light sources as well, but I
wouldn't bank on it.
Date: 3 Sep 2009 10:20:00
Message: <web.4a9fd022300e4d4f6ce87ead0@news.povray.org>
> Mr schrieb:
> > Say I have a light
> > #declare
> by POV-Ray's SDL.
even more so since my light doesn't have a name
Thanks,I'll just have to type the code for my main light, it will be a chance to
see if I can get anything more from it than by my exporter.
Date: 3 Sep 2009 12:39:05
Message: <4a9ff129@news.povray.org>
"Mr" <nomail@nomail> wrote in message
news:web.4a9fc4204fc5d1a76ce87ead0@news.povray.org...
> exporter ...
I agree with what's been said so far and at the risk of stating the obvious
I just wanted to check what you meant by "my exporter". If it's an exporter
you've written then you can of course get your exporter to #declare a vector
for the location of your light and use it in both the light_source and for
any subsequent purposes that you wish:
#declare LPos = <x,y,z>;
light_source {LPos rgb ....
Of course, if you just mean "the exporter you're using" then this is no
help.
Chris B.
Date: 3 Sep 2009 13:05:00
Message: <web.4a9ff619300e4d4f15e458d60@news.povray.org>
> > exporter ...
> help.
> Regards,
> Chris B.
Unfortunately, it's the exporter I'm using :( Blend2pov) a gpl version used to
exist but nobody has ported it to the current version of blender 2.49 without
closing the source afterwards and since it's not a script anyway but hardcoded,
there's even less chance that I could understand and change it (yet) anyway.
Maybe in a few years/months.
Date: 3 Sep 2009 15:23:34
Message: <4aa017b6$1@news.povray.org>
How can someone modify a GPLed piece of software and release it without
providing access to the source code?
Date: 3 Sep 2009 17:09:02
Message: <4aa0306e@news.povray.org>
"clipka" <ano### [at] anonymousorg> wrote in message
news:4aa017b6$1@news.povray.org...
>> used to
>> without
>> hardcoded,
I would imagine it would have to be the original author/copyright holder,
who is at liberty to relicense versions so long as the alternative licensing
doesn't conflict with the rights that he's already given in perpetuity to
use, modify and redistribute the original GPL'ed code.
Date: 3 Sep 2009 19:10:00
Message: <web.4aa04bd7300e4d4fce00efe80@news.povray.org>
> >> used to
> >> without
> >> hardcoded,
He's not the original author of the code. But anyway... He's not ignoring
feedback.  He's the only one maintaining code synchronised with Blender CVS, so
I implicitly agreed to his terms. I just want to use whatever works.
