POV-Ray : Newsgroups : povray.newusers : layering patterned textures Server Time
23 Feb 2025 12:47:10 EST (-0500)
  layering patterned textures (Message 1 to 6 of 6)
Subject: layering patterned textures
Date: 27 Aug 2009 07:20:01
Message: <web.4a966bb9ac3d3f2cb03583440@news.povray.org>
While playing with fastprox and trying to layer it over a slope pigment, I get
the following error message: "cannot layer patterned textures"...
I thought that was the whole point of layering textures... What is happening?
Subject: Re: layering patterned textures
Date: 27 Aug 2009 09:51:57
Message: <4a968f7d$1@news.povray.org>
POV-Ray provides two ways of combining textures:
(1) Layered textures:
You create these by specifying multiple "texture{...}" statements in a row.
That's what you tried.
(2) Blended textures:
These include averaged textures (using "texture{average
texture_map{...}}"), as well as patterned textures (using the
"texture{PATTERN texture_map{...}}" or "texture{PATTERN texture{...}
texture{...}}" syntax), plus a few specialties.
That's apparently what fastprox is using.
While blended textures can combine /any/ textures no matter how complex,
layered textures can only combine simple "atomic" textures (and possibly
other layered textures, though I'm not perfectly sure about this).
The reason for this is that layered textures are much more coherent,
with the upper layers affecting the processing of lower layers (which by
the way also allows for some optimizations), while the elements of
blended textures can all be evaluated independently, and the results
then just averaged according to the parameters in the combining texture.
Date: 27 Aug 2009 09:58:26
Message: <4a969102$1@news.povray.org>
I just read your other post. To avoid any misunderstanding: Patterned
/pigments/ (and patterned normals, for that matter) present no problems
in layered textures. A texture can have the most complex pigment, and
still qualify as a simple "atomic" texture.
Date: 27 Aug 2009 13:30:01
Message: <web.4a96c2961959013e356795ba0@news.povray.org>
Thanks (sorry for double posting)I still have to identify excactly where the
problem is but what you said gives me a clue to a different approach using
black or white with blended textures instead of transmit with layered textures.
Yet I'm not sure it will work as I'm trying to use the back diffuse light which
i guess doesn't show without transparency, does it?
Date: 27 Aug 2009 19:28:44
Message: <4a9716ac$1@news.povray.org>
It does.
Transparency is really only needed to have things on the other side be
plainly visible, unblurred.
Backside illumination is there to do exactly the opposite: Make an
object appear translucent, /without/ making things on the other side
plainly visible.
Note however that in order for backside diffuse illumination to do
anything useful, your objects must be either non-solid (i.e. just one
infinitely thin surface), or you must use radiosity for the light to
carry all the way through the object.
Date: 28 Aug 2009 15:15:01
Message: <web.4a982c001959013e356795ba0@news.povray.org>
> It does.
> plainly visible.
I guess the problem was that I had a somewhat closed mesh (head open at the
neck). So I would have to use radiosity. Thanks.
