POV-Ray : Newsgroups : povray.newusers : rendering edges Server Time
6 Oct 2024 06:21:16 EDT (-0400)
  rendering edges (Message 11 to 13 of 13)
Subject: Re: rendering edges
Date: 14 Aug 2009 15:24:21
Message: <4a85b9e5@news.povray.org>
"Mr" <nomail@nomail> wrote in message
news:web.4a85a04f4068d214e3f0b2880@news.povray.org...
> No document, I don't know how the original patch by RCRuiz is commented:
> http://code.google.com/p/blend2pov/
> JMS won't release the current modified source, but I'll just ask him about
> those
> faceless edges. If you speak french and are interested in this tool here
> is the
> forum of JMS.
> http://www.zoo-logique.org/3D.Blender/newsportal/thread.php?group=3D.Pov-Ray
I read a few of the posts, but I don't see anything on how it handles edges
or vertices (or even faces for that matter). It mostly spoke of textures and
the Intel Mac issues. I also tried writing an XML file from Blender, but it
seems to require YafRay to be installed (which is odd as the XML file would
be extremely useful if you had Blender and YafRay installed on separate
machines).
If you can switch on the YafRay XML option and generate a file with only a
square plane and one of the vertices extruded to create an edge, then it
should be easy enough to see how it handles such edges and whether there's
any hope of getting such information across into POV-Ray.
Chris B.
Date: 15 Aug 2009 17:05:01
Message: <web.4a8722ac4068d2141c8336ca0@news.povray.org>
> Regards,
> Chris B.
Thanks I did that. Unfortunately the extruded vertex is completely ignored and
the resulting Pov code has only 4 vertices:
//Generated by Blender (Blend2Pov 0.0.6j modification by RCRuiz
ram### [at] hotmailcom)
#declare OBCube = mesh2 {
 vertex_vectors
{4,<1,-4.16881e-007,1>,<-1,-3.91654e-007,1>,<-1,-1.06423e-007,-1>,<1,-2.1718e-007,-1>
 normal_vectors
{4,<1.26136e-008,1,1.42615e-007>,<1.26136e-008,1,1.42615e-007>,<1.26136e-008,1,1.42615e-007>,<1.26136e-008,1,1.42615e-0
07>
 face_indices { 2,<0,1,2>,<2,3,0>}
 normal_indices {0}
Thanks for your help I'll just do without those floating edges...
Date: 15 Aug 2009 17:56:09
Message: <4a872ef9$1@news.povray.org>
news:web.4a8722ac4068d2141c8336ca0@news.povray.org...
>> a
>> there's
> and
Ah. OK! So Blend2Pov won't be able to do anything with those edges for you
because it never gets the data to work with.
The option I posted in my second post to pick up that info from an export in
'obj' format should still be viable though. You could do that by hand quite
quickly using a search/replace in a good editor. Admitedly it's not
something you'd want to do by hand if you wanted to do it very frequently,
but a short script or a little editor macro could easily transform that obj
file data into something useable. Depends how much you want it :-)
Chris B.
