POV-Ray : Newsgroups : povray.newusers : Object without ligth influence Server Time
16 Aug 2025 00:02:55 EDT (-0400)
  Object without ligth influence (Message 1 to 5 of 5)
Subject: Object without ligth influence
Date: 9 Jun 2009 21:20:00
Message: <web.4a2f0a003360bd2a75f7f8dc0@news.povray.org>
Is there any way to make object color be influenced only by the ambient color?
I have tried to use light_group but the target object goes to dark.
tks
Subject: Re: Object without ligth influence
Date: 9 Jun 2009 22:55:00
Message: <web.4a2f1fe227d874bda6f47e80@news.povray.org>
> tks
The 'diffuse' keyword controls the object's response to the light shined on to
it.  If you set the diffuse component of the finish to zero, the object's
lighting is control only by the ambient light.
-Reactor
Date: 10 Jun 2009 14:40:00
Message: <web.4a2ffd1327d874bdf708085d0@news.povray.org>
Try "finish { ambient 1 diffuse 0 specular 0 }". No "light_group" required. That
should do exactly what you're asking for (although I'm not sure whether it also
does what you really want).
Date: 10 Jun 2009 18:55:00
Message: <web.4a3038ac27d874bd75f7f8dc0@news.povray.org>
Thank you guys. You are right!
My mistake was keep setting ambient_light to zero in the global_settings.
At first, I was using ambient_light (global_settings) black and ambient (finish)
in the texture "white". By this way I needed to setup the diffuse (finish) to 1
in order to see anything, but the image was light influenced.
Date: 11 Jun 2009 17:50:32
Message: <4a317c28$1@news.povray.org>
By using ambient_light 0, you effectively suppress ALL ambient in all
finishes.
The porpose of that setting is to provide a way to tint the ambient of
all finishes in a scene. The final ambient of a finish is calculated as
ambient * ambient_lights
