POV-Ray : Newsgroups : povray.newusers : Generating cross-section of a complicated model Server Time
2 Mar 2026 23:04:09 EST (-0500)
  Generating cross-section of a complicated model (Message 21 to 25 of 25)
Subject: Re: Generating cross-section of a complicated model
Date: 21 May 2009 16:15:39
Message: <4a15b66a@news.povray.org>
clipka <nomail@nomail> wrote:
> So why ask, and not just simply make that point.
  Because he is insising that the problem must be fixed. I'm asking how it
should be fixed.
Date: 21 May 2009 18:00:00
Message: <web.4a15cd17c981982af50167bc0@news.povray.org>
"clipka" <nomail@nomail> wrote:
> Warp <war### [at] tagpovrayorg> wrote:
> >   I'm directly asking you: In the case of overlapping objects, which color
> > should be shown in the overlapping part?
> Well, why are you asking anyway?
> It's a rhethorical question from all I see, as there is no sensible answer to it
> (aside from the current averaging approach), which seems to be the point you're
> trying to make.
I couldn't have stated the situation better myself. ;-)
The spirit of my earlier statements/questions/replies was honestly one of,"Hey,
let's put our heads together and see if we might be able to solve this!"
Nothing more was intended. But the general idea became, "Solve what?? What
problem??" Argumentation ensued. Reminds me of the story of the 'Emperor with
no clothes'--the Emperor stands there naked, thinking that he's fully clothed,
while others look and scratch their heads, wondering why he doesn't realize
that there might be a...problem. I'm sure he argued the point...
Can the current cutaway_textures 'situation' be 're-worked'?  (Notice the
less-inflammatory language.) Beats me!! Doesn't sound like it can; and I
understand why. Well, I *mostly* understand, anyway...
KW
Date: 21 May 2009 18:05:00
Message: <web.4a15cf5dc981982af50167bc0@news.povray.org>
> With some partial code redesign, it might be possible to pick the texture of the
> object that would have been the last one encountered along the ray if it wasn't
> partially cut away...
Yeah, I guess that's what I meant by my (vaguely-stated) idea concerning the
'innermost' object.
> Professional CAD software avoids the whole issue by not allowing you to insert
> those spark plugs with the sledge hammer in the first place, but be a good boy
> and drill holes into the motor block first...
Yes yes; and I will be gentle.  ;-)
KW
Date: 22 May 2009 12:55:00
Message: <web.4a16d86cc981982a92f9e9e10@news.povray.org>
As I explained earlier, from all I can imagine there's nothing that can be done
about it.
Not unless we're providing the user with a way to add some hints about which of
the intersecting objects should "win" over the other.
It might be worth putting that on the to-do list, but I don't expect to see it
anytime soon.
Date: 22 May 2009 15:28:59
Message: <4a16fcfb$1@news.povray.org>
Kenneth nous illumina en ce 2009-05-21 17:56 -->
>> trying to make.
> KW
"re-worked"? How?
Whenever 2 or more objects with different texture are overlaping, you need to
decide what texture to show.
There are NO way that you can predict what texture to use if you are to only
show one. In two almost identical cases, you may want one texture or the other
to show. Or, the algorythm used may show one texture, then the other after a
slight rotation or translation of the whole object. Sometimes, a slight change
in the composition of the object, like moving or rotating a component, will
cause a switch of the texture used. Add a third object, and the situation will
get even more complex.
You suggested to take "the innermost", but that innermost may not be obvious. It
can only be "obvious", and even then, not always, if, and ONLY if, it's the
texture of an object that is totaly enclosed into another one.
If you don't want the textures to be averaged, you can always cut a hole into
one object to make room for the other.
You do that by deffining one of the objects beforehand, then use a difference to
remove it before you use the union to add it. This will create a perfectly
shaped hole, and there will be no overlaping.
