POV-Ray : Newsgroups : povray.newusers : Problem merging two isosurfaces Server Time
16 Dec 2025 18:42:28 EST (-0500)
  Problem merging two isosurfaces (Message 1 to 10 of 11)
Subject: Problem merging two isosurfaces
Date: 9 Oct 2008 14:05:00
Message: <web.48ee4781aaa214c0c9b9f9f00@news.povray.org>
I have been trying to create basically a cube in which the top and bottom face
is a 2D sine wave (egg crate pattern).  I have been able to do this using
isosurface, with some trouble however.  The way I found to do this was to make
one isosurface sine wave pattern contained by a box and then make another one
also contained by a box and flip it over.  My problem is that when I try to
merge the two objects I create, I have tried merge and union I always see a
middle boundary in between them.  The indicies of refraction are matched and I
am using fresnel reflection, so I do not see how or why I am seeing this.  If
anyone has any ideas on how to make this artifact go away that would be very
helpful.  I have posted the code I used to make the object below.
Thanks,
Mike
#declare MixedRegion =
material {
        color rgbf<0.3, 0.5, .5,1>
 finish {
        ambient 0.0
        diffuse 0.0
         reflection {
          0.0, 1.0
          fresnel on
        conserve_energy
        specular 0.0
        roughness 0.0
#declare botMixingHalf=
isosurface {
  function {
    ( y-5 + .1*sin(3*6.2832*x)*sin(3*6.2832*z))
  max_gradient 4
  accuracy .0001
  contained_by { box { <-1.8999, 4.5, -1.8999>, <1.8999, 5.1, 1.8999> } }
material { MixedRegion }
     interior {
    ior 1.400
 photons{
             target
                refraction on
               reflection on
 rotate 180*z
 translate 8*y
#declare topMixingHalf=
isosurface {
  function {
    ( y-4 - .1*sin(3*6.2832*x)*sin(3*6.2832*z))
  max_gradient 4
  accuracy .0001
  contained_by { box { <-1.8999, 3.2, -1.8999>, <1.8999, 4.1, 1.8999> } }
     interior {
    ior 1.400
 photons{
                target
                refraction on
                reflection on
#declare Mixingregion=
merge{object{topMixingHalf}
object{botMixingHalf}}
object{Mixingregion}
Subject: Re: Problem merging two isosurfaces
Date: 9 Oct 2008 15:33:30
Message: <ItxNcZC$xl7IFwwZ@econym.demon.co.uk>
You could do this:
global_settings {max_trace_level 50}
#declare F = function {y-4.5 + .1*sin(3*6.2832*x)*sin(3*6.2832*z)}
#declare WholeThing =
isosurface {
  function { abs(F(x,y,z))-0.5}
  max_gradient 2.1
  accuracy .0001
  contained_by { box { <-1.8999, 3.9, -1.8999>, <1.8999, 5.1, 1.8999> }}
  interior {
    ior 1.400
  photons{
    target
    refraction on
    reflection on
I'm getting some dark specks. I don't know if that's due to
max_trace_level, or my lighting, or if it's a real effect caused by
small reflections or refractions of shadowed areas. They don't happen
with an opaque texture, so it's not due to max_gradient or accuracy.
Mike Williams
Gentleman of Leisure
Date: 10 Oct 2008 20:20:01
Message: <web.48efeffec4ddaaeec9b9f9f00@news.povray.org>
> You could do this:
> isosurface {
>   max_gradient 2.1
>   accuracy .0001
>   interior {
>     ior 1.400
>   photons{
>     target
>     refraction on
>     reflection on
> Mike Williams
Yeah, This got rid of the middle layer, but mine also has the added weird
specular effect. I do not think this is real because I did not see it when I
did my way original way, just this way.
-Mike
Date: 11 Oct 2008 22:45:00
Message: <web.48f1637ec4ddaaee85de7b680@news.povray.org>
This looks like a coincident surface problem.  Usually this shows up as
speckles, but in your case it appears to have obliterated both surfaces.
The quick solution would have been to change the 3.2 to 3.4999 so that the
overlap area is only 0.0001--but that didn't eliminate the problem for me; it
only made it thinner.
But I like Mike Williams's solution better anyway.  The cast spots seem to be
from the egg-carton topology, although I can't think of why that would be.  But
once you turn on photons, they'll refract into a spotted pattern anyway, so I
wouldn't worry about them.
Date: 13 Oct 2008 13:40:01
Message: <web.48f3876ac4ddaaeec9b9f9f00@news.povray.org>
Actually, I just tried it with photons on and it did not get rid of the
speckles.  Also, I do not think the speckles are from the egg crate pattern
since the frequency is too small and since this program does not seem to take
into account interference of waves, I don't think it would be possible to have
such a small frequency developing.  The reason I am being such a stickler with
this is that I plan on using this for visualizing an experiment and we would at
least try to minimize artifacts as much as possible.
-Mike
Date: 13 Oct 2008 19:05:47
Message: <48f3d44b$1@news.povray.org>
Mike nous illumina en ce 2008-10-13 13:37 -->
> -Mike
What can explain the speckling is multiple total internal reflections. At one
pixel, you may have only a few, but the next pixel may need a max_trace_level
near the maximum of 255.
Have you tried increasing adc_bailout? It limit the number on reflection and
refractions based on the effective contribution to the colour returned by a ray.
In some cases, it won't change a thing, in others, it can greatly help, and in
still other, it may not be acceptable. Only experimentation can tell you if it's
acceptable in a specific case.
In some cases, adding "all_intersections" can help.
   My wife is such a bad cook, in my house we pray after the meal.
   	Rodney Dangerfield
Date: 14 Oct 2008 16:10:01
Message: <web.48f4fb76c4ddaaeec9b9f9f00@news.povray.org>
> > -Mike
> Alain
>     Rodney Dangerfield
So, I tried both adding all_intersections, playing with adc_bailout (seems like
I should make it smaller to decrease the error it permits before "giving up"),
and I played with the max_trace. All of this did not fix it.  Actually, I
looked online and found someone who might have fixed the problem.
http://www.triplespark.net/render/povray/patches/isoacc-patch/
They edit isosurf.cpp.  I am not sure how to do this, I am using MegaPov on an
intel mac.
-Mike
Date: 15 Oct 2008 13:00:00
Message: <web.48f6207dc4ddaaeec9b9f9f00@news.povray.org>
> > > -Mike
> > Alain
> >     Rodney Dangerfield
> intel mac.
> -Mike
I tried the patch and it does not seem to do much else besides speeding up the
processing time (It uses a better root finding algorithm).  Actually, I notice
that if I lower the refractive index of my material the black dots go away, so
it definitely is a total internal reflection thing.  Also, it seems that by
turning off adc_bailout (seting equal to 0 ) and messing with the
max_trace_level I can make less black dots appear.  However, I have yet to be
able to make max_trace_level equal to 255 with adc_bailout off because it takes
too long to render.  Maybe I do not fully understand how adc_bailout works, it
seems if I make it really small I get no change from if I have it not there at
all (the default value).  Any ideas.
-Mike
Date: 15 Oct 2008 15:35:00
Message: <web.48f64533c4ddaaee81c811d20@news.povray.org>
For what you are doing a heightfield would be far better suited and much easier
to work with.  See below.  You'll need to work with the values to get what you
want for scalings and translations.  The RES parameter adjusts the resolution
used for the heightfield.
Some things to note:
-HFs are created on the X/Z plane from <0,0> to <1,1>
-HFs read the function on the X/Y plane at Z=0  (ie, HF read from XY plane but
create on XZ plane - perpedicular)
-HF height is in the Y axis and ranges from 0 to 1, but actually acts like a
plane, ie, it is infinite below the surface (doesn't stop at 0)
This object should render far faster than an isosurface without errors or holes.
Higher values for RES will give more accurate results but will increase parse
time, however they shouldn't significantly affect render time.
Hope some of this helps.
-tgq
//START
#declare f_1= function (x,y){( 0.9-0.1*sin(3*6.2832*x)*sin(3*6.2832*y))}
#declare RES=100; //hf resolution
#local HF1=
  height_field{
    function RES,RES {pattern{ function {
      f_1 (x*1.9,y*1.9)
  smooth
  translate <-1/2,-1/2,-1/2>
  scale <2.01,2,2.01> //scale the HF slightly larger in X/Z directions to be
removed
intersection{
  object{HF1 pigment {rgb 1}}  //Top HF
  object{HF1 rotate 180*z pigment {rgb 1}}  //Bottom HF
  box{-1,1 pigment {rgb 1}}  //Cube to trim sides
  scale <1.9,1,1.9>
//END
Date: 16 Oct 2008 15:15:00
Message: <web.48f791c6c4ddaaeec9b9f9f00@news.povray.org>
> -tgq
> //START
> #local HF1=
>   height_field{
>       f_1 (x*1.9,y*1.9)
>   smooth
> removed
> intersection{
>   scale <1.9,1,1.9>
> //END
Thanks for the advice, this works much better.  However, when I switch the
material to the same as that I have been using (translucent, ior =1.5) I still
get black dots however not as much.  Actually, I have noticed that I can nearly
get rid of them by turning off adc_bailout (setting it equal to zero) and
increasing the max_trace_level.  I am having trouble going anywhere above
around 50 for the max_trace_level with the adc_bailout off (it takes forever to
render).  I would really like it if someone could explain the adc_bailout to me
a bit better than what is given in the documentation.  Is there a lower limit?
I think what I would actually want to do is make adc_bailout really small as to
retain the affect of max_trace_level, but I am not seeing this.  It seems with
adc_bailout on, no matter what the value (when made smaller than the default
because larger only makes things worse) a change in max_trace_level does
nothing.
Here is the updated piece of code you gave me that I have been running:
material {
 finish {
        ambient 0.0
        diffuse 0.0
         reflection {
          0.0, 1.0
          fresnel on
        conserve_energy
        specular 0.0
        roughness 0.0
#declare RES=6000; //hf resolution
#local HF1=
  height_field{
      f_1 (x*1.9,y*1.9)
  smooth
removed
#declare Mixingregion3=
intersection{
  object{HF1 material { MixedRegion } interior {ior 1.5} }  //Top HF
  object{HF1 rotate 180*z material { MixedRegion } interior {ior 1.5}}  //Bottom
HF
  box{-1,1 material { MixedRegion } interior {ior 1.5}}  //Cube to trim sides
  scale <1.9,1,1.9>
  translate 4*y
  //material { MixedRegion }
  //interior {ior 1.5}
object{Mixingregion3}
-Mike
