POV-Ray : Newsgroups : povray.newusers : Artifacts on lathe object Server Time
16 Aug 2025 11:56:08 EDT (-0400)
  Artifacts on lathe object (Message 1 to 10 of 10)
Subject: Artifacts on lathe object
Date: 17 Jul 2008 00:35:00
Message: <web.487ec9449eb880d26e62e6f60@news.povray.org>
A long time ago, when I first started playing with POVRay, it was quite the
trend to have a short POV script for a signature. No one does that anymore it
seems, but I always wanted to try it, so I did! Except the lathe object in the
script appears with artifacts...
I've tried antialiasing, raising the max_trace_level, and adding the sturm
keyword, but none worked. I am using version 3.6.1c.
camera{location y*10 look_at 0}
light_source{<1,30,1>rgb 1}
difference{
  lathe{
    bezier_spline
    4,
    <0,-2>,<2.5,-1.95>,<1,2>,<0,3>
    rotate x*90
    texture{
      pigment{
        bozo scale .25
        color_map{
          [.2 rgb 1.5]
          [1.0 rgbt<1.6,1.5,1.5,.3>]
      finish{
        specular 1
        roughness .0005
        reflection .85
        irid{.25 thickness .25 turbulence 0.5}
  prism{
    linear_sweep
    linear_spline
    0,6,28,
    <-.05,-.33>,<-.38,.66>,<-.71,-.33>,<-.61,-.33>,<-.51,0>,
    <-.25,0>,<-.15,-.33>,<-.05,-.33>,<-.46,.1>,<-.38,.46>,
    <-.31,.1>,<-.46,.1>,<.05,-.33>,<.05,.66>,<.46,.66>,
    <.66,.46>,<.66,.26>,<.46,.06>,<.15,.06>,<.15,-.33>,
    <.05,-.33>,<.15,.56>,<.41,.56>,<.56,.41>,<.56,.31>,
    <0.41,.16>,<.15,.16>,<.15,.56>
    texture{
      pigment{rgb<.6,.4,.1>}
      finish{ambient .15 brilliance 5 metallic specular .8 roughness .01
reflection .65}
(Sorry about the lousy formatting...signatures were crammed to make them as
short as possible. I tried to break it up so it is mostly readable :-) )
Thanks in advance!
~Angela Perry
Subject: Re: Artifacts on lathe object
Date: 17 Jul 2008 07:57:27
Message: <2tcu7492sm1ojn2p6d7evlpsl48atha4hl@4ax.com>
Have you tried the sturm keyword? I've found that if I don't use it I get
artefacts when the object intersects the horizon.
Regards
Date: 17 Jul 2008 09:24:42
Message: <487f481a@news.povray.org>
Stephen napsal(a):
reread the post you quote. You can see she did have tried.
Date: 17 Jul 2008 11:24:11
Message: <lvou74hujdmijg2qfji9qlbimmlufpvf51@4ax.com>
On Thu, 17 Jul 2008 15:26:05 +0200, Jan Dvorak <jan### [at] centrumcz> wrote:
>Stephen napsal(a):
I shouldn't do these thinks quickly at work :(
Regards
Date: 17 Jul 2008 11:35:01
Message: <web.487f65ae64250a2e64eed08a0@news.povray.org>
That gives me an idea though! Maybe I'll try translating it away from the
origin, just to see if it is the horizon :-) For the location of the artifacts,
that makes sense.
I'm at work too (darn it) so I'll try it when I get home.
~Angela Perry
> >Stephen napsal(a):
> Regards
>      Stephen
Date: 17 Jul 2008 15:10:00
Message: <web.487f980364250a2e210497120@news.povray.org>
Offhand, it looks like the artifacts are from self-shadowing.  After trying the
usual tricks (translating or rotating by a very small amount, etc), I tried
using no_shadow, and the upper ones disappeared.  Unfortunately, this visibly
changes the image without removing some of the lower artifacts.  I am starting
to suspect a bug.
In any case, another work around that reduces (but does not entirely remove) the
artifacts is multiplying the light_source location vector by a higher number.
Code:
light_source{<1,30,1>*100 rgb 1}
With all else the same, the upper, darker artifacts do go away.
     HTH,
  -Reactor
Date: 17 Jul 2008 19:47:18
Message: <487fda06@news.povray.org>
"Angela" <ang### [at] yahoocom> wrote in message
news:web.487f65ae64250a2e64eed08a0@news.povray.org...
> artifacts,
> that makes sense.
I've had similar problems in the past when the change of direction between
two points is too big. Although it may be possible to find a position where
the artifacts are not very apparent, that's a bit fiddly.
I think you'll find it's a more robust solution to simply add a midpoint,
reducing the change of direction between each set of points. For example:
camera{location -z*10 look_at 0}
light_source{<1,1,-30> rgb 1}
lathe{
  bezier_spline
  8,
  <0,-2>,<1.5,-1.985>,<1.49,-0.5>,<1.24,0.5>
  <1.24,0.5>,<0.99,1.5>,<0.5,2.5>,<0,3>
  pigment{rgb <1,1,1>}
Warning: I've flipped the axes in this example to the default ones which I'm
more accustomed to and which avoid having to rotate the lathe object.
Chris B.
Date: 17 Jul 2008 22:05:01
Message: <web.487ff92e64250a2e802286fd0@news.povray.org>
That fixed it Chris, thank you! And thanks everyone else for all the help and
suggestions :-)
~Angela Perry
Date: 17 Jul 2008 23:40:33
Message: <48802D91.50900@joplin.com>
I ran your eample also version 3.6.1c and don't get any Artifacts.
I used antialise:
+A0.1 +AM2 -J.25 +R3
and tested at two sizes 400*400 and 800*800
No problems anywhere!
Date: 18 Jul 2008 07:44:14
Message: <ld0184pp38f52emu0t7h3uh1j1693b32o2@4ax.com>
>suggestions :-)
I'm pleased that you got a solution. I found that when I rotated the lath by 5
degrees the artefacts were not visible.
Regards
