POV-Ray : Newsgroups : povray.newusers : Rendering Window Server Time
8 Apr 2026 05:59:22 EDT (-0400)
  Rendering Window (Message 1 to 10 of 12)
Subject: Rendering Window
Date: 17 Feb 2008 03:05:00
Message: <web.47b7e9a9dc027f8bb61821680@news.povray.org>
Hi! I know this is the dumbest question, any one has ever asked but I am kinda
puzzled with this.This being the forum for new user I thought this the place to
seek help.
I am not able to change the size rendering window,I mean the output image window
is very small in my case and I want to render my scene file to a larger
dimension.So, can you tell how to change that in windows executable POV-ray. :(
Subject: Re: Rendering Window
Date: 17 Feb 2008 03:36:20
Message: <47b7f204$1@news.povray.org>
"here_I_am" <nomail@nomail> schreef in bericht
news:web.47b7e9a9dc027f8bb61821680@news.povray.org...
> kinda
> place to
> seek help.
> window
> POV-ray. :(
As you know, there are no stupid questions... :-)
There are several ways to do what you ask:
1) you can select pre-defined render sizes from the drop-down combobox on
the upper left of your screen, the one showing (for instance "[640 x 640, AA
0.3]"
2) you can edit the content of this combobox by opening the file "Edit
resolution INI files" under the Tools menu
3) you can define your own resolution in the command line window, for
instance: +w1000 +h800
4) you can also write your own ini file in which those parameters are
included
Before all else, the documentation can help you with details on this. See
the introduction chapter of the help.
Date: 17 Feb 2008 03:36:35
Message: <47b7f213$1@news.povray.org>
"here_I_am" <nomail@nomail> wrote in message
> window
Upper left corner of the program window there should be a resolution
drop-down selection there.
You can also change output resolutions by adding -wN -hN (N is integer
number, also +w +h works), for the width and height dimensions needed, to
the command field box immediately to the right of that (unless you moved
it).
If those are larger than the display you're using the render window will
have scroll bars, unless you maximize it in which case it'll conform to the
display (shrink it down to fit).
/*bob hughes*/
Date: 17 Feb 2008 03:46:14
Message: <47b7f456@news.povray.org>
"Thomas de Groot" <t.d### [at] internlDOTnet> wrote in message
news:47b7f204$1@news.povray.org...
Hey Thomas! It was a little bit dumb... ;^) Only joking!
I skipped saying that Tools menu resolution.ini edit so maybe we both
answered completely enough. Was wondering if the toolbar was showing
properly if it didn't look obvious to change it already.
/*bob hughes*/
Date: 17 Feb 2008 04:20:00
Message: <web.47b7fbae3a59d637b61821680@news.povray.org>
> /*bob hughes*/
It worked with command line option:)
But as Thomas mentioned earlier:
"you can select pre-defined render sizes from the drop-down combobox on
0.3]" "
there is no predefined default option there in combobox.In fact there is a file
called quickres.ini but it never shows up there in the drop-down combobox.
So, is there any setting or something to add that those option there in
combobox.
(Just for info: In my case combobox has only one option called More Resolution
and when ever I choose that one..that brings help menu for ...on how to add
more resolution)
Date: 17 Feb 2008 07:56:55
Message: <47b82f17$1@news.povray.org>
news:web.47b7fbae3a59d637b61821680@news.povray.org...
> AA
> 0.3]" "
> file
> combobox.
> Resolution
> add
> more resolution)
Hmm... I thought POV-Ray always came with a filled quickres.ini file. If you
have a quickres.ini file somewhere, just open it in the editor to see what
is inside. It should be in the "renderer" folder of POV-Ray.
Maybe I overlooked something there. Just in case, I attach my own version of
quickres.ini. Just drop it into the "renderer" folder of POV-Ray. The
combobx should then contain a list of resolutions. I suppose that you can go
on from there.
Download 'quickres.ini.txt' (6 KB)
Date: 17 Feb 2008 08:25:00
Message: <web.47b8350b3a59d637b61821680@news.povray.org>
> > AA
> > 0.3]" "
> > file
> > combobox.
> > Resolution
> > add
> > more resolution)
> on from there.
> Thomas
No, this was not I meant earlier.Actually I have the very same file with the
data available but that doesn't shows up in the combobox.....Do i have to
configure it's path or something.
Date: 17 Feb 2008 08:39:59
Message: <g8egr3pv0le1m2e1rpjtp3m5hdkoktesb5@4ax.com>
Check in PVENGINE.INI that there is an entry in
[General] that has an entry like
SecondaryINIFile=C:\GRAPHICS\POV-RAY FOR WINDOWS V3.5\renderer\quickres.ini
SecondaryINISection=[800x600, AA 0.3]
Access to PVENGINE.INI can be found in the Tolls menu
Regards
Date: 17 Feb 2008 08:41:16
Message: <hbegr3tb2a94pvv32ga2hn24voti7ja5bo@4ax.com>
What is wrong with my fingers today? Tools menu
Regards
Date: 17 Feb 2008 11:06:43
Message: <47b85b93$1@news.povray.org>
"Stephen" <mcavoysATaolDOTcom@> schreef in bericht
news:hbegr3tb2a94pvv32ga2hn24voti7ja5bo@4ax.com...
better than Trolls menu.... :-)
