POV-Ray : Newsgroups : povray.newusers : unexpected scale results Server Time
19 Nov 2025 07:05:56 EST (-0500)
  unexpected scale results (Message 1 to 9 of 9)
Subject: unexpected scale results
Date: 7 Dec 2007 20:10:00
Message: <web.4759ee8a2b8d7db3e4c81d9c0@news.povray.org>
// This exercise is from the 2.2.7.1  Transformations, scale and translate
section of
// the PovRay tutorial,
// but it seems to have returned unexpected results
// can you render this? thanks
    camera
       location <16, 32, -20.0>
       look_at  <8, 8,  0.0>
    plane
       y, -1.0
       checker color Gray65 color Gray30
light_source { <5, 10, 0> color White }
light_source { <-5, 10, 10> color White }
    sphere { < 2, 2, 2 >,1  // draws sphere at this location
      pigment { Blue }
      scale <4,3,.5>       // squishes and strectches according to scale
    sphere { < 0, 3, 0 >,1  // draws sphere at this location
      pigment { Green }
      scale 2               // doubles the diameter of sphere
    sphere { <10, 10, 10>,1 // draws sphere at this location for reference point
      pigment { Orange }
    //// Please explain why these spheres where translated to a new location
after being scaled, thanks
    sphere { <12, 10, 10>,1 // draws sphere at this location, should be next to
Orange
      pigment { Yellow }
      scale < 3,2,4 >      // squishes and strectches according to scale, but
where did it go??
      // comment this scale out, to see Yellow sphere
      pigment { Red }
      translate 4*x         // draws sphere at <14,10,10>, should be next to
Yellow next to Orange
      scale <2,.4,.5>       // squishes and strectches according to scale, but
where did it go??
      // comment this scale out, to see Red sphere
Subject: Re: unexpected scale results
Date: 7 Dec 2007 20:33:00
Message: <4759f44c@news.povray.org>
  Suppose you have this:
object { MyObject scale 2 }
  What do you expect happens to that object? It should be uniformly scaled
twice its size, no? The resulting object should look exactly the same as
the original one, just twice as large, no?
  Well, assume that MyObject is defined as follows:
#declare MyObject =
  union
  { sphere { <0, 0, 0>, 1 }
    sphere { <2, 0, 0>, 1 }
  This is the union of two spheres which touch each other at a point
(more precisely, at <1, 0, 0>). After this object is instantiated and
scaled above, the result should still be a union of sphere which touch
at a point. A uniform scale should not and does not change this.
  In order for this to happen at least one of the spheres must change
position besides being scaled larger, so that the end result is two
spheres twice as large as the originals, which touch at one point.
  Since the object is scaled with respect to the origin, the first sphere
will not move, but the second sphere will move to <4, 0, 0>, and of course
their radiuses will double. (And thus the new point where they touch is
<2, 0, 0>.) The end result is an object which looks identical to the
original object, just twice as large.
  Well, what happens if instead of that we declare MyObject as:
#declare MyObject =
  sphere { <2, 0, 0>, 1 };
  Now it's the same object, except that the first sphere has been removed.
  What happens if we instantiate this object and scale it twice as large,
as above? Should the behavior of this sphere change in some way simply
because now it's alone and not in a union with another sphere?
  No. Objects are always scaled with respect to the origin. This lone
sphere will still be scaled in the same way regardless of whether it's
in a union with another sphere or not. The transformation is independent
of this. The end result is still a sphere centered at <4, 0, 0> (and
with radius 2).
  The point is, transformations don't know nor care about what is the
"center" of the object. Many object do not have a "center". The "center"
of the object is always the origin, nothing else, and all transformations
are done with respect to that.
Date: 7 Dec 2007 22:10:00
Message: <web.475a0af3b93ae2ada71cf50d0@news.povray.org>
BTW, works the same in Blender and possibly other modellers as well.
Date: 8 Dec 2007 00:41:49
Message: <475a2e9d$1@news.povray.org>
jofg nous apporta ses lumieres en ce 2007/12/07 20:08:
> section of
> Orange
>       pigment { Yellow }
> where did it go??
This sphere is now centered at <12*3, 10*2, 10*4> or <36, 20, 40>
>       pigment { Red }
This sphere is now at <14,10,10>
> where did it go??
It's location is now <28, 0.4, 0.5>
When you want to scale or rotate an object, it's always beter to define it at
the origin (around <0,0,0>), scale oan/or rotate it, THEN translate to where you
want it to apears.
All scalings and rotations are ALWAYS performed relative to the origin of the
coordinate system. So, the location of any object NOT at the origin will also
change. Scaling will move the object on a line passing by the origin. Rotations
will make the object orbit the coresponding axis.
You know you've been raytracing too long when you keep a blacklist of people who
ask questions about 3DFX products.
Alex McLeod a.k.a. Giant Robot Messiah
Date: 11 Dec 2007 04:57:35
Message: <475e5f0f$1@news.povray.org>
Not used Blender that much, but in other modellers you define an "object
centre" point, and all transformations apply relative to that point.  So if
you have a complex scene with an object (or group) you can rotate/scale
about the object centre rather than the whole scene centre...
Date: 11 Dec 2007 08:27:00
Message: <475e9023@news.povray.org>
  How do you select whether you want to apply a transformation to a group
of objects as if it was a single object with a common center point, or
whether you want the transformation to be applied to each object individually,
independently of the other objects?
  Anyways, it's quite trivial to apply a transformation to an object in
POV-Ray in relation to a defined local center point:
#declare MyObject = ...;
#declare MyObjectCenter = <centerX, centerY, centerZ>;
object
{ MyObject
  translate -MyObjectCenter
  // add local transforms here
  translate MyObjectCenter
Date: 11 Dec 2007 09:45:33
Message: <475ea28d$1@news.povray.org>
> individually,
You either apply the transformation to the group, or to all the items in the
group (usually an ungroup command will leave all the objects selected in the
group, so you can apply the transformation and then re-group).  Each
"object", whether it is a primitive or a group, has a centre point (that you
can actually modify if you want), all transformations on an object are
relative to the object's centre point.
Yes, but if you've built a union of several objects, and then decide that
actually you want each one to be rotated by a certain amount, or scaled by a
certain amount, but to keep its position, it's quite hard work as you have
to manually add the transformations to every single object in the union.
All I was saying is that there are more efficient ways to do that sort of
thing in other software.
Date: 11 Dec 2007 12:20:01
Message: <web.475ec65db93ae2ad773c9a3e0@news.povray.org>
yes, you can do that in Blender as well.  Except it's a pain in the ass
positioning the cursor or reaching for "New center" in the menu.  I actually do
it the way I do it in pov:  create at center, do transforms and position them
later.  much faster...
Date: 11 Dec 2007 19:14:41
Message: <475f27f1@news.povray.org>
Hash: SHA1
Hell, if that's too hard, there's macros in transforms.inc that do it
all for you.
William Tracy
You know you've been raytracing too long when you seriously entertain
thoughts about learning C so you can improve POV-Ray without waiting for
the POV Team to do it.
    -- Taps a.k.a. Tapio Vocadlo
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFHXyfwKrVIcTMekC8RAoccAJ9N+xlJYn0CYObPuw5FVMFE5GuB9wCguX4d
6VtGNGNzeoXZUwLhgOiegxY=
=VZA8
-----END PGP SIGNATURE-----
