POV-Ray : Newsgroups : povray.newusers : Question about radiosity Server Time
14 Mar 2026 03:40:12 EDT (-0400)
  Question about radiosity (Message 1 to 4 of 4)
Subject: Question about radiosity
Date: 26 Jun 2007 21:10:02
Message: <web.4681b84e6bc85a0bb56da8d00@news.povray.org>
I've never used radiosity or hdri lighting so that should give some context
to this current inquiry, and i thank you in advance.
For radiosity to really have an effect on realism in a scene it should be
used when there is more than one object right?  I mean lets say i was
rendering a "portrait" of say some geometric object adding radiosity would
nt have any effect right, except for really long render times.  IN this
case to increase the realism of the object/scene i need to use HDR right.
I know it really depends, but the question stands.
Subject: Re: Question about radiosity
Date: 26 Jun 2007 22:29:44
Message: <4681cb98$1@news.povray.org>
Why don't you test it? I always keep a special POV file called
"tester.pov" for these types of things.
To answer your question (I hope): The effects of radiosity can be seen
without the use of HDR or an HDR light probe. Also, you can use HDR
without radiosity. HDR backgrounds can affect a scene either by
reflecting off of reflective surfaces, showing through transparent
surfaces, or through indirect illumination (radiosity).
If you have a white background (not a light probe, just a background
statment set to rgb<1,1,1>), it will illuminate the scene if radiosity
is included in the global_settings block. If you add a light, then you
will see it bounce multiple times depending on the radiosity's
recursion_limit.
In short, you don't need to use HDR in order to use radiosity. Radiosity
alone will increase the realism of your scene.
~Sam
Date: 26 Jun 2007 22:35:01
Message: <web.4681cc4ff97fc515b56da8d00@news.povray.org>
> recursion_limit.
> ~Sam
Thanks Sam i am doing that now.  I have my simple scene with radiosity image
saved and now I am doing it with out to see if I can discern any difference.
Date: 27 Jun 2007 17:54:20
Message: <4682dc8c$1@news.povray.org>
clarkking nous apporta ses lumieres en ce 2007/06/26 22:32:
>> recursion_limit.
>> ~Sam
A little trick: Place the radiosity block in an #if(frame_number =2)...#end
statement and do a 2 frames animation by adding +kff2 on the command line. This
will give you 2 files named test1 and test2, or whatever name you have used,
that you can quickly compare.
Light travels faster than sound. That is why some people appear bright until you
hear them speak.
