POV-Ray : Newsgroups : povray.newusers : refraction with multiple transparent objects behind eachother Server Time
18 Mar 2026 06:13:46 EDT (-0400)
  refraction with multiple transparent objects behind eachother (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: refraction with multiple transparent objects behind eachother
Date: 18 Apr 2007 01:45:01
Message: <web.4625afefe12fc74b694f24b00@news.povray.org>
> Are your meshes forming closed shapes? If a mesh forms a shaped surface without
> any back, any ray entering it get refracted and is considered traveling inside
> something with an ior of 1.2. Now, it encounter the second mesh, also having an
> ior of 1.2. So, the ior before and after the surface is the same resulting in no
> further refraction.
The meshes are not closed. Basically I started with a .OBJ file of the
Stanford Bunny. I then wrote a program that would remove the back of the
bunny, leaving me with only its front.
How could I fix this? Is there any command that allows me to work around
this?
Date: 18 Apr 2007 03:55:07
Message: <4625cedb@news.povray.org>
Tim Attwood <tim### [at] comcastnet> wrote:
> Probably should have inside_vector in the meshes just to be safe, as well.
  "Just to be safe"? Why?
  I think it's better to understand what "inside_vector" does instead of
just spreading it around "just to be safe".
Date: 18 Apr 2007 03:56:40
Message: <4625cf38@news.povray.org>
  Given that the mesh is transparent how could you expect it to work
correctly if parts of the surface have been removed?
> this?
  How do you expect POV-Ray to create a part of the mesh which isn't there?
Date: 18 Apr 2007 17:57:21
Message: <46269441$1@news.povray.org>
Shai nous apporta ses lumieres en ce 18-04-2007 01:43:
>> further refraction.
It would be beter to use the whole original .OBJ converted into a mesh.
You wrote a programm to remove the back, what a waste of your time :-(
Maybe you can alter it to replace the back with a flat face rather than just
removing part of the object.
> this?
Only "fix" that I can think of is not removing the back, or replacing with some
flat face. That can't be done by POV-Ray, as your choped object is missing some
parts.
'I never met a piece of chocolate I didn't like.'
Date: 19 Apr 2007 00:01:58
Message: <4626e9b6$1@news.povray.org>
I guess I wasn't being entirely clear...
The type of effect he's going for probably will end up requiring CSG,
and then he'll need inside_vector.  Inside_vector lets POV know where
the inside of a mesh is.
If you have two surfaces, a front and a rear, and you wish for refraction
to happen on them, one solution is for both of those surfaces to be
part of the same closed object assembled with CSG.
Date: 19 Apr 2007 16:50:02
Message: <web.4627d597e12fc74b694f24b00@news.povray.org>
I only want the ray to refract when it enters the object. The ray should not
be refracted again when it leaves the object through the back side. I didn't
know how to get this effect in POVray, so I thought it would be best if I
just removed the back of the object myself.
Date: 19 Apr 2007 19:07:11
Message: <4627f61f@news.povray.org>
Shai nous apporta ses lumieres en ce 19-04-2007 16:48:
>>                                                           - Warp
OK, but that is completely unrealistic and contrary to comon sence.
I abhor war and view it as the greatest scourge of mankind.
Thomas Jefferson
Date: 20 Apr 2007 03:26:45
Message: <46286b35@news.povray.org>
  So POV-Ray is thus behaving exactly like you wanted. What is, then, your
problem?
Date: 20 Apr 2007 07:05:02
Message: <web.46289d87e12fc74b694f24b00@news.povray.org>
> >>                                                           - Warp
> Alain
> Thomas Jefferson
I know, but I'm not going for realism here :)
Nevertheless, is there any way to achieve this effect without me having to
remove the back of the object?
Date: 20 Apr 2007 08:32:34
Message: <4628b2e2$1@news.povray.org>
Shai nous apporta ses lumieres en ce 20-04-2007 07:01:
>>>>                                                           - Warp
>> Alain
>> Thomas Jefferson
You can replace it with a flat surface. There will be a refraction, but it will
be uniform. It may be the best compromise available to you.
For that, you can rework your removal tool into a replacing one, or you can
difference the mesh with a plane. For that last one, the mesh must be completely
closed and every faces must be correctly oriented, the inside vectors all toward
the actual inside of the mesh.
Commercialism: Let's package this shit.
