POV-Ray : Newsgroups : povray.newusers : Surface normal in pigment user-function Server Time
14 Mar 2026 05:23:36 EDT (-0400)
  Surface normal in pigment user-function (Message 1 to 8 of 8)
Subject: Surface normal in pigment user-function
Date: 13 Mar 2007 20:05:02
Message: <web.45f74903fde32694bb706900@news.povray.org>
I know you can create a pigment user function that accepts x,y,z,u,v as the
geometric and texture coordinates of the point being evaluated.  My
question is, are there constants that can be set to automatically accept the
normal of the point being evaluated?
I know that I could use the trace method to retrieve it, and if there is no
other way, I'll do that, but it seems redundant.  Likely, when evaluating
the function, trace or some method like it, has been called prior and
calling trace would just duplicate the effort and take longer.
Subject: Re: Surface normal in pigment user-function
Date: 13 Mar 2007 21:05:01
Message: <web.45f757b54f1e00c84bb706900@news.povray.org>
To complicate matters for the trace method, I don't seem to be able to
convert the x, y, z parameters into a vector to pass to trace. :(  Any
ideas?
Date: 13 Mar 2007 21:30:29
Message: <45f75e45$1@news.povray.org>
"avariant" <nomail@nomail> wrote in message
news:web.45f74903fde32694bb706900@news.povray.org...
> the
> no
If you just want a pigment based on the surface normal, have a look at the
'slope' pattern type.  For something more complicated, you can look at
layering it perhaps.
-tgq
Date: 13 Mar 2007 22:40:01
Message: <web.45f76e764f1e00c84bb706900@news.povray.org>
Ah CRAP!!!  I feel stupid.  I never even saw that pattern.  That's exactly
what I need.  Thanks Trevor!!
Date: 14 Mar 2007 07:45:01
Message: <web.45f7eddc4f1e00c8c150d4c10@news.povray.org>
No problem.  Just be sure to read carefully, it can be difficult to
understand exactly how the parameters work at first.
-tgq
Date: 6 Apr 2007 11:00:02
Message: <web.461660564f1e00c8fdebbbce0@news.povray.org>
Turns out that's not exactly what I need after all...  It's a good solution
and for small, relatively uniform objects it's probably sufficient.  The
problem is that the slope pattern takes a single vector, which can be a
vector from the camera position to the object's center.  But I want to
evaluate the angle between the camera vector and the normal of EACH surface
point which means, based on the point, the vector from the camera is always
changing.
Like I said when I started this post, I know trace would work, but as I've
learned more about POV-Ray, it seems that there isn't a way to include it
in a pigment function because functions don't support vectors.
So, are there any thoughts on how this could be done?  Like I said, slope
pattern can work, but wouldn't be entirely correct for large or complicated
objects.
Date: 6 Apr 2007 11:43:42
Message: <46166aae$1@news.povray.org>
> changing.
I think the "aoi" pattern in MegaPOV would be just what you need.
It is similar to slope, except that instead of a fixed direction
vector, either a reference point or the direction of the incoming
rendering ray is used.
Date: 6 Apr 2007 17:10:00
Message: <web.4616b6924f1e00c8fdebbbce0@news.povray.org>
Ok, thanks.  I haven't looked at MegaPOV yet.  I actually went ahead and
modified the source directly to add a reference point tag to the slope
pattern, but it looks like megapov has a lot of other cool things.  I'll
check it out.
> > changing.
