POV-Ray : Newsgroups : povray.newusers : height_field problems (crashing POV) Server Time
18 Aug 2025 00:07:52 EDT (-0400)
  height_field problems (crashing POV) (Message 1 to 9 of 9)
Subject: height_field problems (crashing POV)
Date: 9 Oct 2006 01:55:00
Message: <web.4529e3464445cd55cde7f9360@news.povray.org>
It's been a long time since I've done much POV (like since I put POVAFX32
together back in the day), but I've downloaded the latest & I'm messing
with some stuff now.  Bad news is I keep getting bad crashes while trying
to run POV on my computer.  I'm trying to do some animation work (play)
with height fields.  POV will intermittently crash while tracing the pov
file included below.  I've tried adjusting resolution, changing the
tga/gif/jpg height file, and several other things with no luck.  Sometimes
it'll make it all the way through the animation rendering & sometimes it
doesn't.
I'm running POV-Ray 3.6 for Windows (32 bit) on my AMD Athlon64 3200+
machine with 1GB RAM & plenty hard drive space.  Physical memory available
during the renderings seems ok.  I ran memtest on my RAM & it checks ok.
I've tried uninstalling & reinstalling with no luck.  I can run POV for
hours on other files without any issues.
The animation options for rendering test.pov are: +KI0 +KF140 +KFI0 +KFF20
If you don't use these, the object starts off the rendered portion, so
you'd have to put in a value for "clock" in the pov file.  It's crashed
with & without rendering multiple frames.
The crashes are not always the same.  Sometimes POV reports an unhandled
exception in it's own window & recommends closing the program.  Sometimes
the computer hangs.  Sometimes the computer shuts completely down & reboots
as if I just hit the reset button.  And twice I've gotten a blue screen of
death (BSOD).  The error on the BSOD was:  IRQL_NOT_LESS_OR_EQUAL.  Not
fun.
The files needed are here:
http://www.thedukes.org/pov/test.pov  (also included below)
http://www.thedukes.org/pov/patch5_border2.jpg
It's very weird.  Any ideas?
Thanks!
-Bryan
//------start pov file
//Patch test POV file by Bryan Duke bry### [at] thedukesorg
//+KI0 +KF140 +KFI0 +KFF20  <--command line options for animation
#include "textures.inc"
#include "metals.inc"
global_settings { assumed_gamma 2.2 }
   location  <0, 0, -5>
//   direction <0, 0, 1>
   look_at   <0, 0, 0>
light_source { <-15, 30, -25> color red 1 green 1 blue 1 }
light_source { < 15, 30, -25> color red 1 green 1 blue 1 }
background { colour SkyBlue }
//declare rotations for patch height maps
#if (clock>50)
   #declare rotate_x = clock+50;
   #declare rotate_y = 90-clock+50;
   #declare rotate_z = 90-clock+50;
#else
   #declare rotate_x = 0;
   #declare rotate_y = 90;
   #declare rotate_z = 90;
#declare Patch = union{
  height_field {
    jpeg "patch5_border2.jpg"
    water_level 0.1
    smooth
    pigment { color red .9 green .9 blue .9  }
    scale <2, .2, 2>
    rotate rotate_x*x
    rotate rotate_y*y
    rotate rotate_z*z
//    translate <-.50, 6, -.5>
    translate <-1*(clock/140), 1, -3.5+(clock/40)>
  Patch
//------end pov file
Subject: Re: height_field problems (crashing POV)
Date: 9 Oct 2006 11:46:10
Message: <452a6ec2@news.povray.org>
"bryan" <bry### [at] thedukesorg> wrote in message
news:web.4529e3464445cd55cde7f9360@news.povray.org...
     I ran your code with no problems on 3.6. Have you checked your virtual
memory? When I ran the code, I found mine set on 'No Paging File'.
      ~Steve~
> Thanks!
> -Bryan
Date: 9 Oct 2006 18:27:19
Message: <452accc7$1@news.povray.org>
I didn't have any problem with running this in 3.6 either...
I'm not sure about the final line "Patch", normally I'd use object{Patch}
for
#declared objects.
Date: 9 Oct 2006 23:30:01
Message: <web.452b12fd63ca0cddcde7f9360@news.povray.org>
Thanks for the help with this.  I checked my page file settings & memory
available during rendering & both seem fine (about 400MB free RAM during
rendering).  I changed the pov file last line to be object{Patch}.  Still,
no change in the behavior on my desktop PC.  I rendered an animation series
& 4 frames into it, my computer hung (nothing works...just plain locked up).
I installed POV-Ray 3.6 on my laptop & everything works perfectly with the
same pov & image files.  Grrrr.
So, I'm thinking maybe there's a corrupt file somewhere on my desktop.  I
tried uninstalling & reinstalling (again!), but no luck.  If I don't use a
height_field, my desktop POV runs normally.  Anyone have an idea of a dll
that might be getting called during height_field number crunching that I
can delete/reinstall manually?
Thanks,
-Bryan
Date: 10 Oct 2006 00:30:00
Message: <web.452b210263ca0cdd8968e2cd0@news.povray.org>
There is nothing wrong with POV-Ray, there is something wrong with your
computer. An application cannot make a properly working system crash. Most
likely your system has a cooling problem. While most programs will hardly
require any processing power, the prolonged running under full load, like
you do when rendering an animation, causes your system to overhead and then
results in random system failures. Get your system fixed, and POV-Ray will
run just fine. Repeated installing and unstinatlling POV-Ray or any other
software will not fix your hardware!
Date: 10 Oct 2006 02:59:07
Message: <452b44bb@news.povray.org>
web.452b210263ca0cdd8968e2cd0@news.povray.org...
then
I second that, maybe you could have a look at the CPU heat sink, it could be
full of dust and tar.
Or the fan doesn't work properly.
Marc
Date: 10 Oct 2006 23:35:00
Message: <web.452c664763ca0cddcde7f9360@news.povray.org>
I checked all that & cleaned about a little bit of stuff...still crashes.  I
run other stuff at 100% CPU load all the time (eg. seti@home) & never have
had any problems.  Maybe I'll try POV with less than 100% CPU allowed.
I've monitored CPU temps during the runs & they don't seem any different
with & without height fields (or between POV & any other high CPU use
program).
Anyway, it's something wrong with my computer (software or hardware).  For
now I'll stick with POV on my (slower) laptop.
Thanks!
Date: 11 Oct 2006 16:06:57
Message: <452d4ee1@news.povray.org>
It's a good idea to run something like
Ccleaner to fix registry stuff once in a while.
http://www.ccleaner.com/
You might want to try a memory diagnostic, it
may be hardware,
http://oca.microsoft.com/en/windiag.asp
but I'd suspect a driver, maybe run windows update.
or run sfc /scannow to check for corrupt system
files (if you have the windows CD).
http://www.updatexp.com/scannow-sfc.html
Date: 11 Oct 2006 16:55:00
Message: <web.452d58fa63ca0cddcde7f9360@news.povray.org>
Thanks Tim, I'll give that stuff a try!
-Bryan
