POV-Ray : Newsgroups : povray.newusers : Newbie question Server Time
20 Nov 2025 00:26:00 EST (-0500)
  Newbie question (Message 1 to 9 of 9)
Subject: Newbie question
Date: 23 Mar 2006 14:00:00
Message: <web.4422efb6b6b87aedee4c493c0@news.povray.org>
Recently i have started to use POV-Ray, after a lot of time using Anim8or.
Now, there is a feature in Anim8or that I don't know how to translate in
POV-Ray.
In anim8or, with a texture map applied to Emissive, you can simulate the
effect of lit windows. I sthere any way to do this is POV-Ray? I think that
it can done with layered textures, but I haven't figured out how yet.
Subject: Re: Newbie question
Date: 23 Mar 2006 14:21:47
Message: <4422f54b@news.povray.org>
that
I'm not sure if that's what you're after as I haven't used Anim8or myself,
but you might want to have a look at "ambient" in the finish-block. Setting
it to 1 will result in a texture which is completely lit, with or without
light (as long as ambient_light in the global_settings-block is set to the
default). Note that additional lights will brighten the texture even
further, so you might want to set "diffuse" to 0 (also in the finish-block)
to make the texture disregard lightsources.
Tim
aka "Tim Nikias v2.0"
Date: 23 Mar 2006 17:34:20
Message: <4423226c@news.povray.org>
Tim Nikias nous apporta ses lumieres en ce 23/03/2006 14:21:
> that
> Regards,
> Tim
If you do that and add radiosity{...} in the #global_settings{...} section, that
texture will
effectively emit light capable of lighting whatever is around.
Please read section 3.3.4 Radiosity in the documentations.
WARNING: The consumption of alcohol may leave you wondering what the hell happened to
your bra and
panties.
Date: 24 Mar 2006 05:30:01
Message: <web.4423c9cd8e4dc7a21f59794c0@news.povray.org>
> > that
> > Regards,
> > Tim
texture will
> Alain
to your bra and
> panties.
I haven't explained myself well. In Anim8or, with the procedure that I so
badly explained, you can simulate the effects of lit windows in a otherwise
normal surface. What I wanted to know is if there is a way to do that in
POV-Ray.
Antonio
Date: 24 Mar 2006 15:25:01
Message: <web.442454c68e4dc7a2ee4c493c0@news.povray.org>
I'll try to explain it better this time:
http://es.geocities.com/borg31de777/grab_1.JPG
This is how the object (a simple square) looks in the object editor of
Anim8or.
http://es.geocities.com/borg31de777/square_lt.JPG
This is the texture applied to emmisive.
http://es.geocities.com/borg31de777/render.jpg
And this is how the square looks after rendering.
Date: 24 Mar 2006 16:15:05
Message: <44246159@news.povray.org>
"A_C_C" <nomail@nomail> wrote in message
news:web.442454c68e4dc7a2ee4c493c0@news.povray.org...
> Anim8or.
Hi A,
Looking at these images, it seems to me that you probably want to use the
shapes of objects to define textures.
POV-Ray lets you do this with the 'object' pattern which is desribed in
section 3.5.11.23  'Object Pattern' of the documentation.
The following example uses a box to create a transparent rectangle in an
otherwise grey texture. This makes the first layer of the texture visible
through the 'hole' in the second layered texture. The first layer is a white
color with an ambient finish of 1, which makes it white even when it's in
shadow (e.g. even with the light_source commented out).
This texture can be applied to any object, in this case I've applied it to a
vertical plane.
You could simplify this down to a single layer texture if you don't need
independant control over the finishes of the two color components.
Hope this is illuminating.
Chris B.
camera {location <0,0,-8> look_at <0,0,0>}
//light_source {<0,3,-3> color rgb 1}
plane {z,0
    pigment {color rgb 1}
    finish {ambient 1}
      object {
        box {<-0.5,0,-1><0.5,2,1>}
        color rgb <0.5,0.5,0.5>
        color rgbt 1
Date: 25 Mar 2006 14:25:01
Message: <web.442598658e4dc7a2ee4c493c0@news.povray.org>
> Hi A,
> vertical plane.
> Regards,
> Chris B.
> plane {z,0
>   texture {
>     finish {ambient 1}
>   texture {
>     pigment {
>       object {
>         color rgbt 1
That is exactly what I wanted! Thanks for your help!
Antonio
Date: 26 Mar 2006 21:31:48
Message: <44274e94$1@news.povray.org>
> in section 3.5.11.23  'Object Pattern' of the documentation.
Or possibly 2.5.11.23.
Anton Sherwood, http://www.ogre.nu/
"How'd ya like to climb this high *without* no mountain?" --Porky Pine
Date: 27 Mar 2006 01:07:14
Message: <44278112$1@news.povray.org>
"Anton Sherwood" <bro### [at] poboxcom> wrote in message
news:44274e94$1@news.povray.org...
Indeed. I think I'll stop referring to section numbers in the help as they
differ considerably between versions (in 3.5 for Windows it's 6.7.11.23).
Chris B.
