POV-Ray : Newsgroups : povray.newusers : Dealing with colours Server Time
16 Jan 2026 21:46:48 EST (-0500)
  Dealing with colours (Message 1 to 7 of 7)
Subject: Dealing with colours
Date: 14 Mar 2006 17:20:00
Message: <web.44174154bedb9510f039f4f00@news.povray.org>
As much as I try, I find it so difficult to deal with RGB colors in a 0 to 1
scale. When it comes with dealing with colour maps (such as those used to
create a sky for example) my confusion is compounded.
For example, what does this
0.50 rgb <0.1, 0.2, 1>*0.9
mean? It is used within a color map statement, so I assume a portion of the
map will have that colour.
I have read the POV-Ray manual and I am no clearer. Are there tools out
there to help determine the RGB values? Perhaps there is something within
POV-Ray itself that I have overlooked?
Subject: Re: Dealing with colours
Date: 14 Mar 2006 17:31:22
Message: <4417443a@news.povray.org>
"ChaoZ" <nomail@nomail> wrote in message
news:web.44174154bedb9510f039f4f00@news.povray.org...
1
the
You are correct, the 0.50 does tell you that part of the map will have this
color.
If it's really the 0..1 scale that you don't like, you can use anything as
an upper bound really and then divide the vector by that number. <124, 255,
40>/255
But if visualizing what color this will make is the problem, you could use
something like the GIMP (http://www.gimp.org/) which has a color picker that
displays the RGB componants. There are other standalone tools as well.
Someone in these groups has developed a tool called POVColor that might be
usefull: http://www.sourceforge.net/projects/povcolor
-r
Date: 14 Mar 2006 21:15:00
Message: <web.441777ae2ff0c10f1c6902970@news.povray.org>
At the end of colors.inc (in the include folder in the POV-Ray main folder)
there are some macros that convert colors in different formats (HSB to RGB
etc.).
H
Date: 15 Mar 2006 03:23:13
Message: <77NdBCAc68FEFwG+@econym.demon.co.uk>
>scale.
Most 2d paint programs work with integer values for the colour
components, which range from 0 to 255. To convert values like that to
POV floating point components, divide by 256.
So if you find a colour you like in your favourite 2d paint program and
make a note of the RGB values. Then write something like
        rgb <23,46,230>/256
To interpret "rgb <0.1, 0.2, 1>*0.9" perform the specified
multiplication and then further multiply by 256 and round to an integer
"rgb <0.1, 0.2, 1>*0.9" = "rgb <0.09, 0.18, 0.9>" = RGB[23,46,230]
Mike Williams
Gentleman of Leisure
Date: 15 Mar 2006 07:40:00
Message: <web.44180a532ff0c10f1c6902970@news.povray.org>
A tiny correction: you must divide by 255, not 256. The highest value is
255, and that corresponds to 1.0.
H
Date: 16 Mar 2006 10:05:01
Message: <web.44197dce2ff0c10ff039f4f00@news.povray.org>
> H
Thanks all. These tips helped a lot (especially that colour tool).
One final thing, is it possible to use CMYK values in POVRay? The biggest
problem I was having was controlling the lightness and darkness of a
colour.
Date: 16 Mar 2006 14:53:22
Message: <kurtzlepirate-DE95B4.20532216032006@news.povray.org>
In article <web.44197dce2ff0c10ff039f4f00@news.povray.org>,
> colour.
strange thing... cmyk space is for print. of corse you can always use
any space colors en pov in writing small macro to switch for one space
to an other.
from <http://en.wikipedia.org/wiki/CMYK> Converting CMYK to RGB
To convert, we first convert CMYK to CMY, then convert the CMY value to
RGB. Converting now tCMYK = {C,M,Y,K}
then
  tCMY = {C',M',Y'} = {C(1 - K) + K,M(1 - K) + K,Y(1 - K) + K}
and
  tRGB = {R,G,B} = {1 - C',1 - M',1 - Y'}
or substituting in
  tRGB = {1 - (C(1 - K) + K),1 - (M(1 - K) + K),1 - (Y(1 - K) + K)}
       = {1 - C(1 - K) - K, 1 - M(1 - K) - K, 1 - Y(1 - K) - K}
suppose you declare your macro like that :
#macro cmyk2rgb(cc,mm,yy,kk)
  ...hard compute here...
  rgb<rr,gg,bb>
you can now use cmyk space in pigment :
klp
