POV-Ray : Newsgroups : povray.newusers : Parse Error? Help Server Time
14 Mar 2026 15:09:45 EDT (-0400)
  Parse Error? Help (Message 1 to 4 of 4)
Subject: Parse Error? Help
Date: 25 Oct 2005 19:40:01
Message: <web.435ec15c633e908816b98e6a0@news.povray.org>
I am a new user to POV-Ray (I use Mechanisto but am a bit of a novice with
it too) . I downloaded POV and started up, and, with the help of a
tutorial, put in this really simple code:
 location <2,5,-10>
 look_at <0,0,0>
//now, some light
light_source {
 <0,-10,0>
 color rgb <1,1,1>
//the SPHERE, baby!
sphere {
 <0,0,0>, 5
 pigment {color rgb <1,0,0> }
So, I've put that in and I want to render. I don't know how to initialize a
render (because I'm a novice or an idiot, you decide). But that is not the
main question here. When I try to do anything beyond typing this in, such
as press the stoppy sign thing (is that the render button?), or go to
Render Benchmark, my Messages window displays the following errors...
Possible Parse Error: Could not find file 'functions.inc'
File benchmark.pov line 3
Parse Error: Cannot open include file functions.inc.
Parse Warning: Check that the file is in a directory specifed with a +L
switch or 'Library_Path=' .INI item. Standard include files are in the
include directory or folder. Please read your documentation carefully.
Meh. What the heck does all that mean..?
Subject: Re: Parse Error? Help
Date: 25 Oct 2005 20:19:34
Message: <435ecb96$1@news.povray.org>
a
Render Benchmark renders a separate scene (not the one you made) to evaluate
the performance of your computer. You don't need that option.
Instead, use Render -> Start Rendering (Go!), or just press the shortcut key
alt+g (assuming you're using Windows.)
The stop sign thingy only appears when a render is currently running (maybe
you had already started the benchmark when you noticed this button).
Normally, it should be a green circle with a guy running in it and should
say "Run;" it should do the same thing as the menu option I mentioned above.
All that said, I'm not sure why you got those errors while running the
benchmark (specifically, "Could not find file 'functions.inc'" worries me);
when your scenes get more complicated you might have some issues with your
POV-Ray installation to fix, but for now don't worry about it.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 26 Oct 2005 19:05:02
Message: <web.43600a50a10f348616b98e6a0@news.povray.org>
Sorry--forgot to mention that all the options on the Render menu (I'm on a
Mac, by the way) are grayed out and unselectable. That is, except for
Benchmark Render. This, I assume, is NOT normal, seeing as I have a
full-fleshed scene typed in. Do you think this should go to the Error
Reports topic?
Oh yeah--I've already tried reinstalling, and even re-downloading from a
different source.
Date: 26 Oct 2005 23:27:14
Message: <43604912@news.povray.org>
> Reports topic?
> different source.
Obviously not because obviously thousands of others are using POV-Ray for
Mac and this should already tell you that the problem is on your side and
not with the official version you downloaded ;-)
Either your scene is not saved, your scene does not have a ".pov" and
rendering only files with ".pov" xtension is enabled in the preferences or
you just don't have the scene's window in front.
If you are a new users it really makes sense to follow the tutorial
documentation (via the Help menu or the online version), in particular
<http://www.povray.org/documentation/view/3.6.1/11/>
     Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
