POV-Ray : Newsgroups : povray.newusers : Height Field smooth keyword Server Time
21 Dec 2025 12:25:25 EST (-0500)
  Height Field smooth keyword (Message 1 to 5 of 5)
Subject: Height Field smooth keyword
Date: 2 Jul 2005 20:45:00
Message: <web.42c7341a545312e06a9959d70@news.povray.org>
I have look high and low.  Why does the render hang up on "smooth"?
object {
  height_field {
    tga "Track Tile.tga"
    scale <SCALE_FACTOR, 45.000000, SCALE_FACTOR>
    smooth
      image_map {
        tga "TrackTile_TEX_960.tga"
      scale SCALE_FACTOR
      rotate <90, 0, 0>
    finish {
      ambient <0.35, 0.35, 0.32>
      diffuse 2.5
      crand 0.1
The render runs fine if I comment out "smooth" but I really need to have it
as the render is very jagged looking.
Any help would be great, thanks.
Wayne
Subject: Re: Height Field smooth keyword
Date: 2 Jul 2005 21:41:18
Message: <megec1p1ir9j5jvhe7p71iiutpqbdbfg88@4ax.com>
Move "smooth" before "scale", like this:
  height_field {
    smooth
That should work.
Kyle
On Sat,  2 Jul 2005 20:40:58 EDT, "waynehays1" <way### [at] yahoocom>
>object {
>  height_field {
>    smooth
>  texture {
>    pigment {
>      image_map {
>      scale SCALE_FACTOR
>      rotate <90, 0, 0>
>    finish {
>      diffuse 2.5
>      crand 0.1
>Wayne
Date: 2 Jul 2005 22:00:00
Message: <web.42c745a0e1372cf26a9959d70@news.povray.org>
That worked great Kyle, thanks for the help.  It's almost like I tried
everything but that.
Thanks again,
Wayne
>   height_field {
>     smooth
> That should work.
> Kyle
> >object {
> >  height_field {
> >    smooth
> >  texture {
> >    pigment {
> >      image_map {
> >      scale SCALE_FACTOR
> >      rotate <90, 0, 0>
> >    finish {
> >      diffuse 2.5
> >      crand 0.1
> >Wayne
Date: 3 Jul 2005 00:05:01
Message: <web.42c76355e1372cf26a9959d70@news.povray.org>
>   height_field {
>     smooth
> That should work.
> Kyle
> >object {
> >  height_field {
> >    smooth
> >  texture {
> >    pigment {
> >      image_map {
> >      scale SCALE_FACTOR
> >      rotate <90, 0, 0>
> >    finish {
> >      diffuse 2.5
> >      crand 0.1
> >Wayne
Thanks, that worked great.
Date: 15 Jul 2005 07:00:01
Message: <web.42d796bae1372cf2950b81cf0@news.povray.org>
> >   height_field {
> >     smooth
> > That should work.
> > Kyle
The logic behind this is that specific options and attributes are specified
before general ones. In this case, smooth is an option that is specific to
height-field, so you have to specify it before specifying more general
object modifiers, like scale.
I hope this makes sense. :)
