POV-Ray : Newsgroups : povray.newusers : Photons, media, and caustics Server Time
13 Oct 2025 16:24:46 EDT (-0400)
  Photons, media, and caustics (Message 1 to 5 of 5)
Subject: Photons, media, and caustics
Date: 2 Jun 2005 20:35:01
Message: <web.429fa553b08a18283cb015b90@news.povray.org>
I don't seem to be able to render photon caustics in a media container at
all.  With both turned on the caustics diappear, the media disappears in
the shadow of my transparent object, and shadows go completely black.  With
only media turned on media works just fine with proper shading in the
shadows.  With only photons turned on the caustics work fine.  I all cases
in internal diffusion works.  I have spent hours with the documentation to
no avail.  What am I missing? Here are the settings I last tried:
global_settings {
  assumed_gamma 1.0
  max_trace_level 15
   photons {
     count 20000
     jitter .4
     media 300
     max_trace_level 35
In my object's interior:
  interior{
    ior 2.2
    dispersion 1.9
    dispersion_samples 120
My objects' photon block:
  photons{
    target
    reflection on
    refraction on
My media container:
cylinder{
  <0,-.01,0>,<0,14,0>,8
  texture{
    pigment{ color rgbt <1,1,1,1>}
  interior{
    media{
      scattering { 1, rgb 0.03}
      intervals 1
      samples 30,100
      method 3
  hollow
Subject: Re: Photons, media, and caustics
Date: 3 Jun 2005 19:15:00
Message: <web.42a0e40243860d5eac4848f20@news.povray.org>
> global_settings {
>   assumed_gamma 1.0
>   max_trace_level 15
>    photons {
>      count 20000
>      jitter .4
>      media 300
>      max_trace_level 35
>   interior{
>     ior 2.2
>     dispersion 1.9
>   photons{
>     target
>     reflection on
>     refraction on
> My media container:
> cylinder{
>   texture{
>   interior{
>     media{
>       intervals 1
>       samples 30,100
>       method 3
>   hollow
I think you need a photons {pass_through} on your media container.
Date: 4 Jun 2005 15:40:01
Message: <web.42a202da43860d5e3cb015b90@news.povray.org>
> > global_settings {
> >   assumed_gamma 1.0
> >   max_trace_level 15
> >    photons {
> >      count 20000
> >      jitter .4
> >      media 300
> >      max_trace_level 35
> >   interior{
> >     ior 2.2
> >     dispersion 1.9
> >   photons{
> >     target
> >     reflection on
> >     refraction on
> > My media container:
> > cylinder{
> >   texture{
> >   interior{
> >     media{
> >       intervals 1
> >       samples 30,100
> >       method 3
> >   hollow
Thanks Mienai, that fixed everything.
Date: 4 Jun 2005 19:49:47
Message: <42a23e1b$1@news.povray.org>
Hmm, why was that necessary? Shouldn't photons pass through the transparent
surface anyway?
 - Slime
 [ http://www.slimeland.com/ ]
Date: 9 Jun 2005 23:20:00
Message: <web.42a9067e43860d5e3cb015b90@news.povray.org>
> surface anyway?
>  - Slime
Apparently they will not, but I need to run a LOT more tests using photons,
media, and radiosity together.  All I am sure of is that once I made the
media container a target I got explosive chroma dispersion, both on solid
surfaces and in the media - which is what I was after.  I still find no
mention of this in the documentation.  It is posted in binaries/images.
"Torture...  Temple of Alden"
