POV-Ray : Newsgroups : povray.newusers : just one color:( Server Time
30 Sep 2024 02:15:29 EDT (-0400)
  just one color:( (Message 1 to 4 of 4)
Subject: just one color:(
Date: 18 Mar 2005 10:45:01
Message: <web.423af68f3872ef7ea8399d8d0@news.povray.org>
I have a problem im trying to get a texure on this texure map.
if created a png image to show what i want to see and what i dont want to
see.
on the bits i do show i want a some sort of rusty texure if created(far from
perfect yet)
but it only seems to show the red whit not a single bit of grey.
i know its not the texure itself because it does work on a normal box.
could anybody tell me what im doing wrong
//////this is the texure
#declare metal_roest =
        granite
        color_map {
         [0.0 rgb < 0.5, 0.5, 0.5> ]
         [0.4 rgb < 0.5, 0.5, 0.5> ]
         [1.0 rgb < 0.5, 0, 0> ]
     frequency 1
        scale <30,10,30>
//////and this the cylinder whit the image pattern and texure map
#declare huis_buitenkant_onder =
difference{
  cylinder { <0, 0,0>, <0,100,0>, 50 }
  cylinder { <0,-1,0>, <0,101,0>, 49.5 }
  no_shadow
    image_pattern { png "mask.png" use_color interpolate 2 map_type 2 once}
    texture_map {
      [0 pigment { transmit 1 } ]
      [1  metal_roest]//color rgb < 100/255 , 100/255 , 100/255>}]
    scale 100
  rotate y*225
roelof
Subject: Re: just one color:(
Date: 18 Mar 2005 12:49:15
Message: <TGFHOAATSxOCFwQ3@econym.demon.co.uk>
Wasn't it roelof who wrote:
>Hi,
>see.
>perfect yet)
The "metal_roest" is being affected by the "scale 100" that applies to
the texture map, and you're seeing a tiny bit of that pattern that just
happens to be all red. Scale it back down by a factor of 100 and you'll
see the grey bits.
      [1 pigment {metal_roest scale 0.01} ]
Mike Williams
Gentleman of Leisure
Date: 19 Mar 2005 11:10:00
Message: <web.423c4de9de2946c2a8399d8d0@news.povray.org>
> >Hi,
> >see.
> >perfect yet)
> see the grey bits.
> Mike Williams
thanks!!
that what the exact problem but i didnt tought it would be so easy
why dindt i see that:P
roelof
Date: 19 Mar 2005 14:54:43
Message: <423c8383$1@news.povray.org>
>>>Hi,
>>>see.
>>>perfect yet)
>>see the grey bits.
>>Mike Williams
> thanks!!
> roelof
too close to the problem ?
stephen
