POV-Ray : Newsgroups : povray.newusers : Diffused reflection Server Time
20 Nov 2025 15:35:52 EST (-0500)
  Diffused reflection (Message 1 to 4 of 4)
Subject: Diffused reflection
Date: 10 Jan 2005 22:20:01
Message: <web.41e345721125ceed7b9f44510@news.povray.org>
I'm trying to get a kind of plastic look for some of my materials, ie where
everything reflected in sort of blurry.  Generally the blurryness should
increase the farther the object is from the reflecting surface.  Any ideas?
Subject: Re: Diffused reflection
Date: 10 Jan 2005 22:28:53
Message: <41e347f5$1@news.povray.org>
mienai[AT]hotmail.com nous apporta ses lumieres en ce 2005-01-10 22:18:
Look at http://www.ignorancia.org/tech_page.php?image=6&db=tips
With an adequate pigment, phong or specular highlight and reflection
(constant or variable) values, you can  realisticaly simulate most surface.
Date: 11 Jan 2005 05:51:19
Message: <41e3afa7@news.povray.org>
  If you want blurred reflection, you can use this trick:
http://tag.povray.org/povQandT/languageQandT.html#blurredreflection
  However, often it's enough to fake a "blurry" look by other means
and the image will still look good (like in the example posted in
the other reply).
Date: 11 Jan 2005 07:53:12
Message: <41e3cc38$1@news.povray.org>
This may be what you want. Pay special attention to camera blur settings
  and the normal:
default { finish { ambient 0 } }
global_settings
    assumed_gamma 1
     location <0,.5,-5>
     look_at 0
     blur_samples 500//000//131072
     aperture .02
     variance 1/384
     confidence 0.9
     focal_point <-2,0,-1.2>
light_source { <0, 2, -100> rgb 1 }
light_source { <-100, 100, -100> rgb 2.5 }
//sky_sphere { pigment { color rgb <0.2, 0.5, 0.9> } }
plane { y, -1 texture {
         pigment { checker
             rgb <0.02, 0.05, 0.4>*2
             rgb <0.02, 0.05, 0.4>*0.5
     interior { ior 1.33 }
#declare textured = normal
  spotted 1 scale .001
sphere { 0,10000 pigment { rgb 1 } finish { diffuse 0 ambient 1 }  hollow }
sphere { <3,0,4>,1 pigment {color rgb <0.01,0.1,0.7>*1} finish { diffuse
0.7 specular .7 roughness 0.0005 reflection {0.1,1 fresnel }
conserve_energy } interior { ior 1.33 } normal { textured }}
sphere { <-2,0,0>,1 pigment {color rgb <1,0.1,0.05>*1} finish { diffuse
sphere { <1,0,10>,1 pigment {color rgb <0.01,0.5,0.2>*.25} finish {
diffuse 0.7 specular .7 roughness 0.0005 reflection {0.1,1 fresnel }
~Mike
