POV-Ray : Newsgroups : povray.newusers : Balls on a grid Server Time
21 Mar 2026 06:19:03 EDT (-0400)
  Balls on a grid (Message 1 to 8 of 8)
Subject: Balls on a grid
Date: 4 Jun 2004 10:35:00
Message: <web.40c08856b1fbe2ea7b0df26c0@news.povray.org>
Hello Everybody!
I trying to arrange labelled balls on a grid (see subsequent code). The
problem is that the balls look like pool balls. To become more reliable I
would like use uni-colored balls labelled with black text.
error.
In the web I just found examples with text in a glass ball or text growing
out from a ball. Unfortunately all my attempts to modify failed.
Thanks in advance!
Ralf
// Persistence Of Vision raytracer version 3.5 file.
// by Ralf
// 03-06-2004
#include "functions.inc"
#include "stones.inc"
global_settings {
    assumed_gamma 1.8
    max_trace_level 32
camera {location <7.5,17.5,7.5> look_at <7.5,0,7.5>}
light_source {<7.5,20,7.5> color White}
#macro MakeBall(Text, SpotSize, SpotClearance, ColorTex, WhiteTex)
    #local Mn = min_extent(Text);
    #local Mx = max_extent(Text);
    #local PatternObj =
    union {
        object {Text
            translate -Mn - 0.5*(Mx-Mn)
            scale  x + y + z*1/(Mx.z - Mn.z)
            scale (x+y)*(SpotSize-SpotClearance)/vlength(<Mx.x, Mx.y, 0> -
<Mn.x, Mn.y, 0>) + z
            translate -z*1
        #debug "n"
        #debug str((Mx.z - Mn.z),0,0)
        #debug "n"
        object {Text
            scale  -x + y + z*1/(Mx.z - Mn.z)
            translate z*1
        difference {
            cylinder {-z*2, z*2, 5}
            cylinder {-z*2, z*2, SpotSize/2}
    sphere  {< 0, 0, 0>, 1
            object {PatternObj texture {WhiteTex}, texture {ColorTex}}
#macro MakeTextBall(Text, SpotSize, SpotClearance, ColorTex, WhiteTex)
    #local TextObj =
    text {ttf "crystal.ttf", Text, 1, 0 /* pigment { Black } */
    MakeBall(TextObj, SpotSize, SpotClearance, ColorTex, WhiteTex)
#declare RedTex =
    pigment {color Red}
#declare WhiteTex =
    pigment {color White}
#declare BlackTex =
    pigment {color Black}
#declare GreenTex =
    pigment {color Green}
#declare BlueTex =
    pigment {color Blue}
#declare YellowTex =
    pigment {color Yellow}
/* Grid */
cylinder {<0, 0, 0>, <15, 0, 0>,  0.05  open   texture { T_Stone25 scale 4
cylinder {<0, 0, 2.5>, <15, 0, 2.5>,  0.05  open   texture { T_Stone25 scale
4 }}
cylinder {<0, 0, 5>, <15, 0, 5>,  0.05  open   texture { T_Stone25 scale 4
cylinder {<0, 0, 7.5>, <15, 0, 7.5>,  0.05  open   texture { T_Stone25 scale
4 }}
cylinder {<0, 0, 10>, <15, 0, 10>,  0.05  open   texture { T_Stone25 scale 4
cylinder {<0, 0, 12.5>, <15, 0, 12.5>,  0.05  open   texture { T_Stone25
scale 4 }}
cylinder {<0, 0, 15>, <15, 0, 15>,  0.05  open   texture { T_Stone25 scale 4
cylinder {<0, 0, 0>, <0, 0, 15>,  0.05  open   texture { T_Stone25 scale 4
cylinder {<2.5, 0, 0>, <2.5, 0, 15>,  0.05  open   texture { T_Stone25 scale
4 }}
cylinder {<5, 0, 0>, <5, 0, 15>,  0.05  open   texture { T_Stone25 scale 4
cylinder {<7.5, 0, 0>, <7.5, 0, 15>,  0.05  open   texture { T_Stone25 scale
4 }}
cylinder {<10, 0, 0>, <10, 0, 15>,  0.05  open   texture { T_Stone25 scale 4
cylinder {<12.5, 0, 0>, <12.5, 0, 15>,  0.05  open   texture { T_Stone25
scale 4 }}
cylinder {<15, 0, 0>, <15, 0, 15>,  0.05  open   texture { T_Stone25 scale 4
object {MakeTextBall("NM_8", 1.5, 0, GreenTex, WhiteTex)
    rotate x*100
    rotate z*350
    translate z*0
    translate y*0
    translate x*0
object {MakeTextBall("NM_2", 1.5, 0.1, GreenTex, WhiteTex)
    rotate x*100
    translate z*0
    translate y*0
    translate x*2.5
object {MakeTextBall("DM_10", 1.5, 0.1, BlueTex, WhiteTex)
    rotate x*95
    rotate z*350
    translate z*2.5
    translate y*0
    translate x*0
object {MakeTextBall("DM_4", 1.5, 0.1, BlueTex, WhiteTex)
    rotate x*90
    rotate z*350
    translate z*5
    translate y*0
    translate x*0
object {MakeTextBall("DM_6", 1.5, 0.1, BlueTex, WhiteTex)
    rotate x*90
    translate z*7.5
    rotate z*350
    translate y*0
    translate x*0
object {MakeTextBall("TM_2", 1.5, 0.1, BlackTex, WhiteTex)
    rotate x*90
    rotate z*350
    translate z*10
    translate y*0
    translate x*0
object {MakeTextBall("NM_5", 1.5, 0.1, GreenTex, WhiteTex)
    rotate x*85
    rotate z*350
    translate z*12.5
    translate y*0
    translate x*0
object {MakeTextBall("IM_10", 1.5, 0.1, RedTex, WhiteTex)
    rotate x*80
    rotate z*350
    translate z*15
    translate y*0
    translate x*0
object {MakeTextBall("IM_3", 1.5, 0.1, RedTex, WhiteTex)
    rotate x*80
    translate z*15
    translate y*0
    translate x*2.5
object {MakeTextBall("IT_3", 1.5, 0.1, YellowTex, BlackTex)
    rotate x*85
    translate z*12.5
    translate y*0
    translate x*2.5
object {MakeTextBall("TM_1", 1.5, 0.1, BlackTex, WhiteTex)
    rotate x*90
    translate z*10
    translate y*0
    translate x*2.5
object {MakeTextBall("DM_3", 1.5, 0.1, BlueTex, WhiteTex)
    rotate x*90
    translate z*7.5
    translate y*0
    translate x*2.5
object {MakeTextBall("TM_10", 1.5, 0.1, BlackTex, WhiteTex)
    rotate x*90
    translate z*5
    translate y*0
    translate x*2.5
object {MakeTextBall("IT_8", 1.5, 0.1, YellowTex, BlackTex)
    rotate x*95
    translate z*2.5
    translate y*0
    translate x*2.5
object {MakeTextBall("IT_7", 1.5, 0.1, YellowTex, BlackTex)
    rotate x*100
    translate z*0
    translate y*0
    translate x*5
object {MakeTextBall("IT_9", 1.5, 0.1, YellowTex, BlackTex)
    rotate x*95
    translate z*2.5
    translate y*0
    translate x*5
object {MakeTextBall("DM_7", 1.5, 0.1, BlueTex, WhiteTex)
    rotate x*90
    translate z*5
    translate y*0
    translate x*5
object {MakeTextBall("TM_6", 1.5, 0.1, BlackTex, WhiteTex)
    rotate x*90
    translate z*7.5
    translate y*0
    translate x*5
object {MakeTextBall("DM_9", 1.5, 0.1, BlueTex, WhiteTex)
    rotate x*90
    translate z*10
    translate y*0
    translate x*5
object {MakeTextBall("IM_2", 1.5, 0.1, RedTex, WhiteTex)
    rotate x*85
    translate z*12.5
    translate y*0
    translate x*5
object {MakeTextBall("IT_5", 1.5, 0.1, YellowTex, BlackTex)
    rotate x*80
    translate z*15
    translate y*0
    translate x*5
object {MakeTextBall("NM_4", 1.5, 0.1, GreenTex, WhiteTex)
    rotate x*80
    translate z*15
    translate y*0
    translate x*7.5
object {MakeTextBall("IM_9", 1.5, 0.1, RedTex, WhiteTex)
    rotate x*85
    translate z*12.5
    translate y*0
    translate x*7.5
object {MakeTextBall("NM_10", 1.5, 0.1, GreenTex, WhiteTex)
    rotate x*90
    translate z*10
    translate y*0
    translate x*7.5
object {MakeTextBall("TM_4", 1.5, 0.1, BlackTex, WhiteTex)
    rotate x*90
    translate z*7.5
    translate y*0
    translate x*7.5
object {MakeTextBall("IT_4", 1.5, 0.1, YellowTex, BlackTex)
    rotate x*90
    translate z*5
    translate y*0
    translate x*7.5
object {MakeTextBall("IT_10", 1.5, 0.1, YellowTex, BlackTex)
    rotate x*95
    translate z*2.5
    translate y*0
    translate x*7.5
    rotate x*100
    translate z*0
    translate y*0
    translate x*7.5
object {MakeTextBall("NM_9", 1.5, 0.1, GreenTex, WhiteTex)
    rotate x*100
    translate z*0
    translate y*0
    translate x*10
object {MakeTextBall("TM_9", 1.5, 0.1, BlackTex, WhiteTex)
    rotate x*95
    translate z*2.5
    translate y*0
    translate x*10
object {MakeTextBall("DM_8", 1.5, 0.1, BlueTex, WhiteTex)
    rotate x*90
    translate z*5
    translate y*0
    translate x*10
object {MakeTextBall("TM_5", 1.5, 0.1, BlackTex, WhiteTex)
    rotate x*90
    translate z*7.5
    translate y*0
    translate x*10
object {MakeTextBall("NM_6", 1.5, 0.1, GreenTex, WhiteTex)
    rotate x*90
    translate z*10
    translate y*0
    translate x*10
object {MakeTextBall("IM_8", 1.5, 0.1, RedTex, WhiteTex)
    rotate x*85
    translate z*12.5
    translate y*0
    translate x*10
object {MakeTextBall("IM_7", 1.5, 0.1, RedTex, WhiteTex)
    rotate x*80
    translate z*15
    translate y*0
    translate x*10
object {MakeTextBall("IM_4", 1.5, 0.1, RedTex, WhiteTex)
    rotate x*80
    translate z*15
    translate y*0
    translate x*12.5
object {MakeTextBall("IT_1", 1.5, 0.1, YellowTex, BlackTex)
    rotate x*85
    translate z*12.5
    translate y*0
    translate x*12.5
object {MakeTextBall("IM_4", 1.5, 0.1, BlueTex, WhiteTex)
    rotate x*90
    translate z*10
    translate y*0
    translate x*12.5
object {MakeTextBall("NM_7", 1.5, 0.1, GreenTex, WhiteTex)
    rotate x*90
    translate z*7.5
    translate y*0
    translate x*12.5
object {MakeTextBall("IM_5", 1.5, 0.1, RedTex, WhiteTex)
    rotate x*90
    translate z*5
    translate y*0
    translate x*12.5
object {MakeTextBall("NM_3", 1.5, 0.1, GreenTex, WhiteTex)
    rotate x*95
    translate z*2.5
    translate y*0
    translate x*12.5
object {MakeTextBall("DM_5", 1.5, 0.1, BlueTex, WhiteTex)
    rotate x*100
    translate z*0
    translate y*0
    translate x*12.5
object {MakeTextBall("TM_8", 1.5, 0.1, BlackTex, WhiteTex)
    rotate x*100
    rotate z*10
    translate z*0
    translate y*0
    translate x*15
    rotate x*95
    rotate z*10
    translate z*2.5
    translate y*0
    translate x*15
object {MakeTextBall("DM_1", 1.5, 0.1, BlueTex, WhiteTex)
    rotate x*90
    rotate z*10
    translate z*5
    translate y*0
    translate x*15
object {MakeTextBall("IT_2", 1.5, 0.1, YellowTex, BlackTex)
    rotate x*90
    rotate z*10
    translate z*7.5
    translate y*0
    translate x*15
object {MakeTextBall("TM_3", 1.5, 0.1, BlackTex, WhiteTex)
    rotate x*90
    rotate z*10
    translate z*10
    translate y*0
    translate x*15
object {MakeTextBall("TM_7", 1.5, 0.1, BlackTex, WhiteTex)
    rotate x*85
    rotate z*10
    translate z*12.5
    translate y*0
    translate x*15
object {MakeTextBall("NM_1", 1.5, 0.1, GreenTex, WhiteTex)
    rotate x*80
    rotate z*10
    translate z*15
    translate y*0
    translate x*15
plane  {<0,1,0 >,-1  pigment {color White} finish {ambient .5}}
/* Eof */
Subject: Re: Balls on a grid
Date: 4 Jun 2004 12:45:32
Message: <opr82wq7jqefp2ch@news.povray.org>
And lo on Fri,  4 Jun 2004 10:33:58 EDT, Ralf <mos### [at] gmxde> did
spake, saying:
> Hello Everybody!
> Modifying the “text{..}” by inserting “pigment {color Black}” cerates an
> error.
> growing
> Now I’m looking for an example of a solid sphere labelled with text.
> Thanks in advance!
> Ralf
<snip code>
Just a quicky but substituting this  macro:
//start code
#declare TextTexture=texture{
         pigment{object{Text colour Clear colour Black}
             translate -z*1
texture{pigment {cylindrical color_map{[0 Black][0.2 Black][0.2 White][1
White]}rotate x*90}}
texture{TextTexture}
//end code
Just one side of text though, I'll let you play with the other side  and
Substitute the colours :)
HTH
Phil Cook
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
Date: 4 Jun 2004 13:36:45
Message: <40c0b32d@news.povray.org>
Okay, Phil posted a reply since I started messing with this, but here
goes anyway....
I've typically added text to simple shapes a different way - I make a
union of the base object and an intersection of the "text" with a
similar shape that is very slightly larger.  That way the text is above
the sphere/cylinder, but imperceptibly so.  Sort of what would happen if
the text was a layer of paint on the object surface.
In your case, the face color can be applied the same way, too.  I
modified your macro, adding a "text" texture at the end (and the scaling
and translation is unnecessarily different, since I was tweaking it to
see what you were doing).   In any event, here's an example of what I mean:
-------- SNIP --------
#macro MakeTextBall(Text, SpotSize, SpotClearance, SphereTex, FaceTex,
TextPig)
     #local TextObj = text {ttf "crystal.ttf", Text, 1, 0 };
     #local Mn = min_extent(TextObj);
     #local Mx = max_extent(TextObj);
     union {
	// First, the sphere:
	sphere  {< 0, 0, 0>, 1 texture {SphereTex}}
	// Next, the color behind the text:
	intersection {
	    sphere { <0,0,0>, 1.0001 }
	    texture{FaceTex}
	// Last, the text:
	intersection {
	    union {
		#local ii=0; #while (ii<2)
		object {TextObj
		    scale
<-1,1,0>*(SpotSize-SpotClearance)/vlength(<Mx.x,Mx.y,0>-<Mn.x,Mn.y,0>)+z/(Mx.z-Mn.z)
		    translate -z*1
		    #if (ii) rotate 180*x #end
		#local ii=ii+1; #end
	    sphere { <0,0,0>, 1.0002 }
	    texture{TextPig}
In this case the sphere is 1.0000 in radius, the "face" color is 1.0001
and the text is 1.0002 -- giving the layered effect I was trying to
describe.
Note that this method doesn't "wrap" the text, so if the text covers
much of an arc on the object, it may be distorted too much.
Ralf wrote:
> Hello Everybody!
> error.
Date: 5 Jun 2004 12:02:01
Message: <cjameshuff-4D99B0.11020305062004@news.povray.org>
In article <40c0b32d@news.povray.org>,
This way will be slower and consume more memory than simply using the
object pattern. It is also more likely to cause artifacts from precision
problems, and is very difficult with more complex shapes, though it is
easy with spheres.
http://tag.povray.org/
Date: 5 Jun 2004 14:29:32
Message: <opr84wvpzke4dfwg@news.povray.org>
And lo on Sat, 05 Jun 2004 11:02:03 -0500, Christopher James Huff
<cja### [at] earthlinknet> did spake, saying:
> easy with spheres.
Out of curiosity is there an easily explainable :) reason why you can't
layer multiple object patterns? The obvious answer to this otherwise would
have been to create the differenced cylinders texture and layer the text
texture on top.
Phil Cook
Date: 6 Jun 2004 17:54:26
Message: <cjameshuff-0E0E85.16542906062004@news.povray.org>
In article <opr84wvpzke4dfwg@news.povray.org>,
> texture on top.
You can nest them, which lets you accomplish the same things. The object
pattern is about as simple as a pattern can get, supporting multiple
objects would be a lot more complex. I have been thinking about such a
patch, though...or rather, two similar patterns, one which "layers" each
object over the previous ones, and another which averages overlapping
objects together.
Date: 7 Jun 2004 04:58:45
Message: <opr87u47k4efp2ch@news.povray.org>
And lo on Sun, 06 Jun 2004 16:54:30 -0500, Christopher James Huff
>> would
>> texture on top.
Of course! silly me that would allow you to remove the MakeBall macro and
just have:
//code
#macro MakeTextBall(Text, SpotSize, SpotClearance, OuterColor, SpotColor,
TextColor)
   #local TextObj =
#declare Texttexture=
         pigment{object{TextObj colour Clear colour TextColor}
             translate -z*1
#declare Spottexture=
         pigment{object{difference {
        colour SpotColor colour OuterColor}}
#declare Spheretexture=texture{pigment{Spottexture}}
texture{pigment{Texttexture}}
texture{Spheretexture}
//end code
Remove all those ...Tex #declare's and put the colours directly in the
call, adding in the colour of the text directly as part of the macro:
//code
object {MakeTextBall("NM_8", 1.5, 0, Green, White, Black)
     rotate x*100
     rotate z*350
     translate z*0
     translate y*0
     translate x*0
//end code
> The object
> objects together.
Have fun :)
Phil Cook
Date: 8 Jun 2004 03:20:01
Message: <web.40c5681b890e5fa57b0df26c0@news.povray.org>
Dear Phil
Thank you for your advice. Your first solution already works pretty well.
An other very good solution was mailed directly by Friedrich. Because this
might be of interest for any Newbies working on similar problems, I list
the code below.
Thanks to all of you for your help :-)
Ralf
/* Code from Friedrich */
global_settings {
    assumed_gamma 1.8
    max_trace_level 32
#declare Camera_1 = camera { location <7.5,17.5,7.5>
#declare Camera_2 = camera { angle 5.1                       // Weiter weg =
weniger Verzerrung!  Lo
                            location <7.5,280,7.5>
                            look_at  <7.5, 0,7.5>}
camera {Camera_2}
light_source {<7.5,20+100,7.5> color White}     // Licht weiter weg wirft
// sky -------------------------------------------------------------------
sky_sphere{ pigment{ gradient <0,1,0>
                     color_map{ [0   color rgb<1,1,1>]//White
                                [0.4 color
rgb<1,1,1>]//<0.14,0.14,0.56>]//~Navy
                                [0.6 color
                                [1.0 color rgb<1,1,1>]//White
                     scale 2 }
           } // end of sky_sphere
    #local PatternObj =
    union {
        object {Text
            translate -z*1
       /* #debug "n"
        #debug "n"    geschenkt! */
        object {Text
            translate z*1
      /*  difference {                           //  Das macht den Farbring
der Billiardkugeln! Lo
    }// end of union of "PatternObj"  Lo
    rotate <90,0,0>
    #local TextObj =
    text { ttf "arial.ttf" /*crystal.ttf"*/ , Text, 1, 0  // texture{
pigment { Black } } "Das geht nicht! "
           scale <0.75,1,1> // Lo
         } // end of text object
#declare RedTex =
    pigment {color Red}
#declare WhiteTex =
    pigment {color White*1.2}
    finish  {phong 1}
#declare BlackTex =
#declare GreenTex =
#declare BlueTex =
#declare YellowGreenTex =
    pigment {color rgb<0.8,1,0.3>}
    finish  {ambient 0.15 diffuse 0.85 phong 0.5}
#declare HellgelbTex =
    pigment {color rgb<1.0,1.0,0.5>}
#declare DotterGelbTex =
    pigment {color rgb<1.0,0.6,0.0>}
#declare Metall1 = texture { Polished_Chrome
                   //  pigment{ color rgb<1,0,0>}
                   normal { bumps 0.5 scale 0.005}
                   finish { ambient 0.1 diffuse 0.85  phong 1}
                 } // end of texture
#declare Metall2 = texture { Polished_Chrome
                     pigment{ color rgb<1,0.6,0>}
                 } // end of texture
/* Gitter definieren */
4 }}
4 }}
scale 4 }}
4 }}
4 }}
scale 4 }}
Raster(weite) sind einfacher!
#declare Stab = cylinder {<0, 0, 0>, <15, 0, 0>,  0.05   texture {T_Stone25
scale 4 }}
                                                        // texture
{Metall2}}
#declare Raster = 2.5;
#local Nr = 0; #local End = 7; // start / end of loop
#while (Nr < End)
  object{ Stab translate<0,0,Nr*Raster>}
  object{ Stab rotate<0,-90,0>
               translate<Nr*Raster,0,0>}
 #local Nr = Nr + 1;
#end // of while loop
object {MakeTextBall("NM_8", 1.5, 0, BlackTex, Metall2)
    //rotate y*100
    //rotate z*350
    translate z*0
    translate y*0
    translate x*0
object {MakeTextBall("NM_2", 1.5, 0.1, BlackTex, YellowGreenTex)
    // rotate x*100
    translate z*0
    translate y*0
    translate x*2.5
object {MakeTextBall("DM_10", 1.5, 0.1, BlackTex, WhiteTex)
   // rotate x*95
   // rotate z*350
    translate z*2.5
    translate y*0
    translate x*0
object {MakeTextBall("DM_4", 1.5, 0.1, BlackTex, WhiteTex)
   // rotate x*90
   // rotate z*350
    translate z*5
    translate y*0
    translate x*0
object {MakeTextBall("DM_6", 1.5, 0.1, BlackTex, WhiteTex)
   // rotate x*90
    translate z*7.5
   // rotate z*350
    translate y*0
    translate x*0
    //rotate x*90
    //rotate z*350
    translate z*10
    translate y*0
    translate x*0
object {MakeTextBall("NM_5", 1.5, 0.1, BlackTex, Metall2)
    //rotate x*85
    //rotate z*350
    translate z*12.5
    translate y*0
    translate x*0
object {MakeTextBall("IM_10", 1.5, 0.1, Metall2, BlackTex)
    //rotate x*80
    //rotate z*350
    translate z*15
    translate y*0
    translate x*0
object {MakeTextBall("IM_3", 1.5, 0.1, BlackTex, HellgelbTex)
    //rotate x*80
    translate z*15
    translate y*0
    translate x*2.5
object {MakeTextBall("IT_3", 1.5, 0.1, BlackTex, DotterGelbTex)
    //rotate x*85
    translate z*12.5
    translate y*0
    translate x*2.5
    //rotate x*90
    translate z*10
    translate y*0
    translate x*2.5
    //rotate x*90
    translate z*7.5
    translate y*0
    translate x*2.5
    //rotate x*90
    translate z*5
    translate y*0
    translate x*2.5
    //rotate x*95
    translate z*2.5
    translate y*0
    translate x*2.5
    //rotate x*100
    translate z*0
    translate y*0
    translate x*5
    //rotate x*95
    translate z*2.5
    translate y*0
    translate x*5
    //rotate x*90
    translate z*5
    translate y*0
    translate x*5
    //rotate x*90
    translate z*7.5
    translate y*0
    translate x*5
    //rotate x*90
    translate z*10
    translate y*0
    translate x*5
    //rotate x*85
    translate z*12.5
    translate y*0
    translate x*5
    // rotate x*80
    translate z*15
    translate y*0
    translate x*5
    //rotate x*80
    translate z*15
    translate y*0
    translate x*7.5
    //rotate x*85
    translate z*12.5
    translate y*0
    translate x*7.5
    //rotate x*90
    translate z*10
    translate y*0
    translate x*7.5
    //rotate x*90
    translate z*7.5
    translate y*0
    translate x*7.5
    //rotate x*90
    translate z*5
    translate y*0
    translate x*7.5
    //rotate x*95
    translate z*2.5
    translate y*0
    translate x*7.5
    //rotate x*100
    translate z*0
    translate y*0
    translate x*7.5
    //rotate x*100
    translate z*0
    translate y*0
    translate x*10
    //rotate x*95
    translate z*2.5
    translate y*0
    translate x*10
    //rotate x*90
    translate z*5
    translate y*0
    translate x*10
    //rotate x*90
    translate z*7.5
    translate y*0
    translate x*10
    //rotate x*90
    translate z*10
    translate y*0
    translate x*10
    //rotate x*85
    translate z*12.5
    translate y*0
    translate x*10
    //rotate x*80
    translate z*15
    translate y*0
    translate x*10
    //rotate x*80
    translate z*15
    translate y*0
    translate x*12.5
    //rotate x*85
    translate z*12.5
    translate y*0
    translate x*12.5
    //rotate x*90
    translate z*10
    translate y*0
    translate x*12.5
    //rotate x*90
    translate z*7.5
    translate y*0
    translate x*12.5
    //rotate x*90
    translate z*5
    translate y*0
    translate x*12.5
    //rotate x*95
    translate z*2.5
    translate y*0
    translate x*12.5
    //rotate x*100
    translate z*0
    translate y*0
    translate x*12.5
    //rotate x*100
    //rotate z*10
    translate z*0
    translate y*0
    translate x*15
    //rotate x*95
    //rotate z*10
    translate z*2.5
    translate y*0
    translate x*15
    //rotate x*90
    //rotate z*10
    translate z*5
    translate y*0
    translate x*15
object {MakeTextBall("IT_2 ", 1.5, 0.1, YellowTex, BlackTex)
    //rotate x*90
    //rotate z*10
    translate z*7.5
    translate y*0
    translate x*15
object {MakeTextBall("TM_3 ", 1.5, 0.1, BlackTex, WhiteTex)
    //rotate x*90
    //rotate z*10
    translate z*10
    translate y*0
    translate x*15
object {MakeTextBall("TM_7 ", 1.5, 0.1, BlackTex, WhiteTex)
    //rotate x*85
    //rotate z*10
    translate z*12.5
    translate y*0
    translate x*15
object {MakeTextBall("NM_1 ", 1.5, 0.1, GreenTex, WhiteTex)
    //rotate x*80
    //rotate z*10
    translate z*15
    translate y*0
    translate x*15
plane  {<0,1,0 >,-1  pigment {color White} //finish {ambient .5}}
                                           finish {ambient 1 diffuse 0}}
//alternativ
/* Eof */
