POV-Ray : Newsgroups : povray.newusers : I Need Help With Media Server Time
17 Mar 2026 01:54:30 EDT (-0400)
  I Need Help With Media (Message 12 to 21 of 21)
Subject: Re: I Need Help With Media (small sample image)
Date: 21 May 2004 05:41:36
Message: <opr8cft40op4ukzs@news.povray.org>
On Fri, 21 May 2004 00:27:24 EDT, Danny <danzaetz> wrote:
<snip>
> I still can't figure out how to get rid of the images on the surface of
> the
> laser.  Please help.
Have you thought about doing it as a cylinder light_source, slower but it
might solve your problem:
//code
union{
cylinder{0,x*100, 1 hollow
pigment {rgbt 1}
interior{
media{
scattering{3,1}
density{
cylindrical rotate 90*z
color_map{
[0 rgb 0]
[0.5 red 3]
[0.9 rgb 5]
[1 rgb 10]}
scale <1,.2,.2>
light_source{0 rgb 10 cylinder point_at x*100}
translate<-50,0,10>
//end code
This is done with a non-defined camera so you'll need to tweak the
intensities and translate to get it to look right.
HTH
Phil Cook
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
Date: 21 May 2004 16:25:00
Message: <web.40ae64ea865d73e4ffb015460@news.povray.org>
> <snip>
> > the
> > laser.  Please help.
> //code
> union{
> pigment {rgbt 1}
> interior{
> media{
> scattering{3,1}
> density{
> color_map{
> [0 rgb 0]
> [0.5 red 3]
> [0.9 rgb 5]
> [1 rgb 10]}
> scale <1,.2,.2>
> translate<-50,0,10>
> //end code
> HTH
> Phil Cook
Is this cylinder light_source supposed to produce a visible light beam that
can be seen outside where it's pointing at, or is it more like a laser pen
that produces a dot on the surface it's aimed at? I tried it along with
scattering and it did nothing to get rid of the images.
Also, in order to round off the ends of my laser beam, I put some
half-spheres on either end, both filled with the same media, except the
density is spherical instead of cylindrical.  For some reason, this created
tons more problems.  When you look at the half-spheres perpendicularly,
there's no problem, but when you look at them obliquely, you get very odd
results, such as grey rings, spots, etc.  Here's what I'm doing:
 #default {
  pigment {Grey}
    finish {
     diffuse 0.6
      ior 1.5
      ambient 0.300000
      phong 0.5
      phong_size 50
  location <0,0.5,2>
  look_at <0,0.5,0>
background {color rgb <0,0,0>}
light_source {
  <-1000.000000,1000.000000,1000.000000>       //  x=-1000,y=1000,z=1000
  color rgb <1.0000,1.0000,1.0000>
#declare clock1=1;
union{
cylinder{<0,2*clock1,0>,<0,0,0>, 1                 //the laser, top right
from front
    pigment { color rgbt 1}}
       interior{media{emission rgb 1
       density{ cylindrical
       color_map{[0 rgb 0][0.03 rgb <0.0004,0,0>][0.6 rgb<8,0,0>][0.98 rgb
16][1 rgb 30]} //[0 rgb 0][0.02 rgb <0.004,0,0>][0.5 rgb<4,0,0>][0.96 rgb
5][1 rgb 10]
       hollow
       scale<0.1, 1, 0.1>
difference{
sphere{<0,0,0>, 1
       scattering{3,1}
       density{ spherical
16][1 rgb 30]}
       hollow
       scale<0.1, 0.1, 0.1>
       translate <0,2*clock1,0>
cylinder{<0,2*clock1,0>,<0,0,0>,5}
difference{
sphere{<0,0,0>, 1
       density{ spherical
16][1 rgb 30]}
       hollow
cylinder{<0,5,0>,<0,0,0>,5}
light_source{0 rgb 10 cylinder point_at y*2}
sphere{<.2,.5,-.5>,0.1}
Try running this and you'll see the image of the sphere on the laser.
You'll also see the grey ring where the laser cylinder and the laser
half-sphere meet(try looking at that location perpendicularly and the grey
ring disappears).
You can also see a small white dot on the bottom half-sphere, which is also
an image of the grey sphere.  I have a background of stars, and so the ends
of my laser end up looking speckled.  How can I make all those images and
grey rings go away?
Date: 21 May 2004 23:20:12
Message: <40aec6ec@news.povray.org>
Danny nous apporta ses lumieres ainsi en ce 2004/05/21 16:22... :
> <snip>
Why do you use this default texture, it's the source of most of your
problems
> #default {
>   texture {
>  pigment {Grey}
>    finish {
>     diffuse 0.6
>      ior 1.5
>      ambient 0.300000
>      phong 0.5
>      phong_size 50
>camera {
>  location <0,0.5,2>
>  look_at <0,0.5,0>
>light_source {
>#declare clock1=1;
>union{
>from front
>         texture {
>5][1 rgb 10]
>       hollow
>       scale<0.1, 1, 0.1>
removing this don't change anything in your cene
>difference{
>sphere{<0,0,0>, 1
>         texture {
>       scattering{3,1}
>       density{ spherical
>16][1 rgb 30]}
>       hollow
>difference{
>sphere{<0,0,0>, 1
>         texture {
>       density{ spherical
>16][1 rgb 30]}
>       hollow
Default ior applied to the cylinder
>ring disappears).
Default texture applied to the substracting cylinder
Default texture's ior again
>grey rings go away?
1- Remove the ior statement in your default. Thin add an ior to your
cylinder, this is what cause the sphere to apears in your beam.
2- Use merge instead on an union. This will remove the internal surfaces.
3- Use difference{sphere{...}cylinder{...}texture{...}interior{...}}.
That is, apply the texture and interior to the whole
union/difference/intersection/merge. The cylinder get the default
texture and apply it to where it intercect the sphere, giving you that
gray circle.
Date: 24 May 2004 05:21:28
Message: <opr8hyvpvop4ukzs@news.povray.org>
<snip>
> that
> pen
It constrains the light to within a cylinder so it won't illuminate
anything that is not within it's path just like a laser pen,  so if you
stick a media through it, it will show the path in the same way shining a
laser pen through smoke will. All of the light_sources act in this way,
they won't light up anything not in their path, the default point_light of
course shines light in all directions. Take a look at spotlite.pov in the
scenes/lights directory in fact have a look at most of that directory if
you want to know more about lights
> created
<snip>
I think Alain has answered this one.
Phil Cook
Date: 27 May 2004 23:05:01
Message: <web.40b6ac4e865d73e4ffb015460@news.povray.org>
> > <snip>
> problems
> > #default {
> >   texture {
> >  pigment {Grey}
> >    finish {
> >     diffuse 0.6
> >      ior 1.5
> >      ambient 0.300000
> >      phong 0.5
> >      phong_size 50
> >camera {
> >  location <0,0.5,2>
> >  look_at <0,0.5,0>
> >light_source {
> >#declare clock1=1;
> >union{
> >from front
> >         texture {
> >5][1 rgb 10]
> >       hollow
> >       scale<0.1, 1, 0.1>
> >difference{
> >sphere{<0,0,0>, 1
> >         texture {
> >       scattering{3,1}
> >       density{ spherical
> >16][1 rgb 30]}
> >       hollow
> >difference{
> >sphere{<0,0,0>, 1
> >         texture {
> >       density{ spherical
> >16][1 rgb 30]}
> >       hollow
> >ring disappears).
> >grey rings go away?
> gray circle.
> Alain
Thanks, Alain, all the images on the laser are gone now that ior has been
deleted. It also helped by making the outer edge fuzzier.  However, I'm
still having problems with the grey circle. This time, instead of a grey
circle, there's a disk that matches the color of the media (white in the
middle, red on the outside), but a little wider than the laser so it
doesn't match up (probably b/c removing the ior also seemed to shrink the
laser's width a little). Is this what you wanted me to do:
merge{
16][1 rgb 30]}
       hollow
       scale<0.1, 1, 0.1>
difference{
sphere{<0,0,0>, 1}
       density{ spherical
16][1 rgb 30]}
       hollow
Date: 28 May 2004 20:10:32
Message: <40b7d4f8$1@news.povray.org>
Danny nous apporta ses lumieres ainsi en ce 2004/05/27 23:04... :
>>><snip>
>>problems
>>>#default {
>>>  texture {
>>> pigment {Grey}
>>>   finish {
>>>    diffuse 0.6
>>>     ior 1.5
>>>     ambient 0.300000
>>>     phong 0.5
>>>     phong_size 50
>>>camera {
>>> location <0,0.5,2>
>>> look_at <0,0.5,0>
>>>light_source {
>>>#declare clock1=1;
>>>union{
>>>from front
>>>        texture {
>>>5][1 rgb 10]
>>>      hollow
>>>      scale<0.1, 1, 0.1>
>>>difference{
>>>sphere{<0,0,0>, 1
>>>        texture {
>>>      scattering{3,1}
>>>      density{ spherical
>>>16][1 rgb 30]}
>>>      hollow
>>>difference{
>>>sphere{<0,0,0>, 1
>>>        texture {
>>>      density{ spherical
>>>16][1 rgb 30]}
>>>      hollow
>>>ring disappears).
>>>grey rings go away?
>>gray circle.
>>Alain
>merge{
OK
>   //      texture {
>   // pigment { color rgbt 1}}
>16][1 rgb 30]}
>       hollow
>       scale<0.1, 1, 0.1>
>difference{
>sphere{<0,0,0>, 1}
Why is it so large? cylinder{<0,1.1,0>,<0,0,0>,1.1} is large enough
center your sphere and cylinder about <0,0.000001,0> is better, remove
coincidence surfaces.
>   //      texture {
>       density{ spherical
>16][1 rgb 30]}
>       hollow
    texture{pigment{rgbt 1}finish{ambient 0 diffuse 0}}// apply texture
once to whole merge
Now, I don't see a discontinuity, as long as I stay with a point of view
close to perpendiculat near the base, even zooming in, smooth trensition.
Date: 2 Jun 2004 19:05:00
Message: <web.40be5c7d865d73e4ffb015460@news.povray.org>
> >>><snip>
> >>problems
> >>>#default {
> >>>  texture {
> >>> pigment {Grey}
> >>>   finish {
> >>>    diffuse 0.6
> >>>     ior 1.5
> >>>     ambient 0.300000
> >>>     phong 0.5
> >>>     phong_size 50
> >>>camera {
> >>> location <0,0.5,2>
> >>> look_at <0,0.5,0>
> >>>light_source {
> >>>#declare clock1=1;
> >>>union{
> >>>from front
> >>>        texture {
> >>>5][1 rgb 10]
> >>>      hollow
> >>>      scale<0.1, 1, 0.1>
> >>>difference{
> >>>sphere{<0,0,0>, 1
> >>>        texture {
> >>>      scattering{3,1}
> >>>      density{ spherical
> >>>16][1 rgb 30]}
> >>>      hollow
> >>>difference{
> >>>sphere{<0,0,0>, 1
> >>>        texture {
> >>>      density{ spherical
> >>>16][1 rgb 30]}
> >>>      hollow
> >>>ring disappears).
> >>>grey rings go away?
> >>gray circle.
> >>Alain
> >merge{
> OK
> >   //      texture {
> >16][1 rgb 30]}
> >       hollow
> >       scale<0.1, 1, 0.1>
> >difference{
> >sphere{<0,0,0>, 1}
> >   //      texture {
> >       density{ spherical
> >16][1 rgb 30]}
> >       hollow
> once to whole merge
> Alain
Thanks.  It was the coincident surfaces that were causing my problems.  My
problems are fixed now.
Danny
Date: 4 Jun 2004 23:45:01
Message: <web.40c1409d865d73e4ffb015460@news.povray.org>
> > >>><snip>
> > >>problems
> > >>>#default {
> > >>>  texture {
> > >>> pigment {Grey}
> > >>>   finish {
> > >>>    diffuse 0.6
> > >>>     ior 1.5
> > >>>     ambient 0.300000
> > >>>     phong 0.5
> > >>>     phong_size 50
> > >>>camera {
> > >>> location <0,0.5,2>
> > >>> look_at <0,0.5,0>
> > >>>light_source {
> > >>>#declare clock1=1;
> > >>>union{
> > >>>from front
> > >>>        texture {
> > >>>5][1 rgb 10]
> > >>>      hollow
> > >>>      scale<0.1, 1, 0.1>
> > >>>difference{
> > >>>sphere{<0,0,0>, 1
> > >>>        texture {
> > >>>      scattering{3,1}
> > >>>      density{ spherical
> > >>>16][1 rgb 30]}
> > >>>      hollow
> > >>>difference{
> > >>>sphere{<0,0,0>, 1
> > >>>        texture {
> > >>>      density{ spherical
> > >>>16][1 rgb 30]}
> > >>>      hollow
> > >>>ring disappears).
> > >>>grey rings go away?
> > >>gray circle.
> > >>Alain
> > >merge{
> > OK
> > >   //      texture {
> > >16][1 rgb 30]}
> > >       hollow
> > >       scale<0.1, 1, 0.1>
> > >difference{
> > >sphere{<0,0,0>, 1}
> > >   //      texture {
> > >       density{ spherical
> > >16][1 rgb 30]}
> > >       hollow
> > once to whole merge
> > Alain
Is there a way I can make the transition smooth even from a point of view
nowhere near perpendicular? It's fine when viewed from the pos. y
direction, but from the neg. y direction it looks like a full sphere (not
half-sphere) in front of a black background, and that the cylinder stops
short and is black when viewed through the base. (I hope you can understand
the picture I'm trying to describe, since I can't attach pictures.)  When I
change it from a merge to a union, it looks fine from the neg. y direction,
but from the pos. y direction the media doesn't transition well. Is there a
way to make it transition well from both directions?
Danny
Date: 5 Jun 2004 09:20:58
Message: <40c1c8ba$1@news.povray.org>
Danny nous apporta ses lumieres ainsi en ce 2004/06/04 23:40... :
>Danny
I don't know how. I my testings, that's exactly what I got. I think that
the spherical media just continue and mixes with the other even if it's
bounding shape is an half-sphere. Try removing the sylindrical media,
but keep the cylinder container, to check it.
Date: 6 Jun 2004 23:00:01
Message: <web.40c3da1f865d73e4ffb015460@news.povray.org>
> >Danny
> Alain
That's what it seems to be doing.  Is there any way to cut the sphere so
that the media is cut too?  Also, what am I supposed to be checking for?
