POV-Ray : Newsgroups : povray.newusers : Gaussian blur (PSF) Server Time
21 Mar 2026 10:53:17 EDT (-0400)
  Gaussian blur (PSF) (Message 1 to 9 of 9)
Subject: Gaussian blur (PSF)
Date: 18 Nov 2003 11:10:01
Message: <web.3fba444a555a70536b7c745d0@news.povray.org>
Hi all
Another question..
I used to generate images using a home-made C++ application, in which I was
able to simulate a Point-Spread-Function (doing a convolution with a square
kernel of a gaussian form).
In other words: when I was done constructing my image, all I needed to do is
to build a square kernel, say 5x5 pixels, filling it with a gaussian form.
Then, I applied this kernel to the image using convolution. This way, I
could achieve to simulate a blurring effect.
My question is, can PovRay do something like that? I thought of the
"focal_blur" keyword.. is it gaussian? is there a way to create our own
kernel?
Thanks!
O.
Subject: Re: Gaussian blur (PSF)
Date: 18 Nov 2003 11:48:33
Message: <3fba4d61$1@news.povray.org>
> kernel?
focal_blur is actually like a focal lense: some things will be in focus, and
some won't. This depends on the aperture value, and the overall quality
depends on several things: how close/far the objects are and how many
blur_samples you use. Gaussian-Blur, used for the entire image, can be
achieved with MegaPOV, if I'm not mistaken. But why would you want to blur
your image anyway?
"Tim Nikias v2.0"
Email: tim.nikias (@) nolights.de
Date: 18 Nov 2003 12:50:01
Message: <web.3fba5aa51a62f81d6b7c745d0@news.povray.org>
>your image anyway?
Ok, I'll take a look on MegaPOV then.
>your image anyway?
To simulate the PSF of a lens.
Thanks
O.
Date: 18 Nov 2003 14:12:32
Message: <cjameshuff-EF2BE6.14091818112003@netplex.aussie.org>
In article <web.3fba5aa51a62f81d6b7c745d0@news.povray.org>,
> >your image anyway?
With a 2D blur? In POV? Why?
A gaussian convolution blur won't be a very good approximation in the
first place, and I'm really wondering why you would want to do it in
POV, which although not designed for light simulation, has features that
would allow much better approximations to be done...such as actually
simulating the light traveling through the lens.
http://tag.povray.org/
Date: 18 Nov 2003 15:20:01
Message: <web.3fba7dec1a62f81d6b7c745d0@news.povray.org>
From a previous post I made, I had the feeling PovRAY couldn't do the
simulating of the lens.. maybe I misunderstood ?
So, I'd be able to simulate the PSF of a lens using PovRay? How can I do
that?
Thanks for your help!
O.
Date: 18 Nov 2003 15:41:36
Message: <cjameshuff-8B9194.15382318112003@netplex.aussie.org>
In article <web.3fba7dec1a62f81d6b7c745d0@news.povray.org>,
What previous post? I see a total of four threads started by you: the
one about sinusoidal shadows, 16 bit output, normal patterns, and this
thread.
> that?
I'd start by shining a light through it using photons. However, this
won't even come close to the same effect as blurring the image, so I
wonder if it is what you are looking for...you really need to clearly
state exactly what you are trying to accomplish.
Date: 18 Nov 2003 21:00:01
Message: <web.3fbacdb91a62f81d9e1a2890@news.povray.org>
Christopher James Huff wrote:
>In article <web.3fba7dec1a62f81d6b7c745d0[at]news.povray.org>,
Sounds to me that what he's looking for is in a sample file included with
POVRay, in \scenes\camera\focal_blur.
Date: 19 Nov 2003 08:55:01
Message: <web.3fbb761a1a62f81dd18b58c00@news.povray.org>
>thread.
In the sinusoidal shadow one.. it was said that true diffraction effect
cannot be achieved by PovRay.. that's what made me thought that it can't be
done..
Ok..
What I'm trying to do is this:
I'm trying to simulate the lens effect that I can observe experimentally.
I grab pictures with a camera/lens assembly of a particular object. Since
the lens is not perfect, it has a transfer function, the point-spread
function (PSF) which causes high-intensity pixels to blur its surrounding
neighbors.
In order to revert the effect, it's been modeled as a convolution blur
(gaussian or more complex).
Since I'm trying to simulate reality, I'm trying fo find a way, in PovRay,
to generate this effect.
For now, I'm simulating the effect by doing a convolution with a
user-defined kernel on my "hand"-simulated images.
Since I'm relatively new to PovRay3.5, I don't really know how to do it.
Tell me if you need more info,
Thanks,
O.
Date: 21 Nov 2003 17:10:42
Message: <cjameshuff-43A0F4.17052421112003@netplex.aussie.org>
In article <web.3fbb761a1a62f81dd18b58c00@news.povray.org>,
> done..
Right, diffraction can't be achieved. However, diffraction only accounts
for a small part of point spreading.
> neighbors.
Ok, this is "blooming", scattering/diffusion within the film or charge
overflow in the CCD. This kind of scattering would be possible to
simulate as a 2D convolution blur in the case of film, and a more
complex blur for CCDs.
I'm pretty sure point spreading due to imperfect optics would require
photon mapping with models of the actual optics, and is probably outside
the capability of POV-Ray (unless you implement it as a POV script, in
which case it will be very difficult and horribly slow and inefficient).
POV-Ray really isn't designed for this kind of image processing, but you
can do something similar by loading the image as an image_map pigment,
using functions to operate on each channel individually, and then using
an average pigment with the channel functions to recombine them into one
image. Alternatively, output in a form that POV-Ray's file I/O can read,
and write a POV script that reads the image, processes it, and writes
the blurred version out. You're really better off doing it in another
program...
