POV-Ray : Newsgroups : povray.newusers : Objects at large distances disappear (No matter how large they are) Server Time
18 Jan 2026 07:00:36 EST (-0500)
  Objects at large distances disappear (No matter how large they are) (Message 1 to 7 of 7)
Subject: Objects at large distances disappear (No matter how large they are)
Date: 29 Jun 2003 13:20:01
Message: <web.3eff1f21304fa07162c525300@news.povray.org>
I'm modelling the solar system, using the scale 1meter=1 povray unit.
However, I'm having trouble with objects disappearing when they're located
too far from the camera. I haven't found the exact distance, but it's
somewhere between 11000000.0 units and 10000000.0 units in distance.
So; the question I'm asking is this:
Is there a way to increase the distance to the "far clipping plane" of the
camera in povray?
Of course I can scale everything down, that works as a workaround, but I'm a
curious guy, and it would be interesting to learn why povray works in this
way.
David Ahlard, Stockholm, Sweden
Subject: Re: Objects at large distances disappear (No matter how large they are)
Date: 29 Jun 2003 14:04:16
Message: <3EFF2ADB.22740CC6@pacbell.net>
> camera in povray?
No, it is hard coded into the program.
> way.
Floating point accuracy. There is a set epsilon values used to avoid mathematical
inaccuracies. Very large values, such as those used in astromonical distances,
exceed the set epsilon value.
Ken Tyler
Date: 29 Jun 2003 19:55:01
Message: <web.3eff7ba2cf0c8fec62c525300@news.povray.org>
Thank you for the answer. I'm scaling everything down. Another thing that
turned up to be a problem was the 50 kilometer atmosphere of earth.
Everything turned blue. :)
David Ahlard, Sweden
>> camera in povray?
>> way.
>Ken Tyler
Date: 30 Jun 2003 15:29:27
Message: <3f008f97@news.povray.org>
Actually I think that the imposed maximum value for distances is much
smaller than would be possible with 64-bit floating point numbers (which
POV-Ray uses) at a good precision, but I suppose that the principle
has been "better safe than sorry", which might be a good idea.
  I think that this maximum distance is easily modifiable in one of
the source code files (and then you could recompile a custom version
with a much higher limit).
Date: 30 Jun 2003 15:39:40
Message: <3f0091fc@news.povray.org>
  Well, a small correction: This is subjective.
  It's rather easy to reach floating point accuracy limits even with
the current limitations.
  In regular scenes you will probably never find any artifacts due to
inaccuracy, but this simple scene shows that you don't even need very
extreme values to get artifacts. In this case the artifacts are produced
because of an unusually small 'angle' value of the camera:
camera { location -z*1e5 look_at 0 angle .002 }
light_source { <10,20,-30>, 1 }
sphere { 0,1 pigment { rgb 1 } }
  There's no "fix" for this possible. (Well, the only fix would be using
floating point numbers with many more bits, eg. 128 bits long or larger,
but with current hardware that's not possible.)
Date: 30 Jun 2003 15:59:10
Message: <3f00968e$1@news.povray.org>
In article <3f008f97@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
IMHO this dis cussion or detail does not belong here at all. This is
povray.newusers and your reply only adds to the confusion of a new user
rather than helping at all.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 30 Jun 2003 17:09:51
Message: <3f00a71f@news.povray.org>
  I apologize.
