POV-Ray : Newsgroups : povray.newusers : Round box edge Server Time
10 Apr 2026 12:28:04 EDT (-0400)
  Round box edge (Message 1 to 10 of 10)
Subject: Round box edge
Date: 9 Dec 2002 17:30:06
Message: <web.3df51889472923f770499b5a0@news.povray.org>
I want to round over an edge of a box. I have tried the "Round_Box_* " macro
but it rounds all edges. The z box-edge length is less then x and y. The z
box-edges are those that I want rounded to a given radius.
I appreciate any help you can give.
Thanks.
Subject: Re: Round box edge
Date: 9 Dec 2002 18:40:55
Message: <3df52a07$1@news.povray.org>
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
> In article <web.3df51889472923f770499b5a0@news.povray.org>,
macro
z
> Do it the same way the macros do it, with CSG. If you only want the
> edges along the z axis rounded, a union of 2 boxes and 4 cylinders
> should be sufficient.
+two planes differenced if you want true smooth surfaces and no coincidient
surfaces.
-tgq
Date: 9 Dec 2002 19:10:21
Message: <chrishuff-115A21.19070509122002@netplex.aussie.org>
In article <3df52a07$1@news.povray.org>,
> surfaces.
I don't think the coincident surfaces are a problem here...though one
surface will sometimes be hit before the other, they both have the same
normal and texture, it shouldn't be a problem. (at least, I've never had
a problem with this situation)
http://tag.povray.org/
Date: 9 Dec 2002 20:20:21
Message: <3df54155@news.povray.org>
coincidient
> > surfaces.
I suppose you are right here, but you run into problems if you want to
difference this shape from another one for whatever reason.  I just always
avoid coincident surfaces as a rule just to be safe.
-tgq
Date: 9 Dec 2002 21:40:03
Message: <web.3df553866a56a85570499b5a0@news.povray.org>
Christopher James Huff wrote:
>In article <web.3df51889472923f770499b5a0[at]news.povray.org>,
I don't understand how a union of these objects will remove the sharp corner
that lies along the z axis. It seems to me that a union will simply result
in two (why two?) boxes with 4 cylinders (lying along the z axis) simply
buried in the boxes. An explanation would certainly help this newbie.
Thanks.
Date: 9 Dec 2002 21:42:48
Message: <3df554a8$1@news.povray.org>
corner
> Thanks.
Try this:
  union{
    box{<-2,0,-1> <2,1,1>}
    box{<-1,0,-2> <1,1,2>}
    cylinder{0 y 1 translate <1,0,1>}
    cylinder{0 y 1 translate <1,0,-1>}
    cylinder{0 y 1 translate <-1,0,1>}
    cylinder{0 y 1 translate <-1,0,-1>}
Date: 9 Dec 2002 22:52:36
Message: <chrishuff-CD5C78.22491709122002@netplex.aussie.org>
In article <web.3df553866a56a85570499b5a0@news.povray.org>,
Two boxes arranged to make a cross shape, with the cylinders filling in
the gaps in the corners:
    ___
 __|___|__
|__|___|__|
   |___|
Only 3/4 of each cylinder overlaps with the boxes. The macros do a
similar thing, using 3 boxes to make a 3D cross.
Date: 10 Dec 2002 08:30:04
Message: <web.3df5ec086a56a85570499b5a0@news.povray.org>
>corner
>> Thanks.
>Try this:
>  union{
Thanks all! It sure is obvious when one sees the solution! (smack on
forehead!!!).
Date: 11 Dec 2002 09:15:05
Message: <web.3df747ce6a56a855de2a6cfb0@news.povray.org>
>macro
>z
>surfaces.
>-tgq
i don't understand what coincidient surfaces are... what can be a problem if
you don't difference two planes?
i guess it's about pov who don't know what surface to take while rendering.
the surface from box1 or box2. am i right?
Date: 11 Dec 2002 10:52:21
Message: <3df75f35$1@news.povray.org>
if
rendering.
Yes, if two surfaces ocupy the exact same plane, POV does not know which
surface to render first and often the result is a speckled unwanted result.
In the following code, the object subtracted on the right shows the
coincident surface problem, the object subtracted on the left is the
equivilant object with coincident surfaces removed. Hope this helps.
-tgq
--8<--
camera{
  up y
  angle 45
  location <0,10,-10>
  look_at  0
light_source{0 rgb 1 translate y*10}
background {rgb 0.5}
#declare CoincidentSurface=
union{
#declare NoCoincidentSurface=
difference{
  union{
    box{<-2,-1,-1> <2,2,1>}
    box{<-1,-1,-2> <1,2,2>}
    cylinder{<0,-1,0> <0,2,0> 1 translate <1,0,1>}
    cylinder{<0,-1,0> <0,2,0> 1 translate <1,0,-1>}
    cylinder{<0,-1,0> <0,2,0> 1 translate <-1,0,1>}
    cylinder{<0,-1,0> <0,2,0> 1 translate <-1,0,-1>}
  plane{y, 0}
  plane{-y, -1}
difference{
  box{<-6,-1,-3><6,0.9,3>pigment{rgb <1,0,0>}}
  object{CoincidentSurface translate <3,0,0>}
  object{NoCoincidentSurface translate <-3,0,0>}
--8<--
