POV-Ray : Newsgroups : povray.newusers : Highlight Effect Server Time
11 Apr 2026 00:02:07 EDT (-0400)
  Highlight Effect (Message 1 to 10 of 13)
Subject: Highlight Effect
Date: 24 Mar 2004 13:46:40
Message: <vhl360dkcd3b2l630nvvo05b1s0714s1p3@4ax.com>
Having been around POV-Ray for some time, I'm sure I should know how
to do this, but somehow the proper effect continues to elude me...
I have some text in my scene I'd like to draw special attention to.
It would be rather nice to have some sort of 'highlight' effect where
the particular word I'd like to emphasize flashes as if a bright light
were crossing a shiny metal surface.  Try as I might, I cannot seem to
reproduce this effect to my satisfaction.
Eventually, I'll animate the effect to show a diagonal flash of light
passing over the word, sort-of like you might see in some 1970's
Marvel Comics type film.
Any ideas?
- How
Subject: Re: Highlight Effect
Date: 24 Mar 2004 15:45:52
Message: <4061f380$1@news.povray.org>
"How Camp" <kro### [at] hotmailcom> wrote in message
news:vhl360dkcd3b2l630nvvo05b1s0714s1p3@4ax.com...
Something like the super- (ha ha! little pun about comics) simple script
below?
You could probably reflect the light's box in the overlying plane too for a
lens flare effect, but what's really needed there is a true lens flare.
 location <0,0,-3>
 look_at <0,0,0>
#declare LightBox=box {-1,1 pigment {rgb 1} finish {ambient 1} scale
<0.25,5,0.1> rotate -45*z}
light_source {
 -10*z,1
 looks_like {LightBox}
 rotate <0,(45-90*clock),0>
//background {color rgb 1}
plane {
 z,-0.25
  rgbt 0.99
 normal {
  bumps 0.1 scale 0.001
 finish {
  ambient 0 diffuse 1
  specular 0.05 roughness 0.005
text {
 ttf "times.ttf"
 "Flashy Text", 0.25, 0
  color rgb <1,0.9,0.3>
 finish {
  ambient 0.1 diffuse 0.2
  specular 0.5 roughness 0.001
  metallic brilliance 2
  reflection {
   <1,0.9,0.3>,0.5
   metallic
 scale 0.5 translate <-1.25,-0.125,-0.125>
Bob H.
http://www.3digitaleyes.com
Date: 24 Mar 2004 16:17:03
Message: <r3t360pqf1patsd6kfftqaeveiobov4ukk@4ax.com>
On Wed, 24 Mar 2004 14:45:46 -0600, "Hughes, B."
>below?
Thanks, Bob, this is exactly the sort of effect I'm looking for.  I've
tried this approach before, just as you did, with varying success.
However, I had not thought to use "looks_like" in my light_source to
limit it's effects.  Is there a way to make a particular light only
interact with a single object?
- How
Date: 24 Mar 2004 17:24:33
Message: <40620aa1$1@news.povray.org>
news:r3t360pqf1patsd6kfftqaeveiobov4ukk@4ax.com...
Very welcome.
If you use version 3.5 (also beta 3.6), there is. Let's see... the 3.5 docs
tell more about it in section 6.5.8 if you want to check into that more. My
example would be like:
light_group {
    light_source {...} // Only this light affects the object included.
    text {...} // Included object.
    global_lights off // No other lights allowed to affect this.
light_source {...} // This one doesn't affect the above, unless
global_lights is 'on'.
Date: 24 Mar 2004 21:46:10
Message: <p0i460h6nlkc7j39htnp716klulc9r7i3g@4ax.com>
On Wed, 24 Mar 2004 16:24:27 -0600, "Hughes, B."
>light_group {
Perfect!  Now, I just need to make the effect quite brilliant.  That
shouldn't be too difficult.  Thanks for the help!
- How
Date: 25 Mar 2004 00:07:54
Message: <l6q460pfgdvl7fjj4e550j17ekkbuj5tie@4ax.com>
On Wed, 24 Mar 2004 20:47:54 -0600, How Camp <kro### [at] hotmailcom>
wrote:
>Perfect!
I spoke too soon.  My understanding from reading the docs (6.5.8, as
Bob pointed out) is that a light_group can be formed with a
light_source and another object, and the indicated light_source will
only affect the object(s) in the light_group.
...So, what am I doing wrong in the following scene?  Somehow, my
light in the light_group is affecting the two text objects outside the
group.
Incidentally, this effect seems to disappear if I comment out the
'looks_like {LightBox}' line in the scene.
 location <0,0,-5>
 look_at <0,0,0>
#declare LightBox=
box {
   <-1,-5,-1>,<1,5,1>
      pigment {rgb 1}
      finish {ambient 1}
   scale <0.25,5,0.1>
   rotate -45*z
//light_source {<-10,5,-10>,1}
#declare MainTex =
   finish {
      reflection {
         <1,0.9,0.3>,0.5
         metallic
light_group {
   light_source {
      -10*z,<1,0,0>
      rotate <0,(45-90*0.5),0>
   text {
      ttf "times.ttf"
      texture {MainTex}
   global_lights
text {
   ttf "times.ttf"
   "Top Text Above", 0.25, 0
   texture {MainTex}
   scale 0.5 translate <-1.25,0.625,-0.125>
text {
   ttf "times.ttf"
   "Bottom Text Below", 0.25, 0
   texture {MainTex}
   scale 0.5 translate <-1.25,-0.725,-0.125>
- How
Date: 25 Mar 2004 06:05:37
Message: <opr5ezuie0p4ukzs@news.povray.org>
> wrote:
>> Perfect!
> group.
<snip code>
Remove the finish {ambient 1}  from the LightBox, light_group constrains
the light_source but the box is producing it's own 'light' from the
ambient which is not stopped and is being reflected in the text, keep the
ambient and change the LightBox to pigment {rgb <0,1,1>}  and you should
see what I mean.
HTH
Phil
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
Date: 25 Mar 2004 10:59:35
Message: <406301e7$1@news.povray.org>
"Phil Cook" <phi### [at] nospamdeckingdealscouk> wrote in message
news:opr5ezuie0p4ukzs@news.povray.org...
Yep, unfortunately light groups are for lights and do not do anything else
to the objects in the scene except to shine for what's included in their
respective groups.
CSG is possble, so there's some chance of fixing it up using that. At least,
I've found that bounding the looks_like object to the text seems to be one
possibility. Only problem with it is the illumination is, of course, then
from that same text. You can face the camera the other way and see that
using the changed script below.
 location <0,0,-5> // +5 z to see light object
 look_at <0,0,0>
#declare MainTex =
   finish {
      reflection {
         <1,0.9,0.3>,0.5
         metallic
#declare FlashyText=
   text {
      ttf "times.ttf"
#declare LightBox=
box {
   <-1,-5,-1>,<1,5,1>
      pigment {rgb 1}
      finish {ambient 1}
   scale <0.25,5,0.1>
   rotate -45*z
   bounded_by {FlashyText scale <0.5,5,1>}
light_group {
   light_source {
      -10*z,<1,0,0>
      rotate <0,(30-60*clock),0>
   object {FlashyText texture {MainTex}}
   global_lights
text {
   ttf "times.ttf"
   texture {MainTex}
text {
   ttf "times.ttf"
   texture {MainTex}
Date: 25 Mar 2004 14:36:41
Message: <d3d6609f16kr9ohjddq05jkq10r3b2ilh8@4ax.com>
On Thu, 25 Mar 2004 09:59:28 -0600, "Hughes, B."
>respective groups.
Thank you both - this makes perfect sense.  I'll see what I can come
up with.
- How
Date: 26 Mar 2004 05:26:49
Message: <opr5gsqebep4ukzs@news.povray.org>
On Thu, 25 Mar 2004 09:59:28 -0600, Hughes, B. <omn### [at] charternet>
> else
> respective groups.
> least,
> one
<snip code>
Shame there's no such thing as an object_group equivalent though I suspect
that would be computationally hideous. Quite funky though for effects like
the sphere in "Sphere" reflects the room but not the people.
Phil
