POV-Ray : Newsgroups : povray.newusers : fn_function and other stuff Server Time
21 Mar 2026 14:01:54 EDT (-0400)
  fn_function and other stuff (Message 1 to 5 of 5)
Subject: fn_function and other stuff
Date: 9 Nov 2003 22:03:41
Message: <matt-pace-1AB5A2.19034009112003@netplex.aussie.org>
So as you know, I am stumbling through the isosurface qualities of POV,
when I came across a site where someone used an identifier fn_function
to make a pigment modifier (bozo in this case) apply to both a height
field and an isosurface.  Can anyone either explain this (as he didnt
really) or point me to a place which does?  He used this as a way to
make some pretty nifty landscapes, so if anyone knows of a site which
shows some isosurface landscaping tricks, that would be awesome too.
Thanks a lot, Matt
Subject: Re: fn_function and other stuff
Date: 9 Nov 2003 22:53:18
Message: <cjameshuff-7C4A9E.22515409112003@netplex.aussie.org>
In article <mat### [at] netplexaussieorg>,
Those are simply pattern functions defined in functions.inc. As
expected, they are documented in the functions.inc documentation. You
can use the same syntax to make your own versions.
http://tag.povray.org/
Date: 9 Nov 2003 23:54:44
Message: <mWcKaOAikxr$EwJy@econym.demon.co.uk>
>Thanks a lot, Matt
There's a section in my Isosurface Tutorial that looks at the difference
between using a function to generate a heightfield and using it to
generate an isosurface.
http://www.econym.demon.co.uk/IsoTut/patterns.htm#hf
In this case I used function{ pattern{ leopard... }} but I could have
used function{f_bozo(x,0,z)}.
Mike Williams
Gentleman of Leisure
Date: 10 Nov 2003 06:16:09
Message: <3faf7379@news.povray.org>
Mike Williams <nos### [at] econymdemoncouk> wrote in
news:mWcKaOAikxr$EwJy@econym.demon.co.uk:
This one works:
http://www.econym.demon.co.uk/isotut/patterns.htm#hf
You can also find an example of a function based height-
field within the source files in this post of mine:
http://news.povray.org/povray.binaries.scene-files/33557
(Source code for "Isomountains" posted by me 26. Oct to
povray.binaries.scene-files)
Tor Olav
Date: 10 Nov 2003 20:30:48
Message: <matt-pace-8931B2.17303410112003@netplex.aussie.org>
> Thanks a lot, Matt
Thanks a lot guys, you are awesome.  Those all helped a lot!
