POV-Ray : Newsgroups : povray.newusers : rgb 1 Server Time
19 Sep 2025 11:23:19 EDT (-0400)
  rgb 1 (Message 1 to 6 of 6)
Subject: rgb 1
Date: 11 Jul 2002 17:43:48
Message: <Xns9248F0D24FE62raf256com@204.213.191.226>
Box with texture
    pigment { color rgb 1 }
    finish { diffuse 1 brilliance 0 }
is lighten with light_source color rgb 1
with assumed_gamma 2.0 (and simmilar 1.0)
shound't this have rgb <255,255,255> in rendered image ? (image is simple -
no fog, no radiosity etc) it has something about (220,220,220) or even
darker
is this o.k. to use objects with pigment color rgb 1.5 ?
Subject: Re: rgb 1
Date: 11 Jul 2002 20:59:04
Message: <chrishuff-0E61E9.19561711072002@netplex.aussie.org>
In article <Xns### [at] 204213191226>,
The manual recommends using assumed_gamma 1 for new scenes.
> darker
Pure white pigment, pure white light source, a diffuse of 1 and a
brilliance of 0...there must be something else in the scene that makes
it give this result. Could you post a minimal scene demonstrating this?
Light values above 1 are perfectly acceptable. Even negative values are
allowed, though they don't correspond to any real-world effect. Pigment
values above 1 (or even equal to 1) aren't realistic, but they are
allowed.
Subject: Re: rgb 1
Date: 12 Jul 2002 07:31:23
Message: <Xns92498A2E21A62seed7@povray.org>
in news:Xns### [at] 204213191226 Rafal 'Raf256' Maj
depends on the angle the light_source makes with the box.
Ingo
Subject: Re: rgb 1
Date: 12 Jul 2002 11:39:49
Message: <Xns9249B31B1E3AAraf256com@204.213.191.226>
ingo <ing### [at] homenl> wrote in news:Xns### [at] povrayorg:
with brilliance 0 alsow ?
Subject: Re: rgb 1
Date: 12 Jul 2002 13:25:50
Message: <Xns9249C646A1EF3seed7@povray.org>
Sorry, my reply was inaccurate.
With ambient 1 the object should always be bright white, even if there
is no light_source and independent of the brilliance (and
assumed_gamma). And it is. Dit you check the pixel value with a color
picker or with a hex-viewer. I did the latter and the result is FF.
Regarding 'brilliance 0', noting is mentioned in the docs. Maybe someone
could have a peek at the source and tell us what it does.
Ingo
Subject: Re: rgb 1
Date: 12 Jul 2002 15:04:08
Message: <chrishuff-C980A8.14012512072002@netplex.aussie.org>
In article <Xns### [at] povrayorg>, ingo <ing### [at] homenl>
A brilliance value of 0 should turn off all shading from direct light
(surface shading because of the angle of incoming light to the surface
normal). There is nothing in the given code that would explain a result
that wasn't pure white, which is why I asked for additional code.
