POV-Ray : Newsgroups : povray.newusers : animating wood Server Time
16 May 2026 14:42:27 EDT (-0400)
  animating wood (Message 1 to 9 of 9)
Subject: animating wood
Date: 9 Mar 2017 00:11:58
Message: <58c0e41e$1@news.povray.org>
30 years on and I have a newbie problem.
I notice that my wood textures change depending on the camera angle.
This is irksome.  i.e.
http://www.buckosoft.com/tteoac/video/frames/ttho1909.png
http://www.buckosoft.com/tteoac/video/frames/ttho1912.png
texture{
     P_WoodGrain1A
     color_map { M_Ash }
     rotate x*2*rand(FamRoomFloorRand)
     scale 1.5*inches*rand(FamRoomFloorRand)+0.75*feet
     rotate y*90
     translate <rand(FamRoomFloorRand)*100*inches,
                rand(FamRoomFloorRand)*100>
I don't recall the dude who does the wood puzzles having this issue.
dik
Subject: Re: animating wood
Date: 9 Mar 2017 02:59:58
Message: <58c10b7e@news.povray.org>
> texture{
>   pigment {
>     P_WoodGrain1A
>     color_map { M_Ash }
>     rotate y*90
Isn't that because of all those rand()? In an animation I would not be
surprised if this happened. The trick would be to keep the texture
declaration outside of the video loop I guess.
Date: 9 Mar 2017 03:42:12
Message: <58c11564$1@news.povray.org>
>> texture{
>>   pigment {
>>     P_WoodGrain1A
>>     color_map { M_Ash }
>>     rotate y*90
I suspect that too.
Mike what happens if you animate the scene without moving the camera?
Regards
Date: 9 Mar 2017 09:21:32
Message: <58c164ec@news.povray.org>
Am 09.03.2017 um 06:11 schrieb dick balaska:
> texture{
>   pigment {
>     P_WoodGrain1A
>     color_map { M_Ash }
>     rotate y*90
I suspect what you're seeing isn't actually the wood grain, but a moiree
pattern created by that wood grain and the pixel grid.
Unfortunately, when the "frequency" of a pattern almost coincides with
the "frequency" of the pixel grid, POV-Ray's standard anti-aliasing
offers little help.
What you would need to do is to enforce some stochastic oversampling,
for example by adding a bit of focal blur. Alternatively, you might want
to try UberPOV's anti-aliasing mode 3.
Date: 9 Mar 2017 14:18:17
Message: <58c1aa79$1@news.povray.org>
Am 2017-03-09 02:59, also sprach Thomas de Groot:
No, those are so each board is different. You know,
loop {
   box {
     0,1
       wood
       translate <rand,rand,rand>
The TV unit has no rands, and it "sparkles" as the camera moves past it.
This tile floor is built similarly with T_Stone8 and lots of rands
http://www.buckosoft.com/tteoac/video/frames/ttho0109.png
and it doesn't suffer the same "random" fate.
dik
Date: 23 Mar 2017 01:25:04
Message: <58d35c30$1@news.povray.org>
Am 2017-03-09 09:21, also sprach clipka:
https://xkcd.com/1814/
It sure looks and acts like a moire.
But, but, but, why is it only an issue when I change the angle of the
camera on the object, and not the distance.  And why do I only see this
with woods at any scale and not stones or other fractals at any scale.
It seems odd.
Focal blur is out of the question. UberPOV, hmmm...
dik
Date: 23 Mar 2017 02:51:15
Message: <58d37063$1@news.povray.org>
Am 23.03.2017 um 06:25 schrieb dick balaska:
Hmm... dunno about that. You might have to provide a genuine animation
where we can see the thing in action.
'Cause wood tends to be more regular than stones or fractals?
The more noise you have in a pattern, the less likely you are to get a
moire effect.
Date: 23 Mar 2017 11:38:45
Message: <58d3ec05$1@news.povray.org>
> It seems odd.
You also get a moiré effect with onion, gradient and checker. If you use
the cells pattern the moiré is almost inexistant.
wood, checker and onion are periodic pattern, cells is not.
Most stone are also aperiodic. fractals are also aperiodics.
Periodic or repeating patterns, when scalled small enough cause moiré,
while irregular patterns don't.
By small enough, I mean that the details are pixel sized or smaller.
Date: 30 Mar 2017 19:05:40
Message: <58dd8f44$1@news.povray.org>
Thought just hit me, if mostly angle dependent, using the aoi pattern to
gradually change from a non-banded wood texture (average-wood-color) to
the normal banded wood texture I suspect would help.
Rendering larger images - no AA - and shrinking to the final size
perhaps a path too.
Bill P.
