POV-Ray : Newsgroups : povray.newusers : Pigment colour from RGB functions Server Time
15 Apr 2025 23:13:36 EDT (-0400)
  Pigment colour from RGB functions (Message 1 to 10 of 10)
Subject: Pigment colour from RGB functions
Date: 20 May 2013 12:32:38
Message: <519a5026$1@news.povray.org>
I've been digging about in the docs for a while and can't come up with
an obvious way to achieve this, although I'm sure it must be fairly
straightforward.
Suppose I have a mathematical formula to calculate the R, G and B values
of a pigment based on the coordinates (x,y,z), how to write that in POV?
I started by writing 3 functions to calculate the R G and B components,
but then I got stuck trying to combine them in the pigment part of an
object. What's the best way to do this?
I want to write this:
pigment{color rgb <functionR,functionG,functionB>}
Subject: Re: Pigment colour from RGB functions
Date: 20 May 2013 14:15:01
Message: <web.519a67c283779f7f21be1230@news.povray.org>
I don't know if this is the best way, but this is what I do.
#local P_R=pigment{
  function{functionR(x,y,z)}
  color_map{[0,rgb<0,0,0>][1,rgb<5,0,0>]}
#local P_R=pigment{
  function{functionG(x,y,z)}
  color_map{[0,rgb<0,0,0>][1,rgb<0,5,0>]}
#local P_R=pigment{
  function{functionB(x,y,z)}
  color_map{[0,rgb<0,0,0>][1,rgb<0,0,5>]}
#local P_F=pigment{
  function{functionF(x,y,z)}
  color_map{[0,rgbf<0,0,0,0>][1,rgbf<0,0,0,5>]}
#local P_T=pigment{
  function{functionT(x,y,z)}
  color_map{[0,rgbt<0,0,0,0>][1,rgbt<0,0,0,5>]}
pigment{
  average
  pigment_map{[1,P_R][1,P_G][1,P_B][1,P_F][1,P_T]}
If you eliminate both the filter and transmit parts, change the 5s to 3s.
I hope this helps.
Date: 21 May 2013 11:51:10
Message: <519b97ee$1@news.povray.org>
> #local P_R=pigment{
> #local P_R=pigment{
> #local P_R=pigment{
> #local P_F=pigment{
> #local P_T=pigment{
> pigment{
>    average
> I hope this helps.
I had thought of doing such a thing but I don't know in my code how
large the return values of the function will be (certainly not limited
to 1). If there is no better alternative then I'll end up with something
like this:
  #local K = 1e8;
  #local P_R=pigment{
     function{ functionR(x,y,z)/K }
     color_map{ [0,rgb <0,0,0>] [1,rgb <3*K,0,0>] }
But obviously I have to choose K large enough for all possible return
values (maybe I can determine the upper limit with some maths).
Date: 21 May 2013 12:50:01
Message: <web.519ba54783779f7f826ce7c10@news.povray.org>
Scott,
Not sure how much it helps, but here's the method I use:
#declare PFunc = function{pigment{bozo}}
#macro RGBFunc(Channel)
 PFunc(x, y, z)
 #switch(Channel)#case(0).x#break #case(1).y#break #case(2).z#break #end
sphere{
 0, 1
 pigment{
  average
  pigment_map{
   [1 function{RGBFunc(0)} color_map{[0 rgb 0][1 rgb x*3]}]
   [1 function{RGBFunc(1)} color_map{[0 rgb 0][1 rgb y*3]}]
   [1 function{RGBFunc(2)} color_map{[0 rgb 0][1 rgb z*3]}]
That's just the bare-bones setup; there's still a lot of room for adjustment.
> like this:
>   #local K = 1e8;
>   #local P_R=pigment{
I've had to do it that way, too. In my case I wanted to cover the entire color
range of an hdr image... but I think I just used 256 in the end. Might account
for some color banding I've seen since then ;)
Sam
Date: 21 May 2013 20:40:27
Message: <519c13fb$1@news.povray.org>
> to 1).
I think there is no elegant way to solve this except for your scaling.
But defining functions without known limit for use as RGB pigment would
seem to be a problematic approach to begin with ... even without the
technicality of turning a function into a pigment you need to decide
on a scaling if the function is not 0 to 1 (or worse, unbounded).
Date: 21 May 2013 20:43:15
Message: <519c14a3$1@news.povray.org>
Christian Froeschlin wrote:
> even without the technicality of turning a function into a pigment
> you need to decide on a scaling if the function is not 0 to 1
unless of course you intentionally want to have parts of the
pigment potentially return more light than is incoming.
Date: 22 May 2013 03:09:53
Message: <519c6f41$1@news.povray.org>
It's for a sky_sphere, so will be used as an emission (to simulate a
realistic sky colour).
I'm looking at the formulas now to see if there is any easy way to pluck
out a kind of global brightness constant that I can then apply
afterwards instead, which would guarantee a certain range of return
values from the functions.
Date: 22 May 2013 11:39:51
Message: <kurtzlepirate-785486.17395022052013@news.povray.org>
> straightforward.
#macro fnR(x,y,z)
  2*x+y+z
#macro fnG(x,y,z)
  x+2*y+z
#macro fnG(x,y,z)
  x+y+2*z
#macro fnColor(thisPoint)
  rgb <fnR(thisPoint.x),fnR(thisPoint.z),fnR(thisPoint.z)>
pigment{color fnColor(<a,b,c>) }
klp
Date: 22 May 2013 11:47:57
Message: <519ce8ad$1@news.povray.org>
> #end
That won't work for me, as the RGB values depend on the coordinates of
the object the pigment is applied to (so it's not a constant colour).
I'm using the method waggy suggested, but modified to cope with large
values. I just wondered if there was a neater way to specify this,
that's all.
Date: 22 May 2013 12:05:01
Message: <web.519cec9783779f7f21be1230@news.povray.org>
> to 1).
One function I've used to guarantee all finite values get mapped within [0,1) is
this.
1-1/(1+abs(functionR))
However, emission pigments having values greater than unity is not unusual. A
global brightness parameter seems like the way to go.
