POV-Ray : Newsgroups : povray.newusers : Seeing it closer Server Time
10 Apr 2026 01:48:55 EDT (-0400)
  Seeing it closer (Message 1 to 6 of 6)
Subject: Seeing it closer
Date: 31 Dec 2005 05:03:08
Message: <43b6575c$1@news.povray.org>
Hi all,
I've done this some tima ago and I want this object bigger. Instead of
multiply all by 2 or by any number, how can I use the camera the see it
closer?
The code is de following :
location  <7, 25, -10> look_at   <5, 3, 0> }
light_source { <-100, 200, -100> color rgb 1 }
background { White }
#declare Direction = vnormalize( <5, 3, 0> - <7, 25, -10> );
global_settings { max_trace_level 20 }
merge{
sphere { <0, 0, 0>, 1
translate -0.5*x
sphere { <0, 0, 0>, 0.5
translate 0.5*x
scale <1.2, 0, 0>
pigment { rgbf <0.9, 0.9, 0.9, 0.95> }
interior_texture { pigment { gradient -x
pigment_map { [0.01 rgbf <0, 1, 0, .95>]
[0.01 rgbf <0, 1, 0, 0.6>]
[0.65 rgbf <0.97, 0.99, 0.98, 0.6>]
[0.65 rgbf <0.97, 0.99, 0.98, 0.6>]}
scale 2
pigment { rgbf <0.97, 0.99, 0.98, 0.6> } // Part de dins.
rotate <0, 0, 0>
scale 1.2 //Scala del merge.
clipped_by { plane { y, 0.01 } translate <0, 0, 0> }
hollow on // Per buidar-lo.
interior_texture { pigment { rgbf <.9, .9, .9, 0.8> } } //Part de fora.
translate <5.5, 8, 0> + Direction // Part traduir l'objecte sencer.
rotate <0, 0, 0> + Direction
//Actin patch
torus { 0.5, 0.32
pigment { color Red }
scale 0.9
translate <17, 40, 0> + Direction*150
torus { 0.5, 0.32
scale 0.9
translate <16, 42, 0> + Direction*150
torus { 0.5, 0.32
scale 0.9
translate <15, 44, 0> + Direction*150
torus { 0.5, 0.32
scale 0.9
translate <17, 37, 0> + Direction*150
torus { 0.5, 0.32
scale 0.9
translate <16, 34, 0> + Direction*150
torus { 0.5, 0.32
scale 0.9
translate <14.5, 32.3, 0> + Direction*150
torus { 0.5, 0.32
scale 0.9
translate <9, 31, 0> + Direction*150
Thanks in advance,
Oleguer
Subject: Re: Seeing it closer
Date: 31 Dec 2005 08:20:00
Message: <web.43b68482bab7a38736af16e70@news.povray.org>
either you reduce the camera angle
camera { location  <7, 25, -10> look_at   <5, 3, 0> angle 15 }
(then you will see that your object is not centered)
or you reduce the distance of the camera
camera { location  .5*<7, 25, -10> look_at   <5, 3, 0> }
(and will then see that your object doesn't look right anymore)
First method recommended with
look_at <5, 7.5, 0>
Regards Roman
"Oleguer Vilella" <ole### [at] infonegociocom> wrote:
> Hi all,
> closer?
> camera {
> merge{
> translate -0.5*x
> translate 0.5*x
> scale <1.2, 0, 0>
> scale 2
> rotate <0, 0, 0>
> //Actin patch
> torus { 0.5, 0.32
> scale 0.9
> torus { 0.5, 0.32
> scale 0.9
> torus { 0.5, 0.32
> scale 0.9
> torus { 0.5, 0.32
> scale 0.9
> torus { 0.5, 0.32
> scale 0.9
> torus { 0.5, 0.32
> scale 0.9
> torus { 0.5, 0.32
> scale 0.9
> Thanks in advance,
> Oleguer
Date: 31 Dec 2005 10:44:53
Message: <43b6a775$1@news.povray.org>
Yeah, what a silly question! :-)
That should work:
location  <7, 25, -10> look_at <5, 7.5, 0> angle 15 }
Happy new year to all!
Oleguer
news:web.43b68482bab7a38736af16e70@news.povray.org...
> look_at <5, 7.5, 0>
> Regards Roman
>> Hi all,
>> closer?
>> camera {
>> merge{
>> translate -0.5*x
>> translate 0.5*x
>> scale <1.2, 0, 0>
>> scale 2
>> rotate <0, 0, 0>
>> //Actin patch
>> torus { 0.5, 0.32
>> scale 0.9
>> torus { 0.5, 0.32
>> scale 0.9
>> torus { 0.5, 0.32
>> scale 0.9
>> torus { 0.5, 0.32
>> scale 0.9
>> torus { 0.5, 0.32
>> scale 0.9
>> torus { 0.5, 0.32
>> scale 0.9
>> torus { 0.5, 0.32
>> scale 0.9
>> Thanks in advance,
>> Oleguer
Date: 1 Jan 2006 21:40:06
Message: <43b89286$1@news.povray.org>
Oleguer Vilella nous apporta ses lumieres en ce 2005-12-31 10:44:
> That should work:
> camera {
> Regards,
> Oleguer
>>look_at <5, 7.5, 0>
>>Regards Roman
You can also enter a direction vector and make it longer than 1 (the default value
been 1*z or
<0,0,1>). Something like:
direction 2.0*z // This will reduce the field of view by half
Place that before the look_at statement.
Date: 11 Jan 2006 12:34:48
Message: <43c541b8@news.povray.org>
What's that curious object shaped quite like a cartoon duck's head? I
don't think I could find a better view than Roman Reiner's.
However, I'm wondering about a side matter if you don't mind the
off-topic turn:
Sure this particular use of "translate" as a POV keyword should be
translated--heheh--into Catalan as "traduir", and not something like
Spanish "trasladar"?
Date: 11 Jan 2006 13:52:27
Message: <43c553eb@news.povray.org>
I didn't traslated all to English because here the main code was the camera.
The object it's a half yeast.
Thanks for your help!
Oleguer
news:43c541b8@news.povray.org...
> However, I'm wondering about a side matter if you don't mind the off-topic
> turn:
