POV-Ray : Newsgroups : povray.newusers : ERROR IN ISECT()?---developers lurking? Server Time
18 May 2026 11:37:49 EDT (-0400)
  ERROR IN ISECT()?---developers lurking? (Message 1 to 8 of 8)
Subject: ERROR IN ISECT()?---developers lurking?
Date: 12 Feb 2004 13:24:44
Message: <402bc4ec$1@news.povray.org>
In an earlier posting (on 20040121), I requested info on "scanning"
unions and differences of objects to read off height-field data from the
composite structure and thence out to a text file. A day or two after this
I discovered the isect() function, which seems to do the trick.
Except....that when the vector you're using to intersect with the intended
surface strikes the junction between two objects in this composite
structure,
sometimes it shoots through the seam and intersects the surface on the
opposite
side.
Here's a test case.
Create a cube 4 units on a side, centered at the origin.
Create a sphere of radius 1, offset 2 units along the +y axis.
Create an object that is the difference between these--what you get is
a cube with a hemispherical "basin" of radius 1. The composite object
is centered on the y axis.
Now run isect() in a raster pattern from x= -2 to 2 and z = -2 to 2,
y = 3 (for example), and with a downward-pointing vector of length 6
(for example). If you iterate isect with this vector at fine enough a
resolution (say 0.001 unit) in the x and z components of the starting
point, sometimes the vector shoots through the top surface at the
junction between the cube and the hemisphere, along the edge of the
basin.
I can work around this programmatically by trapping the erroneous returns,
but thought I'd document this in case 1) a developer wanted to track this,
or
2) I missed something in generating a simple difference object or in using
isect.
--MVSmith
Subject: Re: ERROR IN ISECT()?---developers lurking?
Date: 12 Feb 2004 14:00:05
Message: <8cusf1-knk.ln1@triton.imagico.de>
I don't know such a function, neither in POV-SDL syntax nor in the
POV-Ray source code.
> structure,
> opposite
> side.
> Here's a test case.
It would probably be much easier if you just post a minimal test scene
to reproduce your problem.
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
Date: 12 Feb 2004 14:02:10
Message: <402bcdb2$1@news.povray.org>
Will post a test scene, probably tomorrow.
Chris
news:8cu### [at] tritonimagicode...
this
intended
> > structure,
> > opposite
> > side.
> > Here's a test case.
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
Date: 12 Feb 2004 14:44:21
Message: <402bd795@news.povray.org>
"Christoph Hormann" <chr### [at] gmxde> schrieb im Newsbeitrag
this
It's a macro in shapes.inc. From the docs:
"Isect(Pt, Dir, Obj, OPt) and IsectN(Pt, Dir, Obj, OPt, ONorm)
These macros are interfaces to the trace() function. Isect() only returns
the intersection point, IsectN() returns the surface normal as well."
Marc-Hendrik
Date: 12 Feb 2004 15:02:25
Message: <402bdbd1$1@news.povray.org>
MVSmith wrote:
> Here's a test case.
Sounds like a problem with coincident surfaces...
http://www.povray.org/documentation/view/46/
Date: 12 Feb 2004 17:57:39
Message: <cjameshuff-DAA06E.17580312022004@news.povray.org>
I assume you are talking about the Isect() and IsectN() macros in
shapes.inc. Please be more precise in the future...functions are
something else entirely, and capitalization does matter.
> structure,
> opposite
> side.
This is not a problem with the Isect() macros, they are just wrappers
for the trace() function. And it is very unlikely that it is a problem
with the trace() function, which uses the same code the rest of POV
uses. It sounds more likely that it is a problem with your test object
or with your conception of what to expect. It may be precision errors,
or something wrong with the way you have things set up...
http://tag.povray.org/
Date: 13 Feb 2004 02:23:38
Message: <402C7B7B.35A47391@arkady.demon.co.uk>
> > structure,
> > opposite
> > side.
I saw a problem like this with trace() appearing to miss coincident
surfaces in my IRTC entry. While I can see why in tracing it isn't possible
to tell which surface the ray hits, I didn't expect it to miss both surfaces,
at the time I put it down to an error in my code.
light_source {<8,5,-1>,1}
camera{ location <12,5,-5> look_at <5,1,0>}
#declare Y1=0.35;
#declare Y2=0.35;       // 0.35 fails, 0.3501 works
#declare A=
union
    intersection
        box{<-20,0,0.86> <20,Y1,3>}
        union
            cylinder{<5,0,2.8> <5,Y2,2.8> 1.94 }
            cylinder{<11,0,2.8> <11,Y2,2.8> 1.94 }
            cylinder{<-5,0,2.8> <-5,Y2,2.8> 1.94 }
            cylinder{<-11,0,2.8> <-11,Y2,2.8> 1.94}
    box{<-20,0,0.86> <-11,Y1,3>}
    box{<-5,0,0.86> <5,Y1,3> }
    box{<11,0,0.86> <20,Y1,3>}
object{A pigment {rgb 1}}
#local i=-15;
#while(i<15)
sphere{trace(A,<i,12,2>,-y) 1/10 pigment {rgb x}}
#local i=i+0.1;
Bernard
Date: 14 Feb 2004 04:48:03
Message: <pj41g1-ecf.ln1@triton.imagico.de>
MVSmith wrote:
> OK, mea culpa...Isect is a macro, documented in Help, 7.13.1  shapes.inc,
> which is indeed a wrapper for the trace function.
> Spent a little time stripping some code down to a test case, which
> follows at the end of this msg.
This is about as far from a minimal test scene as it can get.  A minimal
scene would look like:
#include "shapes.inc"
#local Object = object { ... }
#local isIntersection = Isect(<point>, -y, Object, intersectPoint);
#debug str(intersectPoint.y,0,6)
> I've also attached three files zipped
> together:
Never post binary attachments to a non-binary group.
