POV-Ray : Newsgroups : povray.newusers : pattern as function Server Time
19 Sep 2025 04:20:06 EDT (-0400)
  pattern as function (Message 1 to 10 of 11)
Subject: pattern as function
Date: 4 Nov 2002 08:49:38
Message: <3dc67af2$1@news.povray.org>
When you use a pattern as a function, as in:
function {f_marble{x,y,z}}
is there any way to control the turbulence or other properties of the
pattern? And why isn't the function "f_marble" (or f_otherpatterns) in the
documentation?
Thanks much,
Dennis
Subject: Re: pattern as function
Date: 4 Nov 2002 08:54:22
Message: <3DC67C0D.5028FBAA@gmx.de>
> documentation?
f_marble() etc. are defined in 'functions.inc', therefore you find the
documentation in section 7.7.  A pattern function can contain a complete
pattern definition including transformations, warps etc.
Last updated 02 Nov. 2002 _____./\/^>_*_<^\/\.______
Date: 4 Nov 2002 09:30:24
Message: <3dc68480$1@news.povray.org>
Thanks Chris, but looking in functions.inc, I don't see what the syntax
would be to specify say, the turbulence using an isosurface pattern
function. There is a comment in the file that says "some of these ...require
special parameters..." So does that mean that you can't specify all the
parameters of a pattern when using it as an isosurface? Or if you can, can
you give me an example? F_marble isn;t included in the 7.7 section and the
turbulence parameter isn't mentioned either.
Best,
D.
news:3DC67C0D.5028FBAA@gmx.de...
the
> > documentation?
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
Date: 4 Nov 2002 09:44:02
Message: <3DC687B2.16CE4C5@gmx.de>
fumctions.inc, line 661:
#declare f_marble = function {pattern {marble}}
with turbulence warp:
#declare f_marble_turb =
  function {
    pattern {
      marble
      warp { turbulence 0.5 }
Date: 4 Nov 2002 10:03:43
Message: <3dc68c4f$1@news.povray.org>
Now that's interesting as my line 661 is:
(in context)
//the other fractal patterns are not implemented.
#declare f_mandel = function {pattern {mandel 25}}
// object not implemented
I have the 3.5 final build installed; how come we have different .inc files?
Is yours dated 6/17/02?
Anyway, thanks for the syntax..
d.
news:3DC### [at] gmxde...
...require
can
the
>   function {
>     pattern {
>       marble
> Christoph
Date: 4 Nov 2002 11:19:45
Message: <3dc69e21$1@news.povray.org>
"Dennis Miller" <dhm### [at] attbicom> wrote in message
news:3dc68c4f$1@news.povray.org...
<snip>
I *think* Chris means that you can intuit how to apply warps to patterns in
functions from examining the syntax used in functions.inc:
and then just adding the warp statement to that (as found under the general
pattern modifiers 6.7.12).
IMHO it would be impracticle for functions.inc to carry all the possible
variants you might want in pattern functions.
Date: 4 Nov 2002 13:43:51
Message: <3dc6bfe7$1@news.povray.org>
I see it now. Thanks again. I'm still not clear how to alter the turbulence
parameter once it is declared in a scene, For example, how would I pop it
directly here:
#declare Sphere = function {f_marble_turb{x,y,z}}
but I understand how to change the entire declaration in the functions.inc
file so I can always just declare the whole f_marble_turb directly in the
scene and change the warp value there.
Thanks again,
D.
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3dc69e21$1@news.povray.org...
> <snip>
in
general
Date: 4 Nov 2002 15:09:01
Message: <3dc6d3dd@news.povray.org>
> directly here:
  If you *really* want to do it, then there's a way. I don't know how
much overhead it adds, though:
function { pattern { function { f_marble(x,y,z) } turbulence 1 } }
(Untested, but should work.)
  I would say that creating it directly as:
function { pattern { marble turbulence 1 } }
is better.
Date: 4 Nov 2002 15:52:37
Message: <3dc6de15$1@news.povray.org>
That certainly looks cleaner. Thanks much for your help.
D.
news:3dc6d3dd@news.povray.org...
turbulence
it
> > directly here:
> is better.
x]
Warp -
Date: 4 Nov 2002 19:14:26
Message: <3dc70d62@news.povray.org>
In article <3dc6de15$1@news.povray.org> , "Dennis Miller"
You mean "function { pattern { marble turbulence 1 } }", right?  The other
solution is just plain clumsy.  No need to use f_marble at any cost.  Just
declaring a new pattern function is the way to go.  Not by modifying
functions.inc, of course, but by just declaring a new pattern function in
your scene.  Just using f_marble for the sake of using f_marble does not
make sense.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
