![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
When you use a pattern as a function, as in:
function {f_marble{x,y,z}}
is there any way to control the turbulence or other properties of the
pattern? And why isn't the function "f_marble" (or f_otherpatterns) in the
documentation?
Thanks much,
Dennis
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> documentation?
f_marble() etc. are defined in 'functions.inc', therefore you find the
documentation in section 7.7. A pattern function can contain a complete
pattern definition including transformations, warps etc.
Last updated 02 Nov. 2002 _____./\/^>_*_<^\/\.______
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks Chris, but looking in functions.inc, I don't see what the syntax
would be to specify say, the turbulence using an isosurface pattern
function. There is a comment in the file that says "some of these ...require
special parameters..." So does that mean that you can't specify all the
parameters of a pattern when using it as an isosurface? Or if you can, can
you give me an example? F_marble isn;t included in the 7.7 section and the
turbulence parameter isn't mentioned either.
Best,
D.
"Christoph Hormann" <chr### [at] gmx de> wrote in message
news:3DC67C0D.5028FBAA@gmx.de...
the
> > documentation?
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
fumctions.inc, line 661:
#declare f_marble = function {pattern {marble}}
with turbulence warp:
#declare f_marble_turb =
function {
pattern {
marble
warp { turbulence 0.5 }
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Now that's interesting as my line 661 is:
(in context)
//the other fractal patterns are not implemented.
#declare f_mandel = function {pattern {mandel 25}}
// object not implemented
I have the 3.5 final build installed; how come we have different .inc files?
Is yours dated 6/17/02?
Anyway, thanks for the syntax..
d.
news:3DC### [at] gmx de...
...require
can
the
> function {
> pattern {
> marble
> Christoph
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Dennis Miller" <dhm### [at] attbi com> wrote in message
news:3dc68c4f$1@news.povray.org...
<snip>
I *think* Chris means that you can intuit how to apply warps to patterns in
functions from examining the syntax used in functions.inc:
and then just adding the warp statement to that (as found under the general
pattern modifiers 6.7.12).
IMHO it would be impracticle for functions.inc to carry all the possible
variants you might want in pattern functions.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I see it now. Thanks again. I'm still not clear how to alter the turbulence
parameter once it is declared in a scene, For example, how would I pop it
directly here:
#declare Sphere = function {f_marble_turb{x,y,z}}
but I understand how to change the entire declaration in the functions.inc
file so I can always just declare the whole f_marble_turb directly in the
scene and change the warp value there.
Thanks again,
D.
"Tom Melly" <tom### [at] tomandlu co uk> wrote in message
news:3dc69e21$1@news.povray.org...
> <snip>
in
general
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> directly here:
If you *really* want to do it, then there's a way. I don't know how
much overhead it adds, though:
function { pattern { function { f_marble(x,y,z) } turbulence 1 } }
(Untested, but should work.)
I would say that creating it directly as:
function { pattern { marble turbulence 1 } }
is better.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That certainly looks cleaner. Thanks much for your help.
D.
"Warp" <war### [at] tag povray org> wrote in message
news:3dc6d3dd@news.povray.org...
turbulence
it
> > directly here:
> is better.
x]
Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3dc6de15$1@news.povray.org> , "Dennis Miller"
You mean "function { pattern { marble turbulence 1 } }", right? The other
solution is just plain clumsy. No need to use f_marble at any cost. Just
declaring a new pattern function is the way to go. Not by modifying
functions.inc, of course, but by just declaring a new pattern function in
your scene. Just using f_marble for the sake of using f_marble does not
make sense.
Thorsten
Thorsten Froehlich
e-mail: mac### [at] povray org
I am a member of the POV-Ray Team.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
