POV-Ray : Newsgroups : povray.newusers : Anti-aliasing Server Time
10 Apr 2026 19:45:15 EDT (-0400)
  Anti-aliasing (Message 1 to 10 of 55)
Subject: Anti-aliasing
Date: 30 Mar 2002 17:54:44
Message: <3ca64234$1@news.povray.org>
I have a very thin object that is not showing up correctly because some
pixels pick it up and others don't hence creating jaggies, even with
anti-aliasing. My question is, what do I adjust in anti-aliasing to improve
this? And does increasing or decreasing the threshold provide for a better
sample?
Thanks in advance!
Subject: Re: Anti-aliasing
Date: 30 Mar 2002 21:48:14
Message: <3ca678ed@news.povray.org>
> sample?
  Try +a0.0 if it helps. (Note that it will slow down the rendering a lot.)
Date: 31 Mar 2002 05:24:26
Message: <3ca6e3da@news.povray.org>
I don't think this would be of much help here.
Try increasing the recursion depth (+r4 or +r5) instead, this also slow down things,
especially with method 2.
If this doesn't work either, render at bigger resolution and re-size your picture
with your favourite paint program.
Jonathan.
Home: http://digilander.iol.it/jrgpov
"Warp" <war### [at] tagpovrayorg> ha scritto nel messaggio
news:3ca678ed@news.povray.org...
> > sample?
Date: 31 Mar 2002 06:49:42
Message: <3ca6f7d6@news.povray.org>
  How is this different from using +a0.0?
Date: 31 Mar 2002 08:18:49
Message: <3ca70cb9@news.povray.org>
My fault. I did some tests and have to say that +a0.0 worked better than +a0.1 +r5,
even if it is way slower.
Anyway, IMHO, it's better to render at bigger resolution. This is a pretty common
technique to avoid many AA pitfalls.
Jonathan.
news:3ca6f7d6@news.povray.org...
Date: 31 Mar 2002 11:51:42
Message: <3CA73F75.D5CEDF48@hotmail.com>
> > your picture with your favourite paint program.
+a0.0 forces all pixels to go to the full depth.
+a0.1 at a higher resolution simulates a minimum depth of anti-aliasing,
without forcing full depth for all pixels.
A minimum aa depth might be a useful feature.
Rusty is rendering!
Date: 31 Mar 2002 13:59:58
Message: <3ca75cae@news.povray.org>
  I still don't understand how that's different from using +a0.0.
(What +a0.0 does in practice is exactly what you propose: It kind of renders
an image at higher resultion and "scales" it down to the desired resolution.
This happens because it sends the extra rays for *each* pixel regardless of
what there is in the image; that's exactly the same as rendering at higher
resolution. You can control the extra resolution with +r.)
Date: 31 Mar 2002 14:01:24
Message: <3ca75d03@news.povray.org>
  Ie. exactly what rendering at higher resolution does.
  Yes, but rendering at higher resolution forces povray to shoot more rays
even though it wouldn't be necessary.
Date: 31 Mar 2002 15:13:26
Message: <chrishuff-0E6284.15142531032002@netplex.aussie.org>
In article <3ca75d03@news.povray.org>, Warp <war### [at] tagpovrayorg>
+a0.0 forces it to shoot all the rays for every pixel. Rendering at a
higher resolution and resizing lets you control the minimum sampling
density (making your objects more likely to be visible) while still
taking advantage of adaptive sampling for faster rendering.
An additional "minimum samples" control would do the same thing, without
the additional external step of reducing the final image in size, which
will give different results with different programs.
Date: 31 Mar 2002 15:29:22
Message: <3ca771a2$1@news.povray.org>
+a0.0 worked perfectly. Plus it fixed some artifacts I had with image maps.
Thanks a bunch!!
improve
better
> > sample?
lot.)
M()}}
Warp -
