POV-Ray : Newsgroups : povray.newusers : normals and pigments in a csg Server Time
25 Dec 2025 06:14:07 EST (-0500)
  normals and pigments in a csg (Message 1 to 10 of 12)
Subject: normals and pigments in a csg
Date: 18 Jul 1999 16:58:00
Message: <37923fd8@news.povray.org>
Hi group,
following problem:
I want to make an object of a csg to have an individual pigment, but the
normal pattern of the whole csg (with all translations and rotations).
here is an (simplified) example of what i mean:
union{
  sphere{x,1  pigment{ rgb<0,1,0>} } /* I want this sphere to have the
parent's bumps AND to be green!!*/
  sphere{-x,1}
  pigment{rgb <1,0,0>}
  normal{bumps scale .1 }
There are several objects in my csg, and all are translated in a different
way, so i cannot use a #declared normal pattern.
I hope someone can help me...
TIA, Daniel
Daniel Pirch
nap### [at] linuxzrztu-berlinde
Subject: Re: normals and pigments in a csg
Date: 18 Jul 1999 19:25:20
Message: <379261CF.C44F720D@pacbell.net>
Daniel Pirch wrote:
> Hi group,
> following problem:
> union{
>   sphere{-x,1}
> TIA, Daniel
> Daniel Pirch
 If I understand your question correctly what you are looking for is several
objects that have their own pigment and then you want to apply a global normal
pattern to the entire csg'd object. This can be done quite simply using the
following method.
  union {
 sphere { x,1 pigment <1,0,0> }
 sphere {-x,1 pigment <1,1,0> }
 sphere { y,1 pigment <0,1,0> }
 sphere {-y,1 pigment <0,0,1> }
 normal { bumps 1 scale 1     }
In the above operation you apply the normal to the csg constuct as opposed
to one or several of the individual components.
  By the way you can use a declared normal pattern anywhere a normal would
normaly be used. For example:
#declare My_Normal = normal { bumps 1 scale  1 }
  union {
 normal { My_Normal           }
  If I have missed your intent please try to describe again what it is you
are looking for.
Ken Tyler
mailto://tylereng@pacbell.net
http://home.pacbell.net/tylereng/links.htm
Date: 18 Jul 1999 21:12:15
Message: <37927AE8.471D541C@xs4all.nl>
> following method.
>   union {
I'm sorry but this won't work (or I am getting real perception problems).
I've had this problem more then once. If you stick a pigment on a part of a csg
(or blob) the normal or finish you use for the whole object doesn't apply there.
Remco
http://www.xs4all.nl/~remcodek/softmach.html
Date: 18 Jul 1999 22:15:50
Message: <379289BF.67095D68@pacbell.net>
> Remco
Then what is the solution ? Should we just use softext instead and forget
about normals and them other pesky primitives ?
Ken Tyler
Date: 18 Jul 1999 22:50:15
Message: <379291CD.8C1026CE@pacbell.net>
If at first you don't succeed... you use the other workable solution. This
following example clearly shows that you can maintain even distribution of
a normal pattern for each object in the csg operation and it looks kool too !
  camera {location<0,0,-5>look_at 0}
  light_source {<0,0,-20> rgb 1}
  #declare Norm = normal { gradient x+y 1 rotate 45*x+y scale .5 frequency 2}
  union {
 sphere { 0, 1 pigment { rgb<1,0,0> } translate<-1, 0,0>normal {Norm} }
 sphere { 0, 1 pigment { rgb<1,1,0> } translate< 1, 0,0>normal {Norm} }
 sphere { 0, 1 pigment { rgb<0,1,0> } translate< 0,-1,0>normal {Norm} }
 sphere { 0, 1 pigment { rgb<0,0,1> } translate< 0, 1,0>normal {Norm} }
Ken Tyler
Date: 19 Jul 1999 03:30:21
Message: <3792d40d@news.povray.org>
But if the objects are part of other transplated CSGs?
#declare spheres = union{
  sphere{ -2*x, 1 pigment{ rgb<1,0,0>}}
  sphere{0, 1 pigment{rgb <0,1,0>}}
  sphere{ 2*x,1 pigment{ rgb<0,0,1>}}
union{
  object{spheres translate 2*z}
  object{spheres}
  object{spheres translate -2*z}
  normal{Norm}
Ken <tyl### [at] pacbellnet> wrote in message
news:379291CD.8C1026CE@pacbell.net...
problems).
of a csg
apply there.
too !
2}
>   union {
> Ken Tyler
Daniel Pirch
Date: 19 Jul 1999 04:43:36
Message: <3792E49D.4D782757@pacbell.net>
Daniel Pirch wrote:
> But if the objects are part of other transplated CSGs ?
 Then you end up giving Ken a big pain in his head :(
 If I come up with anything I will get back to you.
Ken Tyler
Date: 19 Jul 1999 05:38:14
Message: <3792F101.885CB699@xs4all.nl>
> > Remco
The thing I do is to put the normals and finishes at the same place the pigments
are declared. Too bad, because it needs a little work and perhaps a lot (extra)
memory.
I don't see how this relates to the problem here? If you don't want me to bring
it up anymore I won't.
Bye,
Remco
Date: 19 Jul 1999 05:54:29
Message: <3792F53B.25A461CD@pacbell.net>
  Easy there Remco. I simply forgot to add the :) to the end of that last
comment. You can plug your useful utility as much as you see fit and it
will not bother me in the least.
Ken Tyler
Date: 19 Jul 1999 06:34:59
Message: <3792FF4C.395924A3@xs4all.nl>
I'm a bit (over-)sensitive about it since the first time I brought it up I was
criticized over it being just a windows-program, while I just wanted to share a
sorry utility I developed for my own use (hence no docs and stuff and only a
modest registration-fee ;-))
Remco
