POV-Ray : Newsgroups : povray.newusers : isosurface in mirror Server Time
11 Nov 2026 18:03:59 EST (-0500)
  isosurface in mirror (Message 14 to 33 of 33)
<<< Previous 13 Messages Goto Initial 33 Messages
Subject: Re: isosurface in mirror
Date: 10 Oct 2006 11:44:32
Message: <20061010174400.999aea88.not@available.yet>
i am going mad.
now only one part is not visible in mirror.
but it comes better:
back part of object is visible in mirror but not in front of it. then I rendered it
without the mirror.
and what should I say: it is invisible!
like Mike Williams said: watch max_gradient warnings.
this time I get one:
Shutdown Warning: The maximum gradient found was 1.001, but max_gradient of the
 isosurface was set to 2.038. Adjust max_gradient to get a faster rendering of
 the isosurface.
if max_gradient is set to 1.001 Povray warns that max_gradient found is 2.038 and vice
versa.
I don not know if this has something to do with my problem. but hints are welcome.
soon I post an image to p.b.images.
Date: 10 Oct 2006 11:45:39
Message: <452bc023$1@news.povray.org>
difference{
object { isosurface1_containedby_box }
object {
isosurface2_containedby_box
translate y*-value
rotate x*90
double_illuminate
"marabou" <not### [at] availableyet> a écrit dans le message de
news:200### [at] availableyet...
> On Tue, 10 Oct 2006 17:25:02 +0200
> "Penelope20k" <pen### [at] caramailfr> wrote:
> > the 'what' you see in the mirror is not your iso surface ..i think its
the
> > reflects light of your isosurface ...
> > like difference { A B ..with no_reflection statement }
> > i dont see also the shadow of your isosurface ...this is strange also
..(but
> > doenst count yet)
> there is a shadow of isosurface in mirror. look between my painted lines.
there is a shadow from light on the ground. it ist a little bit blinded.
Date: 10 Oct 2006 11:48:39
Message: <452bc0d7@news.povray.org>
> max_gradient of the
>  rendering of the isosurface.
> is 2.038 and vice versa.
I guess POV-Ray can not in all cases find out the best max_gradient
value. You should try a very high max_gradient to be sure that this is
not the problem.
Date: 10 Oct 2006 11:57:23
Message: <20061010175651.4772675e.not@available.yet>
On Tue, 10 Oct 2006 17:58:41 +0200
> difference{
> object {
> translate y*-value
> rotate x*90
> double_illuminate
it makes no difference.
Date: 10 Oct 2006 12:13:53
Message: <452bc6c0@news.povray.org>
Hi
marabou wrote:
> i was proud that someone can see anything in mirror with  difference.
> without you see less...
To find the problem, do the following:
- Remove all unions,differences,intersections or merges from the scene.
- Remove all objects from the scene except _one_ isosurface.
If the error is still present, there is something really wrong. In this
case I would try to tinker with the threshold and accuracy values of
the isosurface. But I'm not an expert ...
If the error is gone, you can reactivate the things one after another
and you will find out what causes the problem.
Anyway, I'm sure that this has something to do with CSG ...
Greetings
Urd
Date: 10 Oct 2006 12:16:39
Message: <20061010181608.5f7206d9.not@available.yet>
On Tue, 10 Oct 2006 18:17:12 +0200
Urs Holzer <urs### [at] andonyarcom> wrote:
> Hi
> Greetings
> Urd
thank you for your ideas.
I had the same but it does not help.
Date: 10 Oct 2006 12:28:31
Message: <452bca2f@news.povray.org>
"marabou" <not### [at] availableyet> wrote in message
   I'm no expert, but couldn't this be an 'inverse' situation?
    ~Steve~
Date: 10 Oct 2006 12:29:54
Message: <20061010182922.a335e102.not@available.yet>
On Tue, 10 Oct 2006 17:28:20 +0100
pardon, what do you you mean?
Date: 10 Oct 2006 12:39:07
Message: <452bccab$1@news.povray.org>
   Well, basically, it will turn an object 'inside out', (not sure if it
works with iso's). I'm just thinking/wondering what would happen if you used
'inverse'  - would your original 'invisible' side now be visible in the
mirror, and vice verse?
    If that's not viable, have you tried giving your object some
thickness/depth to see if the problem is still there?
      ~Steve~
Date: 10 Oct 2006 12:46:20
Message: <20061010184548.17ae3a73.not@available.yet>
On Tue, 10 Oct 2006 17:38:54 +0100
it does not work with isos.
yes
Date: 10 Oct 2006 12:53:37
Message: <452bd011@news.povray.org>
marabou wrote:
> hello,
> currently I render a scene with an isosurface and a mirror showing
> that isosurface. isosurface is created like:
> difference{
> object {
> translate y*-value
> rotate x*90
> the result is a nearly planar surface.
> the mirror has reflection 0.8.
Could you give us the code (i.e. the function) of the isosurfaces? Could
you also post an image of one of those isosurfaces (without using CSG)?
Probably someone can then see the problem.
I don't know much about isosurfaces. So I make now a last guess about
what could be the problem and then I'll give up: Some functions are
bad, because they have infinite max_gradient. POV-Ray won't detect
that. But it should report high max_gradient values, so this is rather
not the case.
Good luck in solving the problem!
Date: 10 Oct 2006 13:16:43
Message: <20061010191611.e0fefa2b.not@available.yet>
On Tue, 10 Oct 2006 18:56:58 +0200
> marabou wrote:
> > hello,
> > difference{
> > object {
> > translate y*-value
> > rotate x*90
> not the case.
it is only one CSG in image; please see p.b.images.
little explanation of code:
two arrays hold the clock steps and the spline points and are processed in macro
create_spline(...).
variable createdsplinepath holds the spline and is used in a function f_myspline. this
function is used to create the iso contained_by box.
in macro draw_object(...) the iso is differenced by itself with a little translate to
get only the surface of iso.
then object is placed. the call to draw_object(...) gets references to the two arrays
i mentioned above.
parts of code follow (read from buttom to top):
#macro create_iso(isosteps, isopoints)
create_spline(isosteps, isopoints, 0) //returns createdsplinepath
#undef f_myspline
#declare f_myspline = function {
   spline{
      createdsplinepath	// is the created spline
#declare iso =
isosurface {
   function { y - f_myspline(x).x - f_myspline(z).z }
   accuracy 0.001
// max_gradient 4
   max_gradient 2.038
   contained_by {
	box { -1,1 }
   pigment { rgb <255,255,255>/255 }
   finish {
      phong 0.5
      phong_size 10
#end //macro create_iso
#macro draw_object(objsteps, objspline)
   create_iso(objsteps, objspline)
   difference {
      object { iso }
      object { iso scale <1.001,1,1.001> translate y*-0.02 }
#declare splsteps_m = array[]{}
#declare spl_m = array[]{}
object{
draw_object(splsteps_m, spl_m)
translate <0,-0.5,-2.5>
Date: 10 Oct 2006 13:21:44
Message: <452bd6a8@news.povray.org>
>> used
   Gah, I had a sneaky feeling it didn't.
> yes
  Hmm, then you have an interesting problem. I'll keep thinking on it.
   ~Steve~
Date: 10 Oct 2006 13:27:02
Message: <20061010192630.8d23b14c.not@available.yet>
On Tue, 10 Oct 2006 18:17:07 +0100
> > yes
have you read this:?
news.povray.org povray.newusers:14442
Date: 10 Oct 2006 13:33:54
Message: <nKLKtPA7l9KFFwKz@econym.demon.co.uk>
As I said earlier, you need to specify a sensible max_trace count, or
use all_intersections, in any isosurface that's involved in CSG
operations (like your "difference").
The default max_trace is too low for the CSG.
Mike (why does nobody ever listen to me) Williams
Subject: Re: isosurface in mirror; solved
Date: 10 Oct 2006 14:18:08
Message: <20061010201734.b26d471a.not@available.yet>
heureka!
it was not the keyword "hollow", it was "open"!
thank you for all the good tipps and ideas!
Date: 10 Oct 2006 15:48:59
Message: <452bf92b@news.povray.org>
"Mike Williams" <nos### [at] econymdemoncouk> wrote in message
news:nKL### [at] econymdemoncouk...
>>isosurface is invisible
> As I said earlier, you need to specify a sensible max_trace count>
D'you think sometimes maybe you're invisible too.
;o)
Chris B.
Date: 10 Oct 2006 16:18:09
Message: <94gsRBAU8$KFFwLI@econym.demon.co.uk>
>heureka!
Well "open" will reduce the number of intersections in certain
directions making it possible to get away with the default max_trace
setting sometimes, but if the problem comes back even with "open" you
can fix it with "all_intersections".
Mike Williams
Gentleman of Leisure
Date: 11 Oct 2006 09:54:57
Message: <20061011155424.e2a86c42.not@available.yet>
On Tue, 10 Oct 2006 21:14:12 +0100
recognized. thank you
Date: 11 Oct 2006 09:56:04
Message: <20061011155531.ff5301b2.not@available.yet>
On Tue, 10 Oct 2006 18:33:47 +0100
sorry, it was not meant so.
