POV-Ray : Newsgroups : povray.newusers : isosurface in mirror Server Time
10 Jun 2026 05:21:49 EDT (-0400)
  isosurface in mirror (Message 11 to 20 of 33)
Subject: Re: isosurface in mirror
Date: 10 Oct 2006 11:07:26
Message: <20061010170654.36b1e56b.not@available.yet>
On Tue, 10 Oct 2006 17:16:37 +0200
"Penelope20k" <pen### [at] caramailfr> wrote:
> Yep strange ...i'm still convince that your back is not define ..did the
> reflection works if you remove your difference ..
> i mean if you anly reflect your object A , or object B alone..
i was proud that someone can see anything in mirror with  difference. without you see
less...
Date: 10 Oct 2006 11:11:53
Message: <452bb839$1@news.povray.org>
the 'what' you see in the mirror is not your iso surface ..i think its the
reflects light of your isosurface ...
like difference { A B ..with no_reflection statement }
i dont see also the shadow of your isosurface ...this is strange also ..(but
doenst count yet)
news:200### [at] availableyet...
without you see less...
Date: 10 Oct 2006 11:21:09
Message: <20061010172037.469e0b6b.not@available.yet>
On Tue, 10 Oct 2006 17:25:02 +0200
> doenst count yet)
there is a shadow of isosurface in mirror. look between my painted lines.  there is a
shadow from light on the ground. it ist a little bit blinded.
Date: 10 Oct 2006 11:44:32
Message: <20061010174400.999aea88.not@available.yet>
i am going mad.
now only one part is not visible in mirror.
but it comes better:
back part of object is visible in mirror but not in front of it. then I rendered it
without the mirror.
and what should I say: it is invisible!
like Mike Williams said: watch max_gradient warnings.
this time I get one:
Shutdown Warning: The maximum gradient found was 1.001, but max_gradient of the
 isosurface was set to 2.038. Adjust max_gradient to get a faster rendering of
 the isosurface.
if max_gradient is set to 1.001 Povray warns that max_gradient found is 2.038 and vice
versa.
I don not know if this has something to do with my problem. but hints are welcome.
soon I post an image to p.b.images.
Date: 10 Oct 2006 11:45:39
Message: <452bc023$1@news.povray.org>
difference{
object { isosurface1_containedby_box }
object {
isosurface2_containedby_box
translate y*-value
rotate x*90
double_illuminate
the
..(but
> > doenst count yet)
there is a shadow from light on the ground. it ist a little bit blinded.
Date: 10 Oct 2006 11:48:39
Message: <452bc0d7@news.povray.org>
> max_gradient of the
>  rendering of the isosurface.
> is 2.038 and vice versa.
I guess POV-Ray can not in all cases find out the best max_gradient
value. You should try a very high max_gradient to be sure that this is
not the problem.
Date: 10 Oct 2006 11:57:23
Message: <20061010175651.4772675e.not@available.yet>
On Tue, 10 Oct 2006 17:58:41 +0200
> difference{
> object {
> translate y*-value
> rotate x*90
> double_illuminate
it makes no difference.
Date: 10 Oct 2006 12:13:53
Message: <452bc6c0@news.povray.org>
Hi
To find the problem, do the following:
- Remove all unions,differences,intersections or merges from the scene.
- Remove all objects from the scene except _one_ isosurface.
If the error is still present, there is something really wrong. In this
case I would try to tinker with the threshold and accuracy values of
the isosurface. But I'm not an expert ...
If the error is gone, you can reactivate the things one after another
and you will find out what causes the problem.
Anyway, I'm sure that this has something to do with CSG ...
Greetings
Urd
Date: 10 Oct 2006 12:16:39
Message: <20061010181608.5f7206d9.not@available.yet>
On Tue, 10 Oct 2006 18:17:12 +0200
Urs Holzer <urs### [at] andonyarcom> wrote:
> Hi
> Greetings
> Urd
thank you for your ideas.
I had the same but it does not help.
Date: 10 Oct 2006 12:28:31
Message: <452bca2f@news.povray.org>
"marabou" <not### [at] availableyet> wrote in message
   I'm no expert, but couldn't this be an 'inverse' situation?
    ~Steve~
