POV-Ray : Newsgroups : povray.newusers : Why left-handed coordinate system? Server Time
13 Jun 2026 22:43:17 EDT (-0400)
  Why left-handed coordinate system? (Message 11 to 20 of 21)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Why left-handed coordinate system?
Date: 18 Nov 2002 23:15:14
Message: <1flw2yp.zgcs571jnnwnaN%kaveh@delete_this.focalimage.com>
>   By the way, when calculating handedness-related things literally
> using your hand as an aid, it's very important to remember that
> the thum is *always* the x-axis (and the next fingers are the y and
> the z axes).
I find it easier just to use the curled fingers method, not the index
and third fingers. To get the sense of the z axis, I position the left
hand such that the four fingers curl from the x to the y axis. Then the
thumb shows the direction of the z axis.
>   (If you didn't know, you can easily visualize which direction does
> a positive angle rotate an object by pointing your thumb (of the left
> hand if you are using the left-handed coordinates) towards the positive
> axis around which you are rotating and bend your fingers.)
Yes, this is the way I use the curled fingers.
Kaveh
Date: 19 Nov 2002 05:33:52
Message: <3dda138f@news.povray.org>
  That description was very unclear. I did not visualize at all which
direction the thumb is pointing at...
Date: 19 Nov 2002 06:02:39
Message: <20021119120238.57d0c099.jaimevives@ignorancia.org>
On 18 Nov 2002 15:34:03 -0500
  I use only this rule for all my "visualizations" when I'm writing scenes, and I
agree with you: when you have the right hand already on the numeric pad, the
lef-handed system is very useful. Not joking!
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 19 Nov 2002 08:45:26
Message: <1flwt0q.1eoksy3ek3y68N%kaveh@delete_this.focalimage.com>
It was not clear, I agree. I will put it another way. Put your left hand
in the 'aerobics' position, with fingers curled. Now, point your thumb
in the +z direction. Now if you were to rotate the x axis to coincide
with the y, it your fingers are giving the correct direction.
In a right handed system, sometimes a screw is used. If the screw has
its tip in the +z direction, turning the screw from x to y pushes the
screw in the z direction. But this is of course opposite to the
left-handed system.
All easier to see of course than to describe.
I just find it easier to have something real like a screw, than to
remember a mnemonic.
Kaveh
Date: 19 Nov 2002 08:45:29
Message: <1flwtcy.127zpabpprn6eN%kaveh@delete_this.focalimage.com>
> On 18 Nov 2002 15:34:03 -0500 Warp <war### [at] tagpovrayorg> wrote:
> >   (If you didn't know, you can easily visualize which direction does a
> > positive angle rotate an object by pointing your thumb (of the left hand
> > if you are using the left-handed coordinates) towards the positive axis
> scenes, and I agree with you: when you have the right hand already on the
> numeric pad, the lef-handed system is very useful. Not joking!
I think the reason I brought this up in the first place was that when
studying physics, I found it easiest to imagine a normal wood screw,
turning from x to y axis. In a right handed system, the screw moves in
the +z direction. Now I have to use my hand, as there are no left-handed
screws!
-- Kaveh
Date: 19 Nov 2002 10:05:32
Message: <3DDA5347.8010900@free.fr>
> screws!
There is such thing as 'left-handed screws', but you do not see them
very often. Most of the time, there is a 'right-handed screw' at the
other end, thus a turn of the screw either separate or bring closer the
parts with the bolts (symmetrically!).
Typical application: pairs of compass for technical drawing.
Date: 20 Nov 2002 18:23:38
Message: <3ddc197a@news.povray.org>
Let me try (A degree in physics must be useful somewhere)
For a LEFT handed Coord. sys.
1)  Place the 4 fingers of you LEFT hand so they point in the +X direction.
In the default configuration of POVRay this is heading off the Right side of
your moniter.
2)  "Curl" your fingers so they move from +X to +Y.  Again Default POVRay:
"curl" from right to top of your moniter
3) Your thumb now points in the direction of the +Z axis.  In the example
above "into" the screen.
"Kaveh" <kav### [at] delete_thisfocalimagecom> wrote in message
news:1flwt0q.1eoksy3ek3y68N%kaveh@delete_this.focalimage.com...
the
> left-handed system.
> Kaveh
Date: 21 Nov 2002 00:48:39
Message: <1flzsza.77f6ww1ud5znpN%kaveh@delete_this.focalimage.com>
> your moniter.
Correct. Thank you for the clarification. :-)
Having thought about it, for me at least, a right-handed system would be
easier to use. I remember I never liked mnemonics. The 3-finger system
is really a mnemonic, whereas using the screw analogy (at least in my
simple mind) seems to have some physical basis to it.
Also, all vector calculus I learned was right-handed. If I remember
rightly, the vector A x B, gives a vector C whose direction is given by
using the right handed rule or screw rule, going from A to B.
In physics, When a current goes through a wire, you get a magnetic
field, going around it in a right handed way, although I think this is
just a matter of convention.
So, in short, everything I have come across has used the right-handed
screw analogy, except POVray. As I am not comfortable with a left-handed
screw, I now have to use my left hand.
Date: 21 Nov 2002 00:54:49
Message: <1flzwug.uvaglw8xb2meN%kaveh@delete_this.focalimage.com>
Oh boy. I *knew* I would get myself into trouble at last. :-(
Just a little anecdote I remember, in our physics class. A friend had
terrible trouble using the right hand finger rule. He said it always
came out the wrong way. When I asked him to demonstrate it to me, he was
holding his index and third fingers in the wrong directions, with the
third pointing fingers forwards, the index bent!
Kaveh
Date: 21 Nov 2002 03:57:23
Message: <3ddc9ff3@news.povray.org>
> your moniter.
  And someone thinks this is easier than simply pointing your thumb to
+X, index finger to +Y and middle finger to +Z?
