POV-Ray : Newsgroups : povray.general : Shadows and lighting with HDR sky Server Time
15 Jan 2026 07:54:29 EST (-0500)
  Shadows and lighting with HDR sky (Message 1 to 10 of 11)
Subject: Shadows and lighting with HDR sky
Date: 28 Sep 2021 08:55:00
Message: <web.61530ff3e280e35cfd3478bcd69a400a@news.povray.org>
Hello,
I have trouble getting the lighting right for an outdoor scene. I use an HDR
sky, radiosity and a ground plane. In this image, it appears that the sky casts
light onto the box from the left, but there are no shadows.
Also, the white plane is too dark.
The HDR sky is https://polyhaven.com/a/lilienstein. The relevant part of the
code is
global_settings {
    radiosity {
      pretrace_end 0.001
      count 500
      recursion_limit 1
      low_error_factor 0.2
      brightness 1
sky_sphere{
    pigment{
        image_map{ hdr "sky.hdr"
        map_type 1 interpolate 2}
box {
    <0,0,0>, <8,8,8>
    pigment {rgb <239, 204, 148>/255}
plane {
    y, 0
    pigment { White
Download 'test.png' (118 KB)
Preview of image 'test.png'
Subject: Re: Shadows and lighting with HDR sky
Date: 28 Sep 2021 11:27:14
Message: <61533452$1@news.povray.org>
> Hello,
> code is
> global_settings {
>      radiosity {
>        pretrace_end 0.001
>        count 500
>        recursion_limit 1
>        brightness 1
You are using the default error_bound of 1.8.
Try using a smaller value, like 0.5 and see if the shadows are visible.
global_settings {
     radiosity {
       pretrace_end 0.001
       count 500
       recursion_limit 1
	error_bound 0.5 // Should give sharper shadows
       low_error_factor 0.4
// With a smaller error_bound, it can be set larger
       // brightness 1 Not needed as it's the default
Another thing to check : Where is the Sun in the sky. Try another HDR
with the Sun closer to the horizon.
Date: 28 Sep 2021 13:15:00
Message: <web.61534ce1c55e1a84fd3478bcd69a400a@news.povray.org>
There isn't much more shadow even with error_bound 0.01. What it does is that it
changes the pattern on the left side of the cube.
The sun is near the horizon in the hdri.
Download 'test.png' (831 KB)
Date: 29 Sep 2021 01:25:00
Message: <web.6153f546c55e1a844cef624e6e066e29@news.povray.org>
> that it changes the pattern on the left side of the cube.
To add to what Alain said: With a few 'higher quality' radiosity settings, I do
see a shadow. I think each person has his or her own set of 'favorite'
settings-- mine change on a weekly basis, ha.
My own *basic* rule-of-thumb is to use very small settings for
minimum_reuse ...
maximum_reuse ...
This creates smaller light 'patches', which more accurately get into and around
corners, etc. (But then other rad values need to be tuned as well, including a
higher count to get ride of that splotchy 'pattern' you mentioned. All of which
naturally makes for a slower render...)
I was actually surprised that I *do* see a shadow; the particular HDR image that
you used has a somewhat uniform sky color/brightness, with the
Sun below the horizon. Also, the 'dark' result on the plane is probably a
natural result of the relatively dark sky in most of that image.
----- example -----
#version 3.8; // or whatever
global_settings {
assumed_gamma 1
    radiosity {
      pretrace_end 0.001
      count 1100
      recursion_limit 1
      // [I added these three...]
      minimum_reuse .0032
      maximum_reuse .0032*5
      always_sample on // off by default. I prefer this ON
      brightness 1
  perspective
  location  <10, 11, -20>
  look_at   <10, 4,  0>
  angle 67
sky_sphere{
    pigment{
        image_map{ hdr "lilienstein_4k.hdr"
box {
    <0,0,0>, <8,8,8>
    rotate 35*y
plane {
    y, 0
    pigment { rgb 1}
Download 'better_shadow.jpg' (39 KB)
Preview of image 'better_shadow.jpg'
Date: 29 Sep 2021 11:57:25
Message: <61548ce5$1@news.povray.org>
I do see a shadow to the right of the box. In fact, there are two, one
faint and soft, in line with the front face, and a darker and sharper
I NEVER use the default pretrace_end. The largest I commonly use is
0.005. I often use half or even a quarter of that for the final rendering.
It takes more time for the pretrace step, but, as more samples are taken
during that phase, the render proper is often faster as it don't need to
take as many extra samples.
I tend to set minimum_reuse a bit smaller than the pretrace_end.
Something like :
pretrace_end 0.005
minimum_reuse 0.004
pretrace_end 0.0025
minimum_reuse 0.002
or
pretrace_end 0.00125
minimum_reuse 0.0012
I also tend to keep the maximum_reuse at it's default value.
I usually use the sampling pool feature :
count 100 100*pi
And also the adaptive sampling :
nearest_count 20 3
Date: 29 Sep 2021 16:25:00
Message: <web.6154cb34c55e1a84d74e8b43d69a400a@news.povray.org>
The lighting is getting better with different settings, but the shadow is still
too weak and the plane too dark. I use an additionl light now, that's easier to
control.
Date: 29 Sep 2021 17:55:00
Message: <web.6154e071c55e1a841f9dae3025979125@news.povray.org>
> control.
I see that you have no finish {} block for your pigment.  Maybe define a full
texture with a finish that you can see what effect changing the diffuse setting
on accomplishes.
I don't know offhand what the default finish values are...
Date: 30 Sep 2021 02:31:08
Message: <615559ac@news.povray.org>
Op 29/09/2021 om 17:57 schreef Alain Martel:
[snip]
Absolutely. Using Alain's settings for radiosity, and, instead of a
skysphere:
   sphere {
     0, 10e5
     pigment{
         image_map {exr "lilienstein_4k.exr"
         map_type 1 interpolate 2 once}
       finish {emission 2 diffuse 0}
and, adding micro-normals to the cube and the plane:
     normal {granite 0.2 scale 0.001}
I get the attached image.
Note that as the sunlight in the hdr/exr is rather diffuse, the shadows
are also diffuse.
Download 'sky_test.jpg' (50 KB)
Preview of image 'sky_test.jpg'
Date: 30 Sep 2021 04:25:14
Message: <6155746a$1@news.povray.org>
Op 29-9-2021 om 07:21 schreef Kenneth:
The Voodoo Master teaches about this (in 2008):
[quote]
always_sample:
When set to "off", this effectively sets "nearest_count" to 1 during the
final render, so that new radiosity samples are only taken if they are
absolutely needed.
For quick test renders, you may want to set this parameter to "on" to
get away with a faster pretrace (or none at all).
Otherwise, you will definitely want to set this parameter to "off", as
new samples taken during final trace may cause visible "jumps" in colour
or brightness between areas rendered before and after the new sample was
taken.
(Note that I recommend to set "nearest_count" to 1 anyway, which leaves
this option without any effect.)
[/quote]
Date: 30 Sep 2021 14:15:00
Message: <web.6155fde2c55e1a844cef624e6e066e29@news.povray.org>
> [quote]
> always_sample:
> absolutely needed.
> taken.
Yes, I remember reading that. Several months ago, I did some lengthy and
detailed tests with radiosity (which I *hope* to post about soon...), and my own
eyes tell me that the final render looks 'better' with always_sample on.
Specifically, it seems to eliminate some very subtle artifacts that I noticed;
as a simple way of describing the effect, it produced a 'smoother' render
IMO...but hard to describe, unfortunately. However, all of my tests used a
single small rad emitting object in a scene (and no sky_sphere), as I wanted to
try and zero-in on the basic behavior of radiosity and its various settings.
I could be wrong, but it may be that this particular feature of rad has been
improved since Clipka posted that info(?)
Or it could be just my personal preference, ha. As the old saying goes,
"One man's meat is another man's poison" (which may not translate well?)
