"Bald Eagle" <cre### [at] netscapenet> wrote:
> Super - I have a MUCH better understanding of what you need, but still no
> details.
> How are the normals encoded in the image?
> What's the equation?
> It looks to me like maybe it's R, G, and B separated at 120 deg from each other?
> I could guess - but I'd just be guessing.
> Is there a spec?
> OK, off to work.
Sorry, I thought I replied to this a couple days ago with a longer explanation,
but didn't see the message show up.
This page explains pretty well the concept.
https://en.wikipedia.org/wiki/Normal_mapping
That's all I have time for now.
Josh
I adjusted the blue channel and - I guess it looks to me like it's right.
The gray asteroid has
finish {ambient 0.5 diffuse 0.25 specular 0.25}
because ambient 1 just gives a flat gray object with no visible features...
Do you need a specular map as well?
Does this need to be rendered with a transparent background (alpha channel) ?
Wow. Cool. I'd love to see the povray file. Yes, I need it rendered with a
transparent background (alpha channel).
Basically I need two images that are perfectly aligned. One is the normal map.
The other is an image of the asteroid, with the features visible, but with no
major shadows. That way the game engine can add light from any direction.
Josh
> Josh
Right, so the background and the normal map look good - the part that you may
want to experiment with is the lighting. As I mentioned, changing the lighting
- or the way the object responds to the lighting (finish) can either accentuate
- or completely wipe out any visible features. Because light and shadow (and
highlights/reflections) are the only visual cues you have to gauge shape and
depth.
I have it set to an area light, and left in a few options and commented-out
snippets of code for you to explore.
Others more skilled in the art (basically: everyone) may have better
recommendations for lighting and antialias settings. Because those are NOT my
strong points.
Load up the .pov file (don't render it), and then load up the .ini file.
run the .ini file, and it will render the .pov file twice - one in gray and once
in normal_map mode, with transparent background.
Just copy and paste the below into a text file named [filename].ini
; Persistence Of Vision raytracer sample file.
Antialias=On
Antialias_Threshold=0.25
Antialias_Depth=5
Test_Abort_Count=100
Input_File_Name=Asteroid_prototype.pov
Initial_Frame=1
Final_Frame=2
Initial_Clock=0
Final_Clock=1
Cyclic_Animation=off
Pause_when_Done=off
Just copy and paste the below into a text file named [filename].pov
#version 3.8;
global_settings {
assumed_gamma 1.0
ambient_light 1.0
#include "functions.inc"
#declare Zoom = 30;
orthographic
right x*image_width/(Zoom)
up y*image_height/(Zoom)
location <0, 0, -10>
look_at <0, 0, 0>
background {color rgbt <0,0,0,1>}
#declare Lighting = 1;
#switch (Lighting)
#case (0)
light_source {<0, 0, -10> colour rgb 1}
#break
#case (1)
// An area light (creates soft shadows)
light_source {
<0,0,0> // light's position (translated below)
color rgb 1.0 // light's color
area_light
<20, 0, 0> <0, 20, 0> // lights spread out across the plane defined by these
vectors
4, 4 // total number of lights in grid (4x*4z = 16 lights)
area_illumination off
adaptive 0 // 0,1,2,3...
jitter // adds random softening of light
//circular // make the shape of the light circular
orient // orient light
translate <0, 0, -10> // <x y z> position of light
#break
#case (2)
sphere {0, 11
clipped_by {plane {-z, -1}}
texture {pigment {rgb 0.9} finish {emission 1}}
#break
#else
light_source {<10, 0, -10> colour rgb 1}
// 1: plain gray
// 2: normal map for Godot shading
#declare Sprite = 1; //<--- use this to manually switch between gray and normal
map
#declare RedX =
slope {x}
color_map {
[ 0 color rgb <0, 0, 0> ]
[ 1 color rgb <1, 0, 0> ]
#declare GreenY =
slope {y}
color_map {
[ 1 color rgb <0, 1, 0> ]
#declare BlueZ =
slope {z}
color_map {
[ 0 color rgb <0, 0, 0.5> ]
[ 1 color rgb <0, 0, 1> ]
#declare NormalMap =
average
pigment_map {
[3 RedX ]
[3 GreenY ]
[3 BlueZ ]
finish { ambient 1 diffuse 0 }
#declare Radius = 2;
#declare Noise = function {f_noise3d (x, y, z) }
#declare P = pigment {Gray50} // may need adjusting
#declare G = function {pigment {granite scale 1.5}} // optional - see end of
isosurface function
#declare NS = 0.7; // NoiseScale
#declare NoiseStrength = 0.5;
#declare Asteroid =
isosurface {
//function {y - Noise (x, 0, z) * 2 }
function {
sqrt(pow (x, 2) + pow (y, 2) + pow (z, 2)) -
Radius -
(Noise (x/NS, y/NS, z/NS)*NoiseStrength)} // <-- delete this } to use function
G
// - G(x,y,z).x*0.25 }
max_gradient 2
accuracy 0.0001
contained_by {box {<-Radius, -Radius, -Radius>*2, <Radius, Radius*3, Radius>*2}
scale <1, 1.5, 1>
#switch (clock)
#case (0)
object {Asteroid
pigment {P}
finish {ambient 0.5 diffuse 0.25} // specular 0.25}
//normal {granite scale 1.5}
//translate -x*3
#break
#case (1)
object {Asteroid
texture {NormalMap}
//translate x*3
#break
#else text {ttf "cyrvetic.ttf", "NOPE.", 0.1, <0, 0> pigment {rgb <1, 0, 0>}
scale 5}
> #version 3.8;
> global_settings {
> assumed_gamma 1.0
> ambient_light 1.0
> #declare Zoom = 30;
> camera {
> orthographic
> look_at <0, 0, 0>
> #switch (Lighting)
> #case (0)
> #break
> #case (1)
> light_source {
> area_light
> vectors
> #break
> #case (2)
> sphere {0, 11
> #break
> #else
> #end
> // 1: plain gray
> map
> #declare RedX =
> pigment {
> slope {x}
> color_map {
> #declare GreenY =
> pigment {
> slope {y}
> color_map {
> #declare BlueZ =
> pigment {
> slope {z}
> color_map {
> texture {
> pigment {
> average
> pigment_map {
> [3 RedX ]
> [3 GreenY ]
> [3 BlueZ ]
> isosurface function
> #declare Asteroid =
> isosurface {
> function {
> Radius -
> G
> max_gradient 2
> accuracy 0.0001
> scale <1, 1.5, 1>
> #switch (clock)
> #case (0)
> object {Asteroid
> texture {
> pigment {P}
> //translate -x*3
> #break
> #case (1)
> object {Asteroid
> texture {NormalMap}
> //translate x*3
> #break
> scale 5}
> #end
Thank you so much for sending this. I think I got it working. But from what I
can tell, the normal map isn't quite right. All the colors are 'washed out'. I
would expect that near the center of the asteroid, the color would be RGB
128,128,255, and that near the right edge the red component would be 255, and
near the left edge the red component near 0, and the same for the green, close
to 0 and 255 near the edges. Maybe mind didn't render correctly or it isn't
quite right yet.
> quite right yet.
A guess. Perhaps the normal map image needs to be in a linear color
space and not POV-Ray's default sRGB output space. Unsure whether the
base sprite would need this too. Depends on what your game engine wants
in the end.
You can specify the output file gamma to use (for PNGs) in your ini
file. However, if the base image needs sRGB and the normal image map a
linear representation, it might be easier to use the command line. For
just the normal map image something like:
povray +ua +k0.0 File_Gamma=sRGB +am2 +a0.1 +r3 +oI.png BaldEagle.pov
povray +ua +k1.0 File_Gamma=1.0 +am2 +a0.1 +r3 +oN.png BaldEagle.pov
for two images using different color space encodings.
Bill P.
Aside: Anyone know if there is a short flag for File_Gamma? Looked like
no, but not had my morning coffee.
I
> quite right yet.
The answer lies here:
http://www.povray.org/documentation/view/3.6.1/393/
0.5
right now, if the camera is pointing this way ---> the results are 0------1.0
0.5
So the whole normal result needs to get adjusted.
I'm not sure if there's a way to rotate the results by 90 deg along the r and g
axes...
Would using these same averaging parameters counter the long lasting slope map
default and at last allow to use the resulting normal map and apply it in POV on
the raw mesh the same way Godot can do it?
