POV-Ray : Newsgroups : povray.general : Object inside opaque media Server Time
18 May 2024 09:01:35 EDT (-0400)
  Object inside opaque media (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Object inside opaque media
Date: 11 Nov 2018 11:43:11
Message: <5be85c1f$1@news.povray.org>
On 11-11-2018 15:26, Shuffle wrote:
> Ok, many thanks everyone for your replies, I'll try to answer to all of them,
> but most suggestions don't apply to my problem or have already been tried... so
> I hope to also clarify what I actually need.
>> Thomas de Groot: The following is about the best I can get
> Thank you for your time and efforts :-) but unless you used some special
> rendering options, when I rendered it the atmosphere is way too bright and the
> sphere can still be distinctly seen through the media.
> More ideas welcome :-)
> PS: this is a professional need, so unfortunately I cannot let go...
I have been thinking since. In RL, atmosphere is always more or less
transparent. What you need is a second media to simulate a cloud layer.
I shall look into that tomorrow.
Date: 11 Nov 2018 12:35:06
Message: <web.5be86811ddef308a765e06870@news.povray.org>
"Shuffle" <shu### [at] gmailcom> wrote:
> > Bald Eagle: Have a look at:
http://news.povray.org/povray.binaries.animations/thread/%3Cweb.5b32f0c22078c5ce458c7af
e0
> %40news.povray.org%3E/
> This is interesting, especially because I don't use POV 3.8 so I had a glimpse
> at new features ;-)
> I downloaded alpha9893777 and proceeded to render the (50 frames) animation: at
> no moment is the grey plane invisible behind or inside the media. I understand
> this is not the purpose of that scene, and the hidden sphere is actually hidden,
> but my need is to have an actually visible object, only hidden because of the
> density of the media.
The purpose there was to show how you can use 3 different functions to control
the color, by having a separate function for r, g, and b, and then adding them
together.
> Basically, what I want is exactly what happens in nature with fog: the objects
> are always there, but as you increase the distance to them, you can't see them
> anymore because the droplets absorb their light and diffuse that of the sun
> instead.
> Maybe I do not understand what you mean, but this does not change the fact that
> a constant density of 1 still allows seeing the sphere through the media. It is
> not a matter of color itself, I can pretty much set any color I want, including
> a color_map for the density, the object inside is always visible.
> What I would probably need are densities higher than 1, or something that mimics
> it.
YES.
>But since densities are looped in the 0-1 range, this is not possible with
> the current implementation of density, unless I missed something...
Don't count me as an expert - media can be, and usually is, a complicated thing
to use, especially properly/accurately.
http://www.povray.org/documentation/view/3.6.1/413/
"Imagine media as a density of particles, you specify 100 particles per cubic
pov-unit. If we scale a 1 cubic pov-unit object to be twice as big in every
direction, we will have a total of 800 particles in the object. The object will
look different, as we have more particles to look through. Yet the objects
density is still 100 particles per cubic pov-unit. In media this "particle
density" is set by the color after emission, absorption, or in the scattering
statement"
I think what you need to do is a calibration scene, much like doing a
calibration exposure in the Zone System for making black & white prints.
Stretch a box across the screen, and define a wedge shape to hold your media.
That way you go from 0 - 100% in terms of "obscurement".
Then you can fiddle with the "density" of the media to find out at what point
you can no longer see through it.
Date: 11 Nov 2018 12:44:39
Message: <5be86a87$1@news.povray.org>
>> of them,
>> tried... so
>> and the
Faster than light ;-)
I include a scene with a cloud layer. Please play around with
MediaScale1 and MediaScale2 as those determine the aspect/thickness of
the media.
I do not use any special rendering options. See image in p.b.i.
Download 'planet media_test.pov.txt' (3 KB)
Date: 11 Nov 2018 15:14:12
Message: <5be88d94$1@news.povray.org>
Am 11.11.2018 um 15:26 schrieb Shuffle:
> instead.
Technically, that's actually not true: The reason that you cannot see
objects in dense fog is not because the light is absorbed completely -
the light from the object falls off logarithmically, so at any finite
distance you'll still get a finite non-zero portion of direct light from
the object.
The reason you cannot see objects in dense fog is because the object's
light gets too dim compared to scattered light.
>> Alain: Try adding some absorbing media.
> That's what I did, including in the scene I posted in my original message. It
> does no good: no matter what combinations of absorption and scattering, you can
> always see the object through the media. Emission is obviously not an option,
> because the unlit hemisphere must stay black.
You may have to crank up the absorption even more.
If even madly high values give you no success, there may be an issue
with the sampling of the media; so toying with the quality settings may
also be worth a try.
> it. But since densities are looped in the 0-1 range, this is not possible with
Cranking up the colour values is what you want.
Date: 11 Nov 2018 15:45:00
Message: <web.5be89453ddef308a765e06870@news.povray.org>
Here's something along the lines of what I was thinking, just to show the
concept. I haven't altered the media parameters (as Alain will point out) from
the example in the wiki, except for changing it to absorption of red x 10
#version 3.8;
global_settings {assumed_gamma 1.0}
 location <0, 0, -12.0>
 look_at 0
 //angle 30
light_source {<0, 2, -20> White}
#declare Container_T= texture {
   pigment {rgbt <1,1,1,1>}
   finish {ambient 0 diffuse 0}
#declare Scale=2;
// linear prism in y-direction: from .. ,to ..,number of points (first = last)
prism { -1.00,  1.00 , 4
       <-5.00,  0.00>, // first point
       <-5.00, -1.00>,
       < 5.00,  0.00>,
       <-5.00,  0.00>  // last point = first point !!!
   hollow
   texture {Container_T}
   interior {
      media {
         intervals 1
         samples 1,1
         absorption <10, 0, 0>
   translate <-2.1,0,0>
box {<-8, -1, 0.5>, <8, 1, 1> pigment {Red}}
Date: 11 Nov 2018 16:08:59
Message: <5be89a6b@news.povray.org>
Am 08.11.2018 um 17:02 schrieb Shuffle:
> What I actually try to achieve is to model a planet with a dense atmosphere.
> Like Venus or, in my case, Saturn's moon Titan. The camera will approach the
> body and dive into the atmosphere, revealing the terrain only at lower
> altitudes.
> You can get a pretty good idea of what I'm trying to achieve by following this
> link: https://www.youtube.com/watch?v=9L471ct7YDo&t=55s
I've only found time now to completely read your original post.
I can guarantee you that in order to achieve what you're shooting for
you /will/ have to cheat.
POV-Ray provides two mechanisms to deal with scattering material:
- The older mechanism, "media", only creates realistic results for cases
where the mean free distance (the average distance a light ray travels
before being scattered or absorbed) is larger than the distance between
camera and object. (*)
- The newer mechanism, "subsurface light transport", only creates
realistic results for cases where the mean free distance is
significantly smaller than the dimensions involved. (Besides, it
requires the material to have a clear-cut surface.)
In a camera dive into the atmosphere of a densely clouded planet down to
the surface, you are transitioning from the regime where the mean free
distance is comparatively small to the regime where it is comparatively
large.
The easiest solution is probably to create two entirely separate
animation sequences: One that takes you from orbit into dense atmosphere
(with the planet invisible), and another one that takes you from dense
atmosphere down to the surface (with the sky invisible).
The trick then will be to match the colour of the first animation's last
frame to the second animation's first frame - or simply do a slow fade
between the two animations.
(*) The problem is not so much that you can't use scattering media to
obscure objects inside it - you can, all you have to do is crank up the
density / colour high enough. The true problem is the scattering effect,
which will go bonkers at such high settings, even if you mess with the
extinction setting and/or add extra absorbing media.
Date: 11 Nov 2018 17:51:04
Message: <5be8b258$1@news.povray.org>
I think this addresses the nub of the problem.
Because what we want to do is compress what, in real life, would take
quite some time, to a video short enough to hold our attention and have
a reasonable file size.
As Tom Lehrer implied in "Lobachevsky"*. The answer is to cheat.
I think it can be done with just textures, transparency and the right
transitions. But as my wife is getting out of hospital this week. I
don’t think that I’ll have time to work on the transitions.
For those too young to remember. ;)
https://www.youtube.com/watch?v=gXlfXirQF3A
Regards
Date: 11 Nov 2018 19:01:15
Message: <5be8c2cb$1@news.povray.org>
Le 18-11-09 à 03:09, Thomas de Groot a écrit :
> On 9-11-2018 9:01, Thomas de Groot wrote:
>>              absorption srgb <0.1, 0.3, 0.5>*10
> better to also use:
>              absorption srgb <0.1, 0.3, 0.5>*10/Scale
srgb <0.1, 0.3, 0.5> is lighter than rgb <0.1, 0.3, 0.5>
srgb <0.1, 0.3, 0.5>*10 is much darker than rgb <0.1, 0.3, 0.5>*10
In both cases, the resulting hue with srgb will get shifted toward the red.
Date: 12 Nov 2018 18:15:28
Message: <5bea0990$1@news.povray.org>
>> Stephen: Have you tried to use the transmit value to control the transparency of
the atmosphere?
> This is not applicable because, for any non-zero transmit value, there will be a
> sudden change when the camera goes from outside to inside the media container.
> Also, the object inside the media should not become visible as soon as we enter
> the atmosphere, only at lower altitudes, as in the video I linked. So even with
> a transmit set by a function of the distance to the atmosphere boundary, this
> would still not be what I need.
Clipka is right in saying a two shot approach is the way to go.
Media can be time consuming. Do you have your heart set on using it?
If you want or need to use media. I would try to make a density map that
had zero density from the centre to the surface of the planet and using
a spherical gradient, from the surface of the planet to the limit of the
atmosphere. Or you could cheat and difference a sphere around your
camera. Then fill that with a less dense media.
After making the video below. Where the whole murky atmosphere gets more
transparent the closer you get to the planet. I think that using a one
shot approach would take too long to get to the point of interest and
the file size would be too large. Then there is the problem with the
resolution of the point of interest at different heights. So for the
close to land shot. I would create a “Sphere of Visibility” around your
camera and have the material or texture be densest at the surface and
zero in the centre. If you use transparency you could use a colour map
as a density curve.
https://youtu.be/gqVw5K9ePyU
Regards
Date: 12 Nov 2018 22:40:01
Message: <web.5bea4685ddef308a765e06870@news.povray.org>
I think perhaps there's no reason one has to stick to a static construct with
the only change being the camera location.
Since for every animation frame the scene can change, perhaps the way to do it
in one shot is to dynamically adapt the media density to what that frame
requires to achieve the desired look.
So graph out what you want in terms of visibility, and then based on the
distance between the camera and the planet's surface, change the density to fit
your needs at that instant.
Similar to what others have proposed, you could define your visibility as a
spline, interpolate, and use the camera distance to the planet to index a
density value.
There's probably other ways to do it, but I'd say the first step would be to
story-board out the animation and use that as a guide to define very detailed
requirements for key points in the animation, and then see what the best method
to transition between those points is likely to be in terms of time, complexity,
and quality of end result.
Just my take on how I'd likely approach this.
