POV-Ray : Newsgroups : povray.general : Object inside opaque media Server Time
19 May 2024 03:38:16 EDT (-0400)
  Object inside opaque media (Message 7 to 16 of 26)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Object inside opaque media
Date: 9 Nov 2018 03:26:26
Message: <5be544b2$1@news.povray.org>
Am 08.11.2018 um 17:02 schrieb Shuffle:
> What I could not find is a way to set the density using a function{} block and
> still be able to control the color independently.
You could use three independent media blocks, each one affecting only a
single colour channel.
Date: 9 Nov 2018 03:30:30
Message: <5be545a6$1@news.povray.org>
Am 09.11.2018 um 09:09 schrieb Thomas de Groot:
> On 9-11-2018 9:01, Thomas de Groot wrote:
>>              absorption srgb <0.1, 0.3, 0.5>*10
> better to also use:
>              absorption srgb <0.1, 0.3, 0.5>*10/Scale
Never try to scale sRGB colours this way. It won't work as expected.
Either use linear colour values, or store the sRGB colour(!) in a
variable and then scale it (though IIRC the syntax for the latter is
tricky).
Date: 9 Nov 2018 06:58:57
Message: <5be57681$1@news.povray.org>
>> better to also use:
> tricky).
Yes. I remember now. My bad. However, principle for the scene remains
the same.
Date: 11 Nov 2018 09:30:00
Message: <web.5be83812ddef308a994738e60@news.povray.org>
Ok, many thanks everyone for your replies, I'll try to answer to all of them,
but most suggestions don't apply to my problem or have already been tried... so
I hope to also clarify what I actually need.
> Stephen: Have you tried to use the transmit value to control the transparency of the
atmosphere?
This is not applicable because, for any non-zero transmit value, there will be a
sudden change when the camera goes from outside to inside the media container.
Also, the object inside the media should not become visible as soon as we enter
the atmosphere, only at lower altitudes, as in the video I linked. So even with
a transmit set by a function of the distance to the atmosphere boundary, this
would still not be what I need.
> Bald Eagle: Have a look at:
http://news.povray.org/povray.binaries.animations/thread/%3Cweb.5b32f0c22078c5ce458c7afe0
%40news.povray.org%3E/
This is interesting, especially because I don't use POV 3.8 so I had a glimpse
at new features ;-)
I downloaded alpha9893777 and proceeded to render the (50 frames) animation: at
no moment is the grey plane invisible behind or inside the media. I understand
this is not the purpose of that scene, and the hidden sphere is actually hidden,
but my need is to have an actually visible object, only hidden because of the
density of the media.
Basically, what I want is exactly what happens in nature with fog: the objects
are always there, but as you increase the distance to them, you can't see them
anymore because the droplets absorb their light and diffuse that of the sun
instead. But I can't simply use POV's "fog" feature because I also need to go
from outside to inside the foggy area, and when I'm outside, the foggy area is
in fact a sphere of non-uniform density.
> Alain: Try adding some absorbing media.
That's what I did, including in the scene I posted in my original message. It
does no good: no matter what combinations of absorption and scattering, you can
always see the object through the media. Emission is obviously not an option,
because the unlit hemisphere must stay black.
> Thomas de Groot: The following is about the best I can get
Thank you for your time and efforts :-) but unless you used some special
rendering options, when I rendered it the atmosphere is way too bright and the
sphere can still be distinctly seen through the media.
> clipka: You could use three independent media blocks, each one affecting only a
Maybe I do not understand what you mean, but this does not change the fact that
a constant density of 1 still allows seeing the sphere through the media. It is
not a matter of color itself, I can pretty much set any color I want, including
a color_map for the density, the object inside is always visible.
What I would probably need are densities higher than 1, or something that mimics
it. But since densities are looped in the 0-1 range, this is not possible with
the current implementation of density, unless I missed something...
More ideas welcome :-)
PS: this is a professional need, so unfortunately I cannot let go...
Date: 11 Nov 2018 11:43:11
Message: <5be85c1f$1@news.povray.org>
I have been thinking since. In RL, atmosphere is always more or less
transparent. What you need is a second media to simulate a cloud layer.
I shall look into that tomorrow.
Date: 11 Nov 2018 12:35:06
Message: <web.5be86811ddef308a765e06870@news.povray.org>
e0
> at new features ;-)
The purpose there was to show how you can use 3 different functions to control
the color, by having a separate function for r, g, and b, and then adding them
together.
> instead.
> it.
YES.
Don't count me as an expert - media can be, and usually is, a complicated thing
to use, especially properly/accurately.
http://www.povray.org/documentation/view/3.6.1/413/
"Imagine media as a density of particles, you specify 100 particles per cubic
pov-unit. If we scale a 1 cubic pov-unit object to be twice as big in every
direction, we will have a total of 800 particles in the object. The object will
look different, as we have more particles to look through. Yet the objects
density is still 100 particles per cubic pov-unit. In media this "particle
density" is set by the color after emission, absorption, or in the scattering
statement"
I think what you need to do is a calibration scene, much like doing a
calibration exposure in the Zone System for making black & white prints.
Stretch a box across the screen, and define a wedge shape to hold your media.
That way you go from 0 - 100% in terms of "obscurement".
Then you can fiddle with the "density" of the media to find out at what point
you can no longer see through it.
Date: 11 Nov 2018 12:44:39
Message: <5be86a87$1@news.povray.org>
>> of them,
>> tried... so
>> and the
Faster than light ;-)
I include a scene with a cloud layer. Please play around with
MediaScale1 and MediaScale2 as those determine the aspect/thickness of
the media.
I do not use any special rendering options. See image in p.b.i.
Download 'planet media_test.pov.txt' (3 KB)
Date: 11 Nov 2018 15:14:12
Message: <5be88d94$1@news.povray.org>
Am 11.11.2018 um 15:26 schrieb Shuffle:
> instead.
Technically, that's actually not true: The reason that you cannot see
objects in dense fog is not because the light is absorbed completely -
the light from the object falls off logarithmically, so at any finite
distance you'll still get a finite non-zero portion of direct light from
the object.
The reason you cannot see objects in dense fog is because the object's
light gets too dim compared to scattered light.
You may have to crank up the absorption even more.
If even madly high values give you no success, there may be an issue
with the sampling of the media; so toying with the quality settings may
also be worth a try.
Cranking up the colour values is what you want.
Date: 11 Nov 2018 15:45:00
Message: <web.5be89453ddef308a765e06870@news.povray.org>
Here's something along the lines of what I was thinking, just to show the
concept. I haven't altered the media parameters (as Alain will point out) from
the example in the wiki, except for changing it to absorption of red x 10
#version 3.8;
global_settings {assumed_gamma 1.0}
 location <0, 0, -12.0>
 look_at 0
 //angle 30
light_source {<0, 2, -20> White}
#declare Container_T= texture {
   pigment {rgbt <1,1,1,1>}
   finish {ambient 0 diffuse 0}
#declare Scale=2;
// linear prism in y-direction: from .. ,to ..,number of points (first = last)
prism { -1.00,  1.00 , 4
       <-5.00,  0.00>, // first point
       <-5.00, -1.00>,
       < 5.00,  0.00>,
       <-5.00,  0.00>  // last point = first point !!!
   hollow
   texture {Container_T}
   interior {
      media {
         intervals 1
         samples 1,1
         absorption <10, 0, 0>
   translate <-2.1,0,0>
box {<-8, -1, 0.5>, <8, 1, 1> pigment {Red}}
Date: 11 Nov 2018 16:08:59
Message: <5be89a6b@news.povray.org>
> What I actually try to achieve is to model a planet with a dense atmosphere.
> Like Venus or, in my case, Saturn's moon Titan. The camera will approach the
> body and dive into the atmosphere, revealing the terrain only at lower
> altitudes.
> You can get a pretty good idea of what I'm trying to achieve by following this
> link: https://www.youtube.com/watch?v=9L471ct7YDo&t=55s
I've only found time now to completely read your original post.
I can guarantee you that in order to achieve what you're shooting for
you /will/ have to cheat.
POV-Ray provides two mechanisms to deal with scattering material:
- The older mechanism, "media", only creates realistic results for cases
where the mean free distance (the average distance a light ray travels
before being scattered or absorbed) is larger than the distance between
camera and object. (*)
- The newer mechanism, "subsurface light transport", only creates
realistic results for cases where the mean free distance is
significantly smaller than the dimensions involved. (Besides, it
requires the material to have a clear-cut surface.)
In a camera dive into the atmosphere of a densely clouded planet down to
the surface, you are transitioning from the regime where the mean free
distance is comparatively small to the regime where it is comparatively
large.
The easiest solution is probably to create two entirely separate
animation sequences: One that takes you from orbit into dense atmosphere
(with the planet invisible), and another one that takes you from dense
atmosphere down to the surface (with the sky invisible).
The trick then will be to match the colour of the first animation's last
frame to the second animation's first frame - or simply do a slow fade
between the two animations.
(*) The problem is not so much that you can't use scattering media to
obscure objects inside it - you can, all you have to do is crank up the
density / colour high enough. The true problem is the scattering effect,
which will go bonkers at such high settings, even if you mess with the
extinction setting and/or add extra absorbing media.
