Before Alain castigates you:
"For media, the defaults are :
method 3
intervals 1
samples 10
confidence is NOT used
variance is NOT used
Only the first value of samples is ever used if you provide two.
Using intervals >1 greatly impaire your rendering speed.
Using intervals with a value larger than 1 is only adviseable if using
method 1 or 2."
I had to rewrite your code to make use of the texture. What inc file are you
using?
This is as far as I got so far:
/* cf 'no_image' */
#version 3.7;
global_settings {
assumed_gamma 1.0
charset utf8
//#include "d2mat.inc"
#declare Mline1 = material {
//pigment {srgbft <1,1,1,1,1>}
pigment {rgbt 1}
finish {
ambient 0
brilliance 1
crand 0
diffuse 0
metallic 0
phong 0
phong_size 40
specular 0
roughness 0.05
interior {
ior 1.1
caustics 0
dispersion 1
dispersion_samples 7
fade_power 0
fade_distance 0
fade_color rgb <0,0,0>
media {
method 3
intervals 1
samples 10
//confidence 0.9
//variance 0.005
ratio 0.9
absorption 0
emission rgb <1,0,0>
aa_threshold 0.1
aa_level 4
#declare Mline2 = Mline1;
#declare Mline3 = Mline1;
#declare Mbox1 = Mline1;
#declare Mbox2 = Mline1;
#declare Mbox3 = Mline1;
orthographic
location <5,4,-20>
look_at <5,4,0>
right x*(image_width/image_height)
up <0,1,0>
angle 90
#declare Oline1 = box {
<0,1,0>, <20,2,20>
hollow
material {Mline1}
// no_image
no_reflection
no_shadow
#declare Oline2 = box {
<0,4,0>, <20,5,20>
hollow
material {Mline2}
// no_image
no_reflection
no_shadow
#declare Oline3 = box {
<0,7,0>, <20,8,20>
hollow
material {Mline3}
// no_image
no_reflection
no_shadow
#declare Obox1 = box {
<1,0,4>, <2,15,5>
hollow
material {Mbox1}
no_reflection
no_shadow
#declare Obox2 = box {
<4,0,4>, <5,15,5>
hollow
material {Mbox2}
no_reflection
no_shadow
#declare Obox3 = box {
<7,0,7>, <8,15,8>
hollow
material {Mbox3}
no_reflection
no_shadow
union {
object {Oline1}
object {Oline2}
object {Oline3}
object {Obox1}
object {Obox2}
object {Obox3}
/* this is not scaled */
On 17/06/2018 17:36, clipka wrote:
> As for the `no_image` keyword, marking an object in this manner will (or
> at least is intended to) cause it to/not/ "be there" - i.e. have /no
> effect whatsoever/ - in the context of primary rays, while still "being
> there" in the context of secondary rays (e.g shadow computations and
> reflections).
From my tests that is what happens.
Maybe it should be spelt out in the documentation?
From my reading that case is undefined.
Regards
hi,
clipka <ano### [at] anonymousorg> wrote:
> Am 17.06.2018 um 16:05 schrieb jr:
> > I tried using the 'no_image' object modifier to achieve an effect where one
> > (emissive) media filled container, hidden, is intersected by another, visible
> > one.
> Your description of the desired effect is pretty vague: I understand
> that you want an object to be "hidden" (whatever that means), yet
> interact with some other visible object in /some/ (unspecified) manner,
> but that's about it.
> You're even talking about "intersecting" media containers, but your
> sample scene only has a union.
ah, sorry, guilty as charged. what I meant is: hidden == no_image modifier, by
intersecting I meant just that, the horizontals + verticals go through one
another, did not think about the CSG meaning.
> at least is intended to) cause it to /not/ "be there" - i.e. have /no
> reflections).
what does "primary" and "secondary" rays mean, in the context? that is, in a
scene with only emissive media objects and zero light_source(s).
regards, jr.
LOL :-)
I replicated the conditions with two elongated boxes that intersected at
90° to each other.
I did notice what looked like a coincidence surface problem. And when I
turned the union into a merge. It looked like a difference with the
intersection black. (I was using red and green emissive media to give
yellow at the intersection.)
Regards
hi,
> method 3
> intervals 1
> samples 10
> method 1 or 2."
I will need to re-read this later. :-) thanks.
> using?
just storage for the materials.
> texture {
> pigment {rgbt 1}
that is what I started off with. modified to 5-colour after reading
LeForgeron's reply.
and the materials that weren't included -- they're all identical, bar the colour
(using red, green, blue, cyan, magenta, and yellow).
regards, jr.
Am 17.06.2018 um 19:59 schrieb jr:
>> reflections).
Primary rays are rays traced (backward) from the camera into the scene.
Seconary rays are rays traced (backward) from any "point of interest"
other than the camera. Typically, the point of interest is an
intersection of the primary ray with an object's surface, but it could
also be a point in a media container where scattering effects are computed.
Primary rays are traced to determine which object surfaces are "seen"
directly in the scene (including surfaces defined to have an invisible
texture), and what interiors (if any) lie between the camera and the
first opaque surface.
Secondary rays may be traced for different purposes:
- A "shadow ray" would be traced from an object's surface to a light
source, to compute whether that light source directly illuminates the
object or whether a shadow is cast on the surface by other object
surfaces or interiors; or from a (sample) point in scattering media to a
light source, to compute whether that light source directly illuminates
that region of space or whether the volumetric equivalent of a shadow is
cast on that region of space.
- A "reflection ray" would be traced from a (reflective) object's
surface in the direction given by the law of reflection, to determine
what objects and interiors are reflected by the surface.
- A bunch of "radiosity rays" would be traced from a (sample) point on
an object's surface in somewhat random directions to determine how much
indirect illumination the point receives from other objects (including
emissive media).
- A bunch of "subsurface rays" would be traced from a point slightly
below an object's surface in somewhat random directions to determine how
much light is transported through the bulk of the object to the
corresponding point on the surface.
In POV-Ray, "refraction rays" are also considered "primary rays" for
historical and technical reasons. These would be traced from a
(transparent or semi-transparent) object's surface in the direction
given by snell's law, to determine what other objects and interiors can
be seen "behind" the object.
hi,
thank you for enumerating. on first reading my idea is a no go. :-(
will need time to re-read and try to understand the consequences.
regards, jr.
Am 17.06.2018 um 22:10 schrieb jr:
> hi,
Whatever you're trying to accomplish; maybe if you let us know we might
be able to bounce some ideas ;)
hi,
appreciated, thanks.
"the idea" is very simple, I would like to animate some visible, emissive media
objects such that they move through other, not directly seen (contained) media.
the effect I'm after is that the additive effect of the differently coloured
media when intersecting should reveal the outline of the "hidden" objects
through the colour change(s).
hope that parses. ;-)
regards ,jr.
Am 18.06.2018 um 03:12 schrieb jr:
> hi,
I think it does.
Did you try using one `difference` and one `intersection` of the
container objects in question, with different media?
Or you could use one `merge` of the objects with the normal media "A",
and one `intersection` with a media "B-A" (IIRC you can have negative
emission, absorption or even scattering).
