POV-Ray : Newsgroups : povray.general : Using bezier_spline Server Time
29 Sep 2024 00:15:55 EDT (-0400)
  Using bezier_spline (Message 1 to 8 of 8)
Subject: Using bezier_spline
Date: 23 May 2018 18:30:00
Message: <web.5b05ea92c0e42ed13ce674f0@news.povray.org>
I draw a curvy line with spline in POVRAY as
camera {location <0,15,5> look_at <0,0,0>}
light_source {<0,5,12> color rgb<1,1,1>}
background {color rgb<1,1,1> }
#declare Spline_1 =
  spline {
   cubic_spline
  -.2, <-5,1.0,-5>,
   .1, <-4,1.0,-2>,
   .2, <-3,1.0,3.5>,
   .3, <-2,1.0,2>,
   .4, <-1,1.0,-1>,
   .5, <0,1.0,0>,
   .6, <1,1.0,1>,
   .7, <2,1.0,0>,
   .8, <3,1.0,1>,
   .9, <4,1.0,0>,
   1.0, <5,1.0,3>,
   1.2, < 6,1.0,5>
 #declare Nr = 0;
 #while (Nr<1)
 sphere{ <0,0,0>,0.27
          texture{ pigment{color rgb <1-Nr/2,0.75+Nr/4,1>}
                  finish {diffuse 0.9 phong 1}
        #declare Tr = Nr * 3;
         translate Spline_1(Nr)
 #declare Nr = Nr + 0.001;
but bezier_spline is a better option for this sort of curves. However, the usage
of bezier_spline and its controller points is not very clear from the povray
documentation.
How can I use bezier_spline in this example?
Subject: Re: Using bezier_spline
Date: 24 May 2018 06:18:03
Message: <5b06915b$1@news.povray.org>
> #declare Spline_1 =
>    spline {
>     cubic_spline
>    -.2, <-5,1.0,-5>,
>     .1, <-4,1.0,-2>,
>     .2, <-3,1.0,3.5>,
>     .3, <-2,1.0,2>,
>     .4, <-1,1.0,-1>,
>     .5, <0,1.0,0>,
>     .6, <1,1.0,1>,
>     .7, <2,1.0,0>,
>     .8, <3,1.0,1>,
>     .9, <4,1.0,0>,
>     1.0, <5,1.0,3>,
>     1.2, < 6,1.0,5>
>   #declare Nr = 0;
>   #while (Nr<1)
>   #end
> documentation.
To my knowledge bezier_spline has never been an option of spline {} in
any official offering. See documentation at :
http://wiki.povray.org/content/Reference:Spline
There are SDL implementations. See for example the object collection at:
http://lib.povray.org/searchcollection/index.php
and search for the keyword 'sphere_sweep'. Both the PointArrays package
and the SphereSweep packages which come up in that search have Bezier
spline support.
Bill P.
Date: 24 May 2018 08:16:38
Message: <5b06ad26$1@news.povray.org>
> documentation.
I use the Colefax spline macro for all my spline needs.
http://www.oocities.org/siliconvalley//lakes/1434/spline/index.html
dik
Rendered 328976 of 330000 (99%)
Date: 24 May 2018 18:00:00
Message: <web.5b0735658fdca69f7a63dc9f0@news.povray.org>
> dik
Interesting, thanks. The tension parameter seems useful in some situations.
Would be interesting to get this parameter nativly in povray.
By the way, is it possible to glue splines in povray. By gluing, I mean I have 2
splines, one from points p0 to pn and the second one from points pn to pq. Then
I would like to concatenate the 2 splines and get one spline from p0 to pq that
I could use like a usual spline.
Date: 24 May 2018 18:20:00
Message: <web.5b073a358fdca69f7a63dc9f0@news.povray.org>
> However, the usage
> documentation.
The splines are hard to follow because the doc is spread at various locations.
The page I like is the following one:
 http://www.povray.org/documentation/view/3.7.0/60/
If you know a little bit about bezier splines, it should be clear what povray
does from this page...
Date: 25 May 2018 16:08:01
Message: <5b086d21@news.povray.org>
>> dik
Yes, in a way.
If the spline is from a sphere_sweep, simply putting them into an union
will do the trick.
If you want a genuine spline that is the concatenation of two or more
splines, it's more complex : You need to edit the splines to make a
single one from the points of the original ones. If you have anything
else than a linear spline, you need to take care of the control points.
Date: 25 May 2018 16:49:21
Message: <5b0876d1$1@news.povray.org>
>>> dik
>> situations.
>> mean I have 2
>> pq. Then
>> to pq that
> Yes, in a way.
> will do the trick.
If I remember well. Moray had an object that was a bezier patch that did
what was required in two dimensions.
I have no idea how they did it.
Regards
Date: 25 May 2018 21:00:01
Message: <web.5b08b1698fdca69f10874a080@news.povray.org>
> > Yes, in a way.
> > will do the trick.
Right.  To manipulate truly as one spline, they should be redefined as a single
spline.
If you're just looking to "stick them together" so that they can be manipulated
as the same object, then unioning them together will do that, but you'll have to
think about the alignment.
One will have to be translated into the proper position, if it isn't already
defined that way, and to get the right junction point, you need to look at the
slopes and curvatures, which IIRC is done by matching the first and second
derivatives of the curves.
Way easier to let POV-Ray just handle the raw data points.
I have always found it easier to define an array of points and then use the
array in the spline or sphere-sweep.
POV-Ray has the bicubic patch, which is a Bezier patch, but I've found that the
best results for aligning it would be to have a 3x3 grid of them tethered
together at the edges.
I tried this a while back - really really tried, and didn't succeed.
Perhaps I'll take another stab at it some day.
