Le 18-01-28 à 14:01, Kenneth a écrit :
>> Maybe it's worth first clearing up the term "evaluate".
> Thanks for your detailed answer. I know it can't be easy to explain such an
> 'all-encompassing' question as mine-- particularly when I'm not being completely
> clear with the proper terms to use (and I'm probably further confusing the issue
> by discussing two different aspects of POV-ray as if they are one:
> 'instantiating' elements in a scene, and the operations performed during the
> parse/render stages.) Honestly, I'm still 'groping my way through a fog' to
> arrive at a proper set of intelligent questions ;-) And to fully understand some
> of the details of your reply.
> My use of the term 'evaluate' is probably a bit shabby and uninformed. What I
> really mean is, 'where the hard time-consuming work is done.' For instance,
> pre-#declaring an image_map for multiple use later: 'Evaluate' would mean,
> 'during the #declare step' (and the parse stage)... then it's simply
> instantiated later, with no extra time-consuming work required during the parse
> or render stages (a gross simplification of what really happens there.) In other
> words, the greatest amount of time time is spent 'evaluating' that image_map
> only once.
> I obviously need a better phrase to describe that paradigm.
>> Maybe what you mean is something I'd call "creating an instance" of, or
>> just "instantiating", an object: Reserving a block of memory as required
>> for a primitive of that particular type, and filling in the values
>> required later during the render stage. This may include a few
>> precomputed values, but for most primitives it is just the data
>> specified in the SDL code.
> Yes, that's basically it.
In the case of an image_map, that image can be seen as a kind of
constant. It's a container of many values that are each constants by
themselves.
So, while the #declare don't actually evaluate anything in this case,
but only assign a name and some work space, it can be evaluated later.
In this case, it's more loading the image file, and usually decoding it,
that takes time. You can save a lot of time by attributing it to some
identifier to be used later in several places.
Same goes for a mesh or a complex blob object.
On 28-1-2018 20:25, Stephen wrote:
> How nice this Newsgroup is compared to most open forums and newspapers.
> {I just felt like saying.}
I second that. I would have left long ago otherwise.
I just noticed that my original post's title has been changed here (in the
newsgroups' web interface, at least). What the...??? I had to look around to
find my own post!
When I look in 'Thread Digest', it has changed to "OT: How nice..." (!!) But if
I look in 'POV-Ray Topics/General', it has its original title of "parse vs.
render stages, and best use of memory."
Hmm. Some gremlins or leprechauns are having some fun somewhere...
> find my own post!
Oops! sorry. 'Twas I
If you look at the thread in a newsgroup reader. It is only a branch of
the thread that has that title. Replies to any other posts will gave
your original one.
I just wanted to commend the manners of the newsgroup.
Regards
Ah, the leprechaun has been unmasked :-P
Strange that it shows up in such a way in the web interface; I've actually
noticed this title-switching before, over the years.
How did you do it?? My inquiring mind is curious. I won't tell anyone ;-)
Begora and the cream o' the morning to ye. ;-)
I'm sure you can't do it on the web interface.
When you reply to a post using a newsgroup reader. At least in
Thunderbird, you get a pop up window just like an email. You can change
the subject line there.
Also when using a newsgroup reader. It can sort the threads into
branches, following a separate conversations. Allowing you to see who
replied to what. And some newsgroup readers allow you to ignore branches
or whole threads.
Regards
That's really strange and fascinating. Looks like something the web admin should
take a look at, if a post's title can be so easily changed inadvertently (or on
purpose by a 'malicious' gremlin, egads; chaos would ensue!)
Thanks. And Top 'o the mornin' to ya, laddie. (Well, it's evening here, but what
the He..)
It is deliberate IIRC. Many moons ago when I was a callous youth(ish).
You could only access the groups with a newsreader. After a lot of
complaints from noobs. A website with limited access was created. As for
the Admin, he went to the darkside (photography), years ago. I think the
site just runs on automatic until it stalls.
BTW
Using a newsreader can give you access to more groups than you can see
on the website. And posts appear instantly you don't have to wait.
</sales pitch> ;-)
> the He..)
Likewise, the sun is over the horizon, somewhere on Earth.
Regards
No need to worry. No data was changed. The SQL query behind the thread digest
shows the title of the newest message in a thread. The thread activity digest
shows the title of the first message, and you can see that it didn't change :-)
The web frontend does actually know the thread structure and could properly
display it. However, back when Chris Cason and I developed the web interface,
HTML and CSS were not far enough along to create a good interface for it in a
finite amount of time (we had to have it work on IE 5&6!), so we stuck to a
plain view.
Thorsten
Thanks. And I see that the thread activity digest does indeed show the original
title; I didn't notice that before.
I book-marked the original thread anyway, at an earlier date, so all's well. I
think Stephen pointed out that the 'new' "OT :-)" title--as seen in the main
thread digest-- will actually change back to the *original* title, if I or
someone else posts a reply to one of the 'earlier-than-OT :-)' posts(?) I
haven't tried that yet, but it sounds... fascinating ;-)
