POV-Ray : Newsgroups : povray.general : parse vs. render stages, and best use of memory Server Time
18 May 2024 01:25:59 EDT (-0400)
  parse vs. render stages, and best use of memory (Message 17 to 26 of 26)
Subject: Re: parse vs. render stages, and best use of memory
Date: 28 Jan 2018 18:46:49
Message: <5a6e60e9$1@news.povray.org>
Le 18-01-28 à 14:01, Kenneth a écrit :
>> Maybe it's worth first clearing up the term "evaluate".
> Thanks for your detailed answer. I know it can't be easy to explain such an
> 'all-encompassing' question as mine-- particularly when I'm not being completely
> clear with the proper terms to use (and I'm probably further confusing the issue
> by discussing two different aspects of POV-ray as if they are one:
> 'instantiating' elements in a scene, and the operations performed during the
> parse/render stages.) Honestly, I'm still 'groping my way through a fog' to
> arrive at a proper set of intelligent questions ;-) And to fully understand some
> of the details of your reply.
> My use of the term 'evaluate' is probably a bit shabby and uninformed. What I
> really mean is, 'where the hard time-consuming work is done.' For instance,
> pre-#declaring an image_map for multiple use later: 'Evaluate' would mean,
> 'during the #declare step' (and the parse stage)... then it's simply
> instantiated later, with no extra time-consuming work required during the parse
> or render stages (a gross simplification of what really happens there.) In other
> words, the greatest amount of time time is spent 'evaluating' that image_map
> only once.
> I obviously need a better phrase to describe that paradigm.
>> Maybe what you mean is something I'd call "creating an instance" of, or
>> just "instantiating", an object: Reserving a block of memory as required
>> for a primitive of that particular type, and filling in the values
>> required later during the render stage. This may include a few
>> precomputed values, but for most primitives it is just the data
>> specified in the SDL code.
> Yes, that's basically it.
In the case of an image_map, that image can be seen as a kind of
constant. It's a container of many values that are each constants by
themselves.
So, while the #declare don't actually evaluate anything in this case,
but only assign a name and some work space, it can be evaluated later.
In this case, it's more loading the image file, and usually decoding it,
that takes time. You can save a lot of time by attributing it to some
identifier to be used later in several places.
Same goes for a mesh or a complex blob object.
Subject: Re: OT: How nice...
Date: 29 Jan 2018 02:46:09
Message: <5a6ed141$1@news.povray.org>
On 28-1-2018 20:25, Stephen wrote:
> How nice this Newsgroup is compared to most open forums and newspapers.
> {I just felt like saying.}
I second that. I would have left long ago otherwise.
Date: 30 Jan 2018 15:35:00
Message: <web.5a70d604882c75ada47873e10@news.povray.org>
I just noticed that my original post's title has been changed here (in the
newsgroups' web interface, at least). What the...???   I had to look around to
find my own post!
When I look in 'Thread Digest', it has changed to "OT: How nice..." (!!) But if
I look in 'POV-Ray Topics/General', it has its original title of "parse vs.
render stages, and best use of memory."
Hmm. Some gremlins or leprechauns are having some fun somewhere...
Date: 30 Jan 2018 16:10:20
Message: <5a70df3c$1@news.povray.org>
> find my own post!
Oops! sorry. 'Twas I
If you look at the thread in a newsgroup reader. It is only a branch of
the thread that has that title. Replies to any other posts will gave
your original one.
I just wanted to commend the manners of the newsgroup.
Regards
Date: 30 Jan 2018 17:05:01
Message: <web.5a70eaf6882c75ada47873e10@news.povray.org>
Ah, the leprechaun has been unmasked :-P
Strange that it shows up in such a way in the web interface; I've actually
noticed this title-switching before, over the years.
How did you do it?? My inquiring mind is curious. I won't tell anyone  ;-)
Subject: Re: OT: :-)
Date: 30 Jan 2018 17:34:30
Message: <5a70f2f6$1@news.povray.org>
Begora and the cream o' the morning to ye. ;-)
I'm sure you can't do it on the web interface.
When you reply to a post using a newsgroup reader. At least in
Thunderbird, you get a pop up window just like an email. You can change
the subject line there.
Also when using a newsgroup reader. It can sort the threads into
branches, following a separate conversations. Allowing you to see who
replied to what. And some newsgroup readers allow you to ignore branches
or whole threads.
Regards
Date: 30 Jan 2018 17:55:01
Message: <web.5a70f7111b69d08aa47873e10@news.povray.org>
That's really strange and fascinating. Looks like something the web admin should
take a look at, if a post's title can be so easily changed inadvertently (or on
purpose by a 'malicious' gremlin, egads; chaos would ensue!)
Thanks. And Top 'o the mornin' to ya, laddie. (Well, it's evening here, but what
the He..)
Date: 31 Jan 2018 01:47:58
Message: <5a71669e$1@news.povray.org>
It is deliberate IIRC. Many moons ago when I was a callous youth(ish).
You could only access the groups with a newsreader. After a lot of
complaints from noobs. A website with limited access was created. As for
the Admin, he went to the darkside (photography), years ago. I think the
site just runs on automatic until it stalls.
BTW
Using a newsreader can give you access to more groups than you can see
on the website. And posts appear instantly you don't have to wait.
</sales pitch> ;-)
> the He..)
Likewise, the sun is over the horizon, somewhere on Earth.
Regards
Date: 31 Jan 2018 05:00:00
Message: <web.5a7192b91b69d08a91b9b16f0@news.povray.org>
No need to worry. No data was changed. The SQL query behind the thread digest
shows the title of the newest message in a thread. The thread activity digest
shows the title of the first message, and you can see that it didn't change :-)
The web frontend does actually know the thread structure and could properly
display it. However, back when Chris Cason and I developed the web interface,
HTML and CSS were not far enough along to create a good interface for it in a
finite amount of time (we had to have it work on IE 5&6!), so we stuck to a
plain view.
Thorsten
Date: 31 Jan 2018 08:05:01
Message: <web.5a71bec51b69d08aa47873e10@news.povray.org>
Thanks. And I see that the thread activity digest does indeed show the original
title; I didn't notice that before.
I book-marked the original thread anyway, at an earlier date, so all's well. I
think Stephen pointed out that the 'new' "OT :-)" title--as seen in the main
thread digest-- will actually change back to the *original* title, if I or
someone else posts a reply to one of the 'earlier-than-OT :-)' posts(?) I
haven't tried that yet, but it sounds... fascinating ;-)
